AlanW
    3,423
Everything posted by AlanW
  1. @RideHi i work in 3D a lot with the automatic working plane set which highlights in colour the surface plane you will work on and allows you to work directly on the plane in 3D. this key toggles it off and on " \ ". Also to select things i hold the B key down and you can select the line easier when in open GL. (Shaded) HTH
  2. @Niels TimmerHi, Looks like you have to put the hatch on the below class of the auto Hybrid. Set the Auto Hybrid up the way i have with classes that way if you move the section plane the drawing changes to section under or above. Creates multiple views by adjusting classes in the viewport. HTH Auto Hybrid Material Hatch v2022.vwx
  3. @hollister design StudiohHi Not sure if this is what you want, Wrap Text?
  4. @RideHi, I draw a 3d Polygon then extrude along path. Make sure you move the object not the line as it extrudes down centre of object, by positioning the object edge to the line it will be easier. Not sure why the left piece sits out different. HTH Trim.vwx
  5. @TomKenThanks. Will have to do this. Told on TM forum to create a subfolder and add the rotator to this. @Dave DonleyIt would be better if the VW Datasmith was to export the door itself without exploding it then exporting all the little pieces. This appears to happen on all items. Am i missing something in the export or import section??? Thanks
  6. Hi Finally using Datasmith over 3DS export and the screen resolution heaps better with DataSmith. One issue i find is that in Twin Motion when i import and keep Hierarchy the doors and other items break down into subcomponents, so when i want to put a rotator on a door i have to add all the door components to the rotator rather than one object, the Door. Am i missing something or can this be adjusted so that only the door object is exported rather than all the subcomponents seperatly? With a big file currently the expanded list is way too large. Thanks in advance. Alan
  7. @GalMake sure none of your adjacent modifiers touch or overlap, this causes the terrain to do strange things.
  8. @hollister design Studio HI this video may assist https://www.youtube.com/watch?v=lvYGzeW05ik
  9. @Benson Shawthe 2d polys form the basis of generating the 3Droof face and should be deleted when creating the roof or roof face. The roof or face can contain the 2d hatches as well as the 3d texture for either shaded or wireframe. some people ad a hatch over the roof but this is not needed. the component off set has an issue, sometimes the offset is a negative and sometimes its a positive even when you type the same offset. i saw in the file only the none class polylines were causing the problem and not the 3d parts. Alan
  10. @hollister design StudioHI, the issue is the 2d lines you started with have solid fills (None Class and the computer fills the colour between the ends of the lines. Set all your 2d lines to none fill and should solve your problem. I hope. Alan
  11. @line-weight LOL thanks, that works 🙂 sometime these have a simple solution looked by different eyes. Thanks again to all and this forum is the best for getting feedback.
  12. Thanks Pat, From the script magician to a Noob like me LOL. Haven't been into writing scrips so I may need a tutorial to start with. Thanks Alan
  13. Hi, Is it possible to close the doors on the lower level design layer so they don't appear in the upper floor plan when multiple design layers are visible without masking them. I can close them but when i need the lower floor plan the doors are closed when i need them to show open.????? See attached Thanks
  14. Hi Dave, Still appears to be issues with some textures from VW and Water in TM not connecting. See attached. Alan Untitled 2.vwx Untitled_2.zip
  15. Hold the B key as it will view to the item you want and you can drag it easily. HTH
  16. Hi what i would do is to create a profile fascia and gutter and extrude along path. Remember the profile extrudes down the centre of the profile so you move the profile NOT the line. See Attached. HTH
  17. Hi My settings seem to show the edges reasonably well.
  18. Hi, I still use C4D to export my final model from VW and do all the dressing up in TM. Never have any issues with strange textures or geometry. Datasmith not working properly yet as far as i can see. I import based on Textures always. VW create different items with any texture and change them in TM. HTH
  19. @Dave DonleyHI, I have noticed that i can save my Datasmith file from VW to any location which is good but TM wont allow me to select another location of the file. I am using the current TM 202.2 Preview 1 to test. Am i still missing something?? Still working with C4D exports. Example of my work.
  20. Hi Dont try to move your model in TM as it is referenced to VW file based on the RLs Click on the site model in right dialogue boxes and hit f to locate it. if you move it each time you change the VW model and reimport you will have to move the model. Leave it where it is. HTH
  21. Hi, Then main thing when using EAP is not to try to move the line move the profile as the extrude runs down the centre of the profile. moving the profile moves the profile to the side of the line. hope this helps. Just use a polyline of 3d poly.
  22. @Pat StanfordThanks for reply Pat. Am Interested in knowing how much they pay for and what speed is their upload and download? Also what is the time delay in getting files up and down? More comments welcome. Seems like everyone is dragging the files up and down and working on them locally, not using cloud as a server, as we do in the office, may be wrong but still need to get head around this if its possible and feasible as an everyday working setup. Thanks in advance.
  23. Is anyone using Cloud storage for all their server everyday working files? Our office is considering it but using Team viewer to download drawings they can take 20min of so for an average drawing, then i work on it at home. My concern is if i am continually saving this file as i am working on it is it as instant save as quick as it is to a local server? Any comments welcome Alan
  24. Hi, Anyone else having issues with stability of VW2022 SP2???? Stalls and crashes many times a day. If I drag a window or wall or just do menial tasks it will stall and crash????????? Any remedies??
