ottoLejeune
27 -
Everything posted by ottoLejeune
After many crashes... project files disappearing... lots of lost time... we have stopped using 2016 Project Sharing until it can be proven to be more reliable. SP3 seems to have fixed a number of issues... but the AFP/SMB issue that plagues the Project sharing feature is not worth delving into that again. The guide for VW project sharing says we need to connect our Macs to our Mac server via AFP and not SMB. But SMB is the default since 2014. It's not a simple matter to try and force all the Mac's in the office to revert back to the old AFP format. (Believe me, we have tried!). I look forward to the VW team to come up with a solution that can make this Project Sharing feature "just work". Right now, it does not, "just work". Unfortunately, I suspect they are busy stitching up their 2017 "features", planning 2018 features...etc. instead of focusing on simply making a version that "just works". That's just my feeling.... what with them having to push out a new version every year... which doesn't seem to "just work" until at least SP 3 or 4. Will try again when SP 4 comes out the door.
Automation for sequential window ID-Tag's ?
ottoLejeune replied to Patrick Fritsch's topic in Architecture
Was this ever addressed? Was there ever a way found out how to sequentially label windows: 1. As you insert them and 2. After they have been inserted. I see this happening in Revit and would LOVE to see this feature in VW. And what happens when a door or window is removed… can the tags reshuffle? Answers would be good. -
We started off a project recently in 2015 on my insistence. Just a few months into it, it seems that I am switching us back to 2014. It's all due to the confusing issues that the wall tool(s) are causing us. I added some screenshots to show one of the issues. I show how both the 2014 and 2015 versions handle the same - Fit Walls to Objects - command. The exterior wall assembly used is a basic wall with only the exterior siding extending 12" down past the flooring. Simple. At least for 2014. 2015 just messes it completely up. This is just one of a number of issues with the walls. On some walls (same design layer… same story… etc), I need to enter completely different hight numbers to make them be in the same plane. i.e.: I may have to set one's Z to 0' while another needs to be at 8'-9" ?? I am baffled. Another item you may notice in the screen shots has to do with the text: in 2014, the grouped text in iso shows unflipped… while in 2015 it gets continually flipped. Sometimes I need to enter the group… and put all the text back onto the Screen Layer. Needless to say, I am starting to believe the rumour around here that we are to never trust an odd numbered year of VW. Best wait for 2016 and in the meantime, stick to 2014. I tried to break that myth… but I just haven't had any luck. Perhaps VW can switch to updating every 2 years instead of trying to push it out once a year?? Any help would be appreciated. Meanwhile… back to 2014. VW 2014 & 2015 with the latest SP's as of March 20, 2015 iMac 3.4 GHx intel core i7 w/ 24GB RAM
I have the following drawing in 2015: 5 Townhouses in 2 blocks. Each block is 3 levels. Each level is one VW Design layer with it's own story height and wall height. Exterior walls class and Interior walls class. Fine. All seemed good… Walls were/are the right height… visually (2D & 3D). But when you select some walls, the info window shows the following: Height: 8'0" Top Bound: Layer Wall Height Top Offset: 19'2 1/2" Bot Bound: Layer Elevation Bot Offset: 19'2 1/2" If I try and change the Top or Bottom offsets to 0, the wall (visible in iso), grows. So… change the bottom offset to 0 and the bottom of the wall in iso extends DOWN 19'2 1/2" What gives??? Anyone else have this happen? thanks otto VW 2015 SP 2 iMac 3.4 GHx i7 w/24 GB RAM
I have two files with plans/models. Each of those plans have Space tools for each floor. Each of those spaces have information I would like to use in another file (the "master file" where I print everything from). I can create viewports of the plans in the "master". That's simple. But when I create a worksheet that is intending to pull data from the spaces in this plans, I cannot specify exactly the criteria. Essentially, in the "master" file, the worksheet pulls every instance of a particular space. Thus, if I have one viewport showing the plan without the areas… and another viewport showing just the areas… the worksheet counts the areas twice. I cannot set the criteria to pull info ONLY from the one viewport. What am I missing?? Why can't it do this? thanks otto VW 2015 Architect
Preserving world coordinates and elevation data for survey
ottoLejeune replied to Damon's question in Troubleshooting
