P Retondo
1,914 -
Everything posted by P Retondo
Aa, you do not say what version you are using, that would be helpful. When I look at your screenshots, I have to say I have never seen that collection of results before. Doubt seriously this has to do with any wall style setting. Take care that you have a separate layer for your roof objects, so that you can be sure no other object is interfering. Also, check to be sure your wall offsets and heights (as shown in the OIP) are consistent. This problem could also have to do with your layer elevation "relative to ground plane" settings. I always set up a separate layer created for just the objects to fit to, duplicate the roofs there and sometimes extend my roofs or other objects to be sure they are fully above the walls.
I have been using the Wacom tablet and pen for well over 5 years because of tendonitis. It has solved my tendonitis problem and has been just as fast and efficient (possibly faster) as a mouse - save for the scroll-to-zoom function, which is handled by a rectangular touch zone on the pad. Because the pen executes a click by touching the pad, it is possible for location to drift during that operation, so take care not to move your stylus location when clicking.
Use the reference input fields in the OIP for your first benchmark, and get it to read properly. Take care to set the option to y or z value as appropriate. Then just copy your original benchmark, move it where you want it (using the "Move" tool is most efficient), and it will automatically read out the elevation per its location.
Not an authoritative answer, but my impression from reading various topics in the recent past is that there are still some elements of the program that can't handle large numbers. It happens when you have millions of lines of code.
It's easy to inadvertently change the class you create new object in. Look on the upper toolbar on the left where there are 5 little squares and a dropdown menu. Typically, that should be set to "None" to create objects in the "None" class. You should also check the classes that walls and wall styles are being created in. Those have separate settings that can override the object creation preference.
- 8 replies
- wall tool
- corrupted file?
(and 2 more)
Tagged with:
Texture cannot not apply on extruded objects
P Retondo replied to Rachel.w's question in Troubleshooting
Perhaps you are not looking at the object in a rendered mode (OpenGL or Renderworks)? Otherwise, the most common reason for this problem is that the object does not have a solid fill. Although you seem to be aware of this, double check - select the object and look at the attributes palette, first item. Also, something seems odd about what you say about seeing the texture when you edit the extrusion 2d object. Textures cannot be applied to a 2d object and would not show up. Are you sure you are clear about the difference between a texture, fill and hatch? -
Fractional display of dimensions resetting upon restart of VW
P Retondo replied to grant_PD's question in Troubleshooting
Grant, what version are you working in? -
This situation is just unavoidable with the way VW works right now. Peter's first suggestion is actually pretty close to how you would conceptualize the walls if you imagine the rafters having a seat cut on top of wall plates, but normally a framer would not do that on the gable walls, their sloping top plates would actually be lower at the outside corner. David is suggesting that if you fit walls at the interior edge, the side walls would be higher than the gable walls at the corner instead of lower, but there will still be an anomaly at the miter. But since you don't have fit walls to objects, none of that would be of any use to you. However, you could join the corners using "capped join" mode, and then you won't have a miter. But there will be an extra vertical line at the corner on the exterior, unless you are viewing in OpenGL or Renderworks and your textures are properly assigned and aligned.
ARM is a modified RISC chip. Patterson and Hennessy just won the Turing award for RISC, and IMHO it's not just Apple wanting greater control, RISC is more efficient.
Bob-H has given the correct procedure. It's a two-step process - copy the plug in to the plug in folder (depending on how your system is set up, you may have to do this for each user), then edit the workspace to load the plug in.
Count me as one who would not like to have a different file format every year. We pay for Service Select to have access to the most up to date and powerful version of the program, with decent tech support. That would not change if there weren't a yearly "version," I'd be happier with service pack upgrades and perhaps a big housecleaning every three years. On the other hand, if VW were thinking about going to a subscription whereby I would have zero VW unless I paid for Service Select every year, I'd have to treat that like I do Autodesk, which has gone to that model. In other words, I would purchase another software tool.
dc, I take your point that it is logistically much easier to update maybe several hundred instances of a program on cloud servers than many thousands in offices around the world. Plus, that sounds like outstanding response to a bug! All the same, we theoretically have the ability to update our desktops - my internet security program does it automatically every day.
