MaltbyDesign
    262
Reputation
32 Great
Personal Information
  • Occupation
    Intern Architect AIBC
  • Homepage
    www.maltbydesign.ca
  • Location
    Canada
Recent Profile Visitors
  1. @Tom W. Thank you so much for the step-by-step! That worked beautifully!
  2. Hi Tom, this sounds interesting but I'm not sure how to proceed once I create the hardscape. Can you provide more detail on how I "set it to Aligned mode then add a Grade object as a Surface Modifier along the LH edge."? Or point me to a tutorial which shows this? Thank you!
  3. Hi All, I'm trying to draw an existing loading bay slab that slopes to an interior floor level (0'). However where the slab meets the exterior wall, it slopes to follow the grade of the adjacent sidewalk, so falls from a height of +1.75' down to +1.35', per the attached image. Is there a quick and easy way to edit a slab to do this?
  4. I've only seen an informational video for this. Are there any detailed instructions anywhere on how to use the new Bluebeam connection tool for those of us who haven't used it before. The video looks promising, but detailed instructions would be helpful.
  5. Have you upgraded your IOS to Sequoia? I just upgraded and immediately started getting this same pop up but for VW2024. It comes up every time I open VW and find it annoying and would like to find a way to disable it.
  6. Thanks for the suggestions. I think I got it figured out. There was also a Wall Data input area in the OIP Shape tab that wasn't updated. Not sure why there are three different locations where the Mark needs to be updated.
  7. When I apply wall data tags to some of my walls, they incorrectly label the wall type. I've added a mark (in this case W2) in the Data field in the wall style and have ensured that the same Tag (W2) is added in the Data tab of the Object Info Palette when the wall is selected. However when I add a wall tag to the wall it is identified as W1. I've had this problem on several drawings and am wondering if anyone can recommend a solution or if this is a bug in VW2024?
  8. I was wanting to be able to see a simple knob or D-pull. It would be nice if cabinet hardware could be used on the bi-folds, as they don't usually have standard door hardware used on them.
  9. Hi Tom, I'm using the "Door Long Rd" data tag from the Dims/Notes Toolset. I mostly use the VW's Door Tool and Window Tool in the Building Shell Toolset. I only used WinDoor for a couple of storefront doors that I needed to include sidelights and transoms.
  10. Hi @Jonathan Pickup, when I try to use a data tag to label a WinDoor generated door, the data tag isn't able to select the object. Is there a trick to using a VW Data Tag for labeling WinDoor objects?
  11. Just noticed in VW2024 that hardware doesn't show up on bi-fold doors. It appears on regular swing doors, though. Is this a know bug?
  12. @Pat StanfordI think that's what I just figured out. Very frustrating.
  13. I don't know if I've unknowingly changed a setting but I can no longer edit the boundaries on Spaces. Also, the Spaces seem to be now being called up as Data Tags in the Object Info Pallet. So it seems that they have somehow changed from a Space Label to Data Tag and lost the ability to edit the boundaries. Any thoughts on what's going on?