Damon, First thing I always like to do is test it. • Import the DWG file. Draw something on it… either in 2D or 3D. Save that. Export that to a DWG and send it to someone there to see if that works for them. Drawings I have imported have retained the world coordinates they came with (checkout all the dialogue areas in the DWG import section in VW). You can then center your page on the portion of the drawing you want to work on without changing those coordinates for exporting later. Check out the VW Help for this. Changing 2D loci to 3D… (In case they give you a 2D, "flat" drawing with 2D loci with heights listed beside each… here's what I do) • In the VW imported file of their survey, create a new layer with the same scale as the survey. You will use this layer for 3D loci. • Grey/snap other layers so you can see the survey as you drop 3D loci on top of their 2D loci locations…. adding the Z height to your 3D loci as you go. • Once finished, you have a set of 3D loci you can select and "Create Terrain" with. Look in the VW Help on how to create the terrain. • WIth the terrain you can start to build your project in 3D. Hope this helps. otto -
We use the Door and Window ID tags along with the Door and Window Schedules a lot here in our office. Now that we can show the ID tags in 3D as well, things are almost there…. almost. Is there a way to show, along with the ID tags, the size of the window or door? I ask because we are having to manually place that information alongside each and every door and window on our Building Permit sets--the City WANTS this information on the plans and elevations… the inspector does NOT want to have to jump back and forth to the schedules sheet. Why can't their be a simple way to either show or not show this info in plan and/or elevation (3D)? We already have the options for the Detail and Sections markers do we not? Does anyone know of a plug-in that could help out with VW 2014 or the 2015 version rather than having to wait all the way until 3/4 of the way through 2015 for the 2016 version? thanks otto
The new hatch on walls feature is rather confusing. Really not getting the settings at all. As well, the "help" for 2015 is extremely limited? and now it's not working! RIght now, this is what I receive when I try to access the 2015 Help: AccessDeniedAccess DeniedE7891C5F8DC1D892Ff2OLjKh/iU+2p8w5MC3un+aeLg2tR69up3WnigrAhVkqsy/i4pMDDjg/XXqqKN2 ??
Good question, actually. We generally just fill it with white because we find the components fills to be too crude. Hopefully it will be improved in 2016.
Proper foundation toolset
ottoLejeune replied to Patrick Fritsch's question in Wishlist - Feature and Content Requests
+1 Agree on the BIM and Simplicity issue--Foundations are a fact just as are Stairs. A simple dialogue box/window that lets one enter all the attributes required? lets it be shown as solid on one layer while dotted on the other? is just another key component to an even more competitive, whole-rounded, BIM CAD system. Would be great to see. -
The initial release was absolutely the most stable of the VW 2014 releases. SP 1 was loaded in at our office? and crashes started. SP 2 came along stating that it had some fixes for certain things? so we loaded that? and now it crashes numbers of times per day. It's crazy. Just mad. Why is it that the more it gets "fixed", the worse it seems to get?? We get memory issues? crashes on saves? too many different issues to count. Actually, we don't want to spend time counting because we need to get our work done and these crashes are causing a major loss of productivity. So far today? about 5 or 6 crashes?.
VW 2012 Crashing - Repeatedly Daily >1 Year
ottoLejeune replied to Catherine_99's topic in General Discussion
We have pretty much the same issues here. New iMacs.. generally all with 24GB Ram. 3.4 GHz i7 Latest os: OS X 10.8.4 We use 2012 & 2013. Both crash constantly throughout the day. Files that used to work in 2012 on OS X 10.6.8 just a couple of months ago are crashing every 30 minutes in 2012 on OS X 10.8.4 So I know it's NOT VW directly... but somehow it's how VW is working in 10.8.4. So when is VW going to put out a Service Pack? Soon? Very Soon? -
In our office Revit would end up costing us a pretty penny at the start. But with VW crashing so constantly, it's getting to be that VW starts costing money in lost time! I can't believe this program is so buggy even at SP4. And, honestly, the minor differences between 2012 and 2013... so tiny... really not worth the upgrade. So.. stability? It's lacking. As for the list of things to avoid so that it won't crash? Wrong. It just should NOT crash. Maybe they need to take some time out and make a version that really works. Take 2 years between upgrades rather than toss out another half-coded version every year. MAKE IT WORK. Or you'll have us leaving for ArchiCAD (Hmmm.. same parent company so they still see a profit?) or Revit (not happy with heading over to the dark side. Not happy at all.).
