100 -
Reputation
6 NeutralPersonal Information
Occupation
Lighting Designer
Homepage
www.nakedeyelighting.com
Location
London, UK
Recent Profile Visitors
1,022 profile views
Schematic Views cannot be Pasted without the Model Object they are Based On
nakedeye replied to pfalvi's question in Troubleshooting
Thanks, yes I've the same issue. I'll try the rollback. -
Thanks, I also found if you right click you get an adjust boundary command which does what I need.
Hi all, I'm drawing seating blocks over an imported 2d seating plan. if I draw a rectangle over say a block of 6 rows at 20 wide and adjust the space between to say 450mm I get a row missing. is there a way of dragging out the bounding box? I've tried editing the seats and copy and pasting a row in but its not worked. Thanks Mx
Hi all, I've an issue with a schematic view. I have a series of vertical pipe and bases made from an extruded circle for the base and a lighting pipe converted to a hanging position. In ISO the fixtures are hung correctly however making a schematic view in Right View the mole strip is correctly rotated but the JDC strobe is not and in Front View the JDC strobe is correct but the mole is not. Anyone with an idea?
Try using a worksheet, you can add whatever information you want to this. If you message me directly I’ll send you one of mine. max
Hi Russ, this does throw the auto numbering out. I've tried this in a console and it doesn't show up.
Thanks, yes I did the same and couldn't find anything suitable so I've used the circle truss tool as a basis for a symbol.
Hi, anyone out there with a 25m or even 30m Diameter Thomas circle truss? something around 520cm deep x 520cm high.
I've just imported both a Robe 600 LED Wash in mode 5 and Robe Spider in mode 10 from the GDTF website, they are shown as 37 and 123 channels respectively which is what I'd expect. On importing into VW the DMX count in the object info pallet is shown as 38 and 124...anyone with any ideas of whats happened here?
Thanks Tom, its only something I've only just noticed.
Is there a way in vision to change the starting universe of artnet from 0 to 1? I usually ignore the 0 and patch artnet 1 to universe 1 and so on. I can change this on the desk patch though I have to change the dmx nodes as well.
I'm trying to attach a vertical pipe to a truss system so it both moves up and down with the truss structure and the pipe and any fixtures attached to it appear in the braceworks calculations. There are a few posts I've seen regarding pipes and half couplers, are there any basic rules with dealing with these things?
Hi, I'm posting this in Entertainmant as its not really a braceworks thing. The truss on the right is made from truss sections and given a height of 5m and hoist data for M7 & M8 show the bottom trim height of the truss (and the weight calculated in Braceworks. The truss on the left is the same truss but converted to a hanging position however M6 and M5 show a zero truss trim height even though if I select system objects the truss, lamps and hoists are selected. I'v managed to amend the data tag for M5 so it shows the load trim however this I'm guessing the hook position as its at 4174. I'm looking at setting up a second data tag for hoists on hanging positions so can anyone give me an idea of the syntax for the tag? Thanks Mx
Any good recommendations for 3D human figures for use in VW? I have used both AXYZ Studio and Renderpeople and although cost money both are really good and Sketchup warehouse which is free. Any other options with a good polygon count/quality ratio? Mx
