ColinW
    155
Reputation
72 Excellent
Personal Information
  • Occupation
    Architect
  • Homepage
    www.designtwo.co.uk
  • Location
    United Kingdom
Contact Info
  • Skype
    designtwo
Recent Profile Visitors
4,430 profile views
  1. 3:38 - AMD Ryzen 9 9950X / 128Gb DDR5/6000
  2. Got my vote. Hit this issue over the last week trying to replicate some historical windows, several hundred all different sizes (!). The diamond leaded glazing for hidden line renders is an extra challenge.
  3. Yes, I've seen the same behaviour. A bug has been submitted.
  4. Dave, file attachedtest render model.vwx
  5. 8:11, AMD Risen 7 7700, 64Gb Ram, RTX 3070 OC 8Gb, Windows 11 (£1,520 in 2023) 27.20, MacPro 2013 12 Core, 32Gb MacOS 12.6.4 (£4,000 in 2014)
  6. Windoor allows control of the architrave offset if you have access to it.
  7. PDF Squeezer on MacOS has been my go for years, it’s easy , quick and controllable. Oh, and good value.
  8. That’s disappointing, the Graphic Legends feature shows great promise
  9. The most straight forward work around is to use Windoor which allows more control of this. I do wonder what led to the 2 dimensions being one parameter, is this a ‘normal’ thing somewhere?
  10. Emily, Thats right, it's line control is just out of reach for now! good luck with your custom window symbol. Regards Colin
  11. It seems to use the None class, and as you noticed, doesn't appear as an option in the Window/Settings/2D visualization tab. If you don't already know, if you ever need to check these you can set up a test PIO and assign seperate classes to each category in the 2d visualization tab, then select and press Command+K, it will be converted to a group so you can then check which classes have been assigned to each part. Some groups will have a class from the visibility section of the same 2D visualization tab, so the sash swing is in a group by default in the visibility class 'Sills', but inside that group the swept arc of the sash is defined by the 'Swing' and is configured to use the class fill and line; the dotted rectangle showing the sash projection uses the 'None' class, but it's line and fill do not use the None class settings so it is preset as far as I can tell. Hope this helps (!), it's not very intuitive and the naming of the visibility classes is certainly misleading.
  12. It is surprising, I have found them really helpful. Thank you!
  13. If the window is controlled by a style, right click on the symbol defining the style in the resource browser, you will see the plug- in object options in the context menu. if it is unstyled, right click on the window PIO to get the same menu.
  14. Like Christiaan, I used to use NBS Building, that has now been replaced with Chorus which is too expensive for a couple of months use per year. The small version of Chorus doesn't use Uniclass and is too restricted for the work we get involved in, the medium and large scale versions are difficult to justify the costs for limited use. So now when we do write specifications, it is manual office standards.
