Antonio Landsberger
Distributor
    294
Reputation
153 Spectacular
8 Followers
Personal Information
  • Occupation
    ComputerWorks employee
  • Location
    Germany
Recent Profile Visitors
6,804 profile views
  1. Hi @Stefan V The answer to your question will come down to the specific situation. If you have a list of values, you'll want to use the "Flatten" node first. Then it depends on whether you want to convert a string to a number (no decimals) or if you want to convert a string to a float (number with decimals). For float conversion you can use the "Float" node. For number conversion you can use the "Function" node and write "int(x)" in the info palette. Then there is the issue, that your floats use commas instead of dots as a delimiter. So, you'd have to change the comma for a dot after flattening, then use the Float node, but only if the value is a string. You see, this is a bit more complicated.
  2. @Giobbe Check out this page explaining all the possible OIP options for Marionette Nodes and how to implement them: https://github.com/Vectorworks/developer-scripting/blob/main/Marionette/pages/Implement a Node.md
  3. Do you know, if there is already an entry for this specific wish in JIRA? I couldn't find one. If there is, please let me know.
  4. Unfortunately doing it this way is pretty bad performance wise, rather than initially filtering by the active layer within the Objs by Crit node. That's why an OIP checkbox for "currently layer only" would be nice as an improvement of this node.
  5. @Johannibal Check out this awesome python script by @Takeshi_Kimura I just tested the python script in Vectorworks 2026 and it still works flawlessly in a new empty document with the scale of 1:1.
  6. Where could be the issue? Since it's a single node I post both the document and the code here: Write symbol names in worksheet.vwx @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'List all symbol names in worksheet' ) this.SetDescription( 'Running this node will first create a worksheet, then fill it will the names of all symbols in the resource manager.' ) def RunNode(self): import os HSFPath = vs.GetFPathName() FileName = os.path.basename(HSFPath) WorksheetName = FileName[0:-4] #script resourceListID, numItems = vs.BuildResourceList( 16, 0, '' ) WorksheetHandle = vs.GetObject(WorksheetName) if WorksheetHandle == None: vs.CreateWS(WorksheetName, numItems, 1) #{Save the current AutoRecalc state} autoRecalcState = vs.GetWSAutoRecalcState(WorksheetName) #{Turn off worksheet Auto Recalculation} vs.SetWSAutoRecalcState(WorksheetName, False) for cnt in range( numItems + 1 ): vs.SetWSCellFormulaN(WorksheetHandle, cnt, 1, cnt, 1, vs.GetNameFromResourceList( resourceListID, cnt )) vs.SetWSAutoRecalcState(WorksheetName, autoRecalcState) vs.RecalculateWS(WorksheetName)
  7. As I understand it: The active layer will be set to the chosen visibility.
  8. For layer visibility there are HideLayer ShowLayer GrayLayer
  9. Exporting Marionette networks (particularly big ones) as Python results in a convoluted mess of variables. I don't believe, that kind of code is suitable for creating plug-in objects.
  10. Does anyone know, what exactly this image is depicting?
  11. @Marissa Farrell Could you please look into this? A conversion is ok, as long as the original object is left in place and the new object is just temporary.
  12. Here's the new link: https://github.com/Vectorworks/developer-scripting/blob/main/Function Reference/Functions/vstGetEventInfo.md in case someone stumbles upon this entry like I did.
  13. Hi @nbakovic What you want is either an event triggered script run, which Marionette and scripts have no access to or knowledge of, or a script that runs in certain intervals to check for changes. The latter is also not possible, because that would essentially be a script running in the background, but Vectorworks is always blocked during script runtime, thus there could also be no change to check while the script is running. You could create a menu command (from a Marionette wrapper), that shows you the relevant information you want to see - no matter where in the document you are. It could even be information from different objects and records (all in this one message).