2013 seems to certainly be Crash Happy. It's getting to be unbelievably frustrating having to reopen a file time and time again! At least 12 times a day it's crashing. If there's a pattern to the crashing... I, for one, have not figured it out. I only know that this is a complete waste of time! I'm hoping someone at VW is reading the boards... maybe reading the crash data that is coming in seemingly fast and furious from all the crashes happening, and that they are putting together patches soon! And hurry! Soon you'll have to thrown out the 2014 version! Maybe that one will be super buggy as well until the end of summer 2014 ? I wonder if they couldn't just put one out every 2 years? That way they would have time to fix things... to make a better product... ? Just saying.
We tried installing and using 2013 Architect w/Renderworks on a new project once I saw that SP4 was available (I don't trust using VW from 0-SP3 because I know it's littered with bugs). However, seems that things are still not working properly with SP4 as we have been getting 2-3 crashes per day on a brand new project... clean file.. etc. Have we decided to troubleshoot the issue? No. We simply went back to VW 2012. It's not worth spending valuable time on trying to fix something that should have been put on the market in a working condition... maybe with one SP ... not putting out fixes every few months! Perhaps they should put a version out every 2 years instead? Spend the interm time making an awesome product rather than a "new" on that's buggy and crappy except for the last 4 months of it's shelf life before the next "NEW and IMPROVED" version arrives. Fix it please. You'll get more clients that way.
Why do callouts change to 3d plane when pasted in VW2012?
ottoLejeune replied to billtheia's topic in General Discussion
It happens to us as well. Absolutely NO idea why it does this. However, one thing we have found is that when you switch to Layer mode and then paste it in place, it seems to react well. (Or was that Screen mode?). The ultimate fix we use we found in this forum thread: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=158585 "..... Try Petri's 'Plane Mode' plug-ins on this page: Vector Depot Plug-Ins..." This is the link: http://www.vectordepot.com/plug-ins/ I added them to my MODIFY pull-down menu. Hope that helps. -
Fixed muntin distance
ottoLejeune replied to VincentCuclair's question in Wishlist - Feature and Content Requests
I'll 3rd that. Much needed. Very frustrating. -
Best to call your VW rep or reinstall from the original DVD/File... then download the updates. Sounds like one file was corrupted... and no way to figure out which one.
Try copying your site model to a blank / new file.... then insert the plant material and see if the same issue pops up? That may help narrow it down.... Also... (in a copy file)... delete the site plan and try inserting the plant material... Same issue?
Ah geez. Windows versus Mac again. An endless "debate". Honestly, there is NO use trying to argue your points. One side talks about how expensive things are... the other side talks about how everything "just works". Just use what you use and get on with it. DWorks: Some of us just like our Macs, okay? And maybe there's a reason Windows is making their new OS's more Mac like? EIther way, people just like what they like. If you honestly think it's all about a "pretty design" and the extra cost, then believe that... but please don't continue to fill the forum with more useless information. :-) thanks kindly. PS: Yes, we use Macs. Lots of them. Yes I play with Windows computers too... and, truth be told, I like my Macs. But I'm not going to labour on about why I stick to them... I'm just going to get back to work now. Enjoy the day!
Is it possible to display window & door IDs in elevations?
ottoLejeune replied to Markus Barrera-Kolb's topic in Architecture
Do we know if WinDoor will be built into VW 2013? That would be a great step forward for the VW folks. More BIM. More control. -
We have some problems with the Wall ID tag and linking to the database. Any assistance would be great. We are using VW 2012 SP4 Architect with Renderworks. If you draw a Wall Assembly on one layer... give that wall assembly an ID in it's data. Then attach a Wall ID to the wall using the ID Label Tool Select the Wall ID... look in the Information palette... under Data. You'll find a long set of letters and numbers in the Name field. This shows us that this wall ID is linked to this wall. So... if you replaced the wall with another wall assembly with a different ID, the ID would change. This works great. UNTIL you decide to create another layer with a wall ABOVE that layer in the Layer Stack. Do that... connect a Wall ID to a wall. All is well. BUT... Go down to the layer below it in the stack and try to attach a Wall ID. It works... but it's NOT connected in the Database. Thus, if the wall assembly was changed or the Wall assemblies ID was changed down the road, that Wall ID tag would NOT change. What's going on??? Please don't tell me they are going to only "Fix" this in version 2013 !?
Sweet! This works great.
True. And where, even, is the help for it? Nada. :-(
Was this ever looked into? It's only been 2 1/2 years on the wish list... ??
