fabrica
    351
Everything posted by fabrica
  1. fabrica
    Baseboards
    either extrude along path or the wonderful plug-in from AF-Design: https://plugins.andreafacchinello.it/baseboard/
  2. @Kevin McAllister I put a few similar tools together (long click to open) to shorten the top bar ...
  3. the top plan view of a custom window is messed up - looks fine in 3d just not in plan view...
  4. 2024 Icon -> 'Apricot Crush' ! 😉 2024 copy.icns.zip
  5. draw a polygon around your walls , then AEC Menu -> Convert Objects from Shapes ... choose slab and your done!
  6. @Chris Fleming maybe look at twinmotion ?
  7. for me, I would do the following: - in your editor of choice (affinity, Pixelmator etc) , I would overlay the ambient occlusion (at 90%) onto the base colour and export as 1 image. Then add this image to the colour slot - change OBJ Attribute to -> image Not 100% sure but don't think Vectorworks can handle normal or height maps. (so no need for them) If you need to scale image you have to use the absolutely useless 'set by image' button ..! If you are only using 'shaded' render that's all I'd do...
  8. make them symbols and auto hybrid.... https://app-help.vectorworks.net/2017/eng/VW2017_Guide/Shapes3/Creating_Auto_Hybrid_Objects.htm
  9. 12.45 14" Macbook M1 Pro, 32GB 13.2 ; VW 2023.SP.3
  10. another option is the split tool - draw your wall as normal , mark out where you want to make cuts , and then change wall heights to suit.. Then use an extrude etc for your wall capping...
  11. sorry, just seen you were after hatch ! not a texture………
  12. save, quit and restart vectorworks gets rid of them.... (probably not the answer you wanted!)
  13. sounds related to this: (the workaround is to select the wall and move it 0,0 - this will regenerate wall)
  14. if any consolation - its hasn't happened to me since first post....
  15. if you pull one window out the other one shows up , and if you put it back in both disappear again.
  16. @Matt Panzer as is typical I can't reproduce it at the moment ! It seems to only happen on the M1 and not the intel iMac , and a restart of vectorworks clears it. Will send on once it happens again - (it doesn't happen everytime you change a window or door)
  17. getting consistent crashes when moving doors / windows around in walls with components with 2023. - especially with duplicate copy of a door or changing window heights - will cause a crash - changing a window height (if more than one window in wall) will result in windows disappearing in 3d view - but show fine in plan view. below is sliding door at 2600mm high - changed to 2650mm high and both disappear in 3d. (all looks ok in 2d) (on MacBook Pro 14", OS 12.6)
