ACopeland
    2
Reputation
0 Neutral
Personal Information
  • Location
    United States
  1. I had the same issue-if you are on a Mac, the newest IOS will do this. Catalina doesn't support the older version I had to switch from 2018 too 2020 and it worked.
  2. I had this issue on v2018 and now on v2020 (both educational, I'm a prof): When changing settings on the edit title block screen, after clicking OK, my information is there but the render of the title block and border is now rough sketch. When I try to change the Render on the Object Info tab, I get the options of different renders, including No Sketch. Selecting on this does not get rid of the sketch effect. The title blocks on other sheets are not effected; I can't copy and paste from another sheet without it becoming rendered in sketch. This only happens on the sheet I initially am on when I edit the title block-usually the first one-none of the others, even when I renter the editing screen on a different sheet. Is there another place the rendering setting can be changed? Does anyone else have this issue?
