Nikolay Zhelyazkov
Vectorworks, Inc Employee-
1,913 -
Everything posted by Nikolay Zhelyazkov
Hello @nakedeye, Thank you for spotting this and posting it here! 🙂 Best Regards, Nikolay Zhelyazkov
Hello @JAC71, I will write here so that others that might be having the same problem could follow the discussion. In your file you have edited the TBB Style and made the TBB graphics to be By Instance. This means that each of the TBB objects using that style will not be using its Title Block graphics. When you create new TBB using that style and the TBB Tool, it is simply not getting the Title Block graphics as it is not set to By Style. So, if you edit the style and click on the button left from Title Block Graphics in the Title Block pane you will see that the Title Block will appear in all objects using that style. My assumption of it disappearing is that at some point you have made the graphics to be By Instance by editing the style and then you have started placing the TBB instances. If you have placed the TBB instances while the graphics were By Style, they would not have changed when you have made the graphics By Instance. Hopefully this solves your issue 🙂 . Let me know if you still have any issues with the TBB. Best Regards, Nikolay Zhelyazkov
Hello @BGD, Yes, you could duplicate the saved resource and then edit the duplicated resource and set its Orientation to Portrait. Another thing you could do is to simply use Fit To Page or Fit To Printable area Sheet Size for the Title Block Border and it will automatically fit to your page. Let me know if you need any further help. Best Regards, Nikolay Zhelyazkov
Hello @JAC71, Can you send me a test file with the invisible TBB? Thanks, Nikolay Zhelyazkov
Hello @Hans-Olav, The Custom Text param is not cleared when you are not using Drawing Stamp. In order to get the custom text for objects using the Drawing Stamp only try using the IF formula like this: =IF( 'Title Block Border'.'Display Drawing Stamp'; 'Title Block Border'.'Custom Text'; '' ) Best Regards, Nikolay Zhelyazkov
- 26 replies
- 1
- drawing schedule
- sheet list
(and 3 more)
Tagged with:
Project Sharing vs Title Block Border tug of war
Nikolay Zhelyazkov replied to Christiaan's question in Troubleshooting
Hello @mouseman85, The TBB is still requiring all TBBs to be checked out when using the Title Block Manager. However, I do not think that this should affect creating of new empty layers. Could you send me a test file or tell me the steps to reproduce what you are experiencing? Thanks, Nikolay Zhelyazkov -
Energos Worksheet Reference Information
Nikolay Zhelyazkov replied to Samuel Derenboim's topic in Energos
Hello all, You could try using the information from the Energos Labels and extract it in a worksheet. Keep in mind that you will get only one object with all the information of the whole document, database rows won't help much. Best Regards, Nikolay Zhelyazkov -
Ops, sorry about that, seems like I have missed this important detail. Then, I think that this is not possible at this time, as the TBB is creating the text that way. It is not doing any modifications to the text settings, so it is interesting why the text is flipped in one place and not in the other. I will see if this is actually a missed case in the TBB logic and let you know in here.
symbol not showing in plan view
Nikolay Zhelyazkov replied to Phil hunt's topic in General Discussion
Hello @Phil hunt, If your symbols is hybrid and has 2D and 3D graphics, only 2D graphics will be displayed in plan view. If this is not the case, could you send me a test file with the symbol in it? Best Regards, Nikolay Zhelyazkov -
Hello @Andy Broomell, Try switching off the Document Option in the Display tab - "Adjust flipped text". Best Regards, Nikolay Zhelyazkov
Hello @DBruhnke, I am sorry to hear that the provided example did not help. I do not know of any other way to get better results. You could ungroup the result from the file I have sent you and delete the parts that you do not need, such as texts. Better results could be given with a clearer scheme with higher quality and maybe less details. Best Regards, Nikolay Zhelyazkov
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
Hello @Conrad P, @Dima, Actually, the offset of the number from the socket it is connected to could be modified from ConnectCAD Settings dialog for all Circuits in the file. Best Regards, Nikolay Zhelyazkov
Hello @DBruhnke, - The tool is just a demo and it is still not certain if it will be released in any of the future versions or not. Best Regards, Nikolay Zhelyazkov
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
Glad to help. 🙂 - Yes.
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
@Julian78 Here is a VW2019 file that you should be able to open: Vectorize Test v2019.vwx You will not be able to get this result, because the tool it is made with is still only a demo and not available.
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
@Julian78, The file is VW2020 file, which version of VW are you using? I have created it with a demo tool that I have, but I still had to convert the pdf to jpg.
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
Here is what I managed to get. Let me know if it gets the job done for you. Vectorize Test.vwx Best Regards, Nikolay Zhelyazkov
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
Hello @Julian78, Could you send me the image file? I want to give it a try and if I succeed I will send you the vwx file with the result. Thanks, Nikolay Zhelyazkov
- 18 replies
- bitmap
- tracing image
(and 3 more)
Tagged with:
Title Block Setting Updating scale question
Nikolay Zhelyazkov replied to MartinFahrer's question in Troubleshooting
Hello @MartinFahrer, The TBB is displaying the paper scale of the layer (respectively the custom scale fo the Viewport) which is always in this format. Anyway, as this seems to be important feature for you and other users, we will investigate if it could be done the way you want it. Best Regards, Nikolay Zhelyazkov -
How do I tag a standard Symbol with the Data Tag tool?
Hello @Christiaan, You should use the Object Name function, it is above the Symbol Name in the function popup in Define Tag Field dialog. Best Regards, Nikolay Zhelyazkov -
Title Block Drawing Stamp Transparency
Nikolay Zhelyazkov replied to BenV's topic in General Discussion
Hello @laurakukulski, - Yes, unless you are using styles with the TBB Graphics set to be By Style. -
Hello @ryanww, You could do that by editing the symbol that is used by the device for its labels. You could see which is the symbol from the Device's OIP. - For signal and connector types there are similar files as the CustomParams.txt located in the same folder - SignalTypes and ConnectorTypes. You could edit these files or add modified versions of them in your user folder. However, if you want to remove an entry from there you will have to edit the app folder file, which is usually not recommended. Best Regards, Nikolay Zhelyazkov
Hello @Stephen Musiol, I saw you PM and answered you there. Anyway, to inform the others reading this, deleting of unused Issues is now automatic in VW2020 and no script is needed for this purpose anymore. 🙂 Best Regards, Nikolay Zhelyazkov
Data Tag - Dynamically changing fill colour
Nikolay Zhelyazkov replied to Cookie_NZ's topic in General Discussion
Hello @Sebastiaan, - Yes, Data Visualization could be applied to Data Tags. Best Regards, Nikolay Zhelyazkov -
Border & Title Block Rendering as Sketch
Nikolay Zhelyazkov replied to ACopeland's question in Troubleshooting
Hello @ACopeland, Could you send me a sample file with a TB rendered in sketch? Best Regards, Nikolay Zhelyazkov