Vectorworks 2018 Hogs Application Memory
P Retondo replied to Seth Thomas's topic in General Discussion
Jim, is it really true that VW2018 will use more than 32 Gb RAM when rendering? -
Christiaan, I see your points 6 and 7 as being inherent to a cloud-based system (access from anywhere, easier sharing). Other than that, the rest just speaks to superior software engineering - which I will stipulate the software you like does have, given the high level of your experience. Yes, file management should be made more simple. I'm sure that if file management is better with Onshape, that is due to software, not some personal file management nanny assigned to the project. Updates should be smoother (if NNA could get their engineering together, user control over whether to update would cease to be a necessary thing). The biggest drawbacks in cloud-based are that we lose control of the tools and their management, and that we may be paying more for CAD - if not now, in the future. Good engineering does not come for nothing, and file management, access and server space cannot be free. If the cloud server goes down due to cyber attacks or other problems, all users will be dead in the water. If we are worried about files being pirated, wiped out by hackers, or just lost due to neglect, we will be at the mercy of the corporation to which we have ceded control. That concerns me very much, almost as much as parametric tools starting to dictate a narrow range of design solutions. PS: regarding the point of file security. Correct me if I am wrong, but the project files for a cloud-based CAD system will have to live on the cloud server. My assumption is that the CAD software is loaded on a cloud computer and works with that computer's RAM. Otherwise, every operation and processor request would have to travel over a very small pipeline between your desktop and the cloud. This means your desktop is just operating as a terminal to send commands and receive screen updates. The program is operating in the cloud, the application memory is on RAM on the cloud computer. So every file save is between the cloud computer and the cloud storage server, otherwise we would be waiting forever with every save and that would not work. The only alternative is that the cloud server file is just temporary, requiring that at the beginning and end of work on any CAD file we would have to wait for the entire file to be transferred over the internet. Slow, not really viable. That's why I assume we would have to give up physical custody of our work for this to be practical. BTW, I did check out this scenario for how cloud applications work with AIA Documents tech support, and they confirmed that is exactly how their system operates.
But, Christiaan, is it the cloud or is it software engineering? What is it about being in the cloud that make any software inherently more usable or stable, or whatever? I would argue that better software is better software, regardless of how it is delivered or accessed, and that for my purposes as an architect seeking to have control over the security of my files, my ownership of my files, and my ownership of CAD tools, the cloud is not where I would like to be. The cloud is the place for those who sell time on cloud computers and want to monetize the use of software as a commodity instead of a tool, since we become totally dependent on them and their equipment. In this sense, selling the cloud as a technological solution as opposed to what it really is - a money-making scheme - that is a hype. When you say there is "no pushing in Onshape," I assume that means the document is actually stored on the cloud computer. It has to be for CAD work of any substance, otherwise every save from RAM has to go through the internet connection. That also means - drum roll - that your design documents now live on someone else's computer, subject to whatever insecurities that implies. Hostageware, poor management, shutdowns, going out of business, all outside your control. This is exactly why I no longer use AIA contract document software, all my contracts would have to be in the possession of the AIA and live on their server. Thanks, but no.
I just asked one of my contractors, who is Chinese, about "who is the first to eat the crab." He had never heard of it, so I still don't know what that means!
dc, I think the issue has more to do with engineering standards and corporate practices than it does with how the software is delivered or where it is installed. The cloud is, IMHO, a much-too-hyped magic solution. The big advantage is that you can use your workstation from any internet-connected location the same way computer "terminals" used to be used when we had mainframes. The big disadvantages outweigh that: 1) the user does not control and own the software, totally dependent on the cloud server's security, availability, and you have to pay the rent, and 2) limited bandwidth - which increases your dependence on the cloud server because you have to save files to the server and keep them there instead of on your own computer. We should be very afraid of such a technology model.
Jim, this is not an answer to your question, but I am very interested in experiences with VW2018 which I have paid for but not yet installed because I am afraid of the type of problem you are experiencing!
I've been asking for this forever. Having a script is a good idea, cberg. When I have some free time (i.e., probably never!) I'll look into it. It would be a simple matter of getting the z layer settings from the 2 layers and moving by the difference immediately after pasting in place.
First positive comment I've heard from a veteran user regarding 2018! Could you tease me with just one or two examples?
I have a few, but no more than I have always had. Not a problem with previous versions, so I assume something has changed since the advent of v 2017.
Jim, thanks for that explanation. It goes a long way to know that the engineers are aware of a problem and are working on it.
Hi Jim, to be clear, handling of resources also affects startup delay. I know it's difficult to separate these delays out, but based on the screen hints I am seeing, something on the order of 10-15 seconds to load the resources after activation verification, where the total startup process used to take 15 seconds. v2017. Have you been able to verify this extra processing time with the new resources handling? If not, could you lay this perception to rest? If yes, can you explain why NNA thinks it was advantageous to re-design the resources interface at such a cost?
Hi Jim, with great respect, I see the activation delay and that is a very important thing to fix. But I am talking about issues that are specific to the time it takes for resources to populate, both at startup and when going to the attributes palette. Anything having to do with resources now involves a very noticeable delay. Do you not experience this delay when using v2017 (can't speak to v2018, because even though I have paid for upgrades, we have not installed 2018 due to fear of even greater productivity dings)? Just for example, I click on the attributes palette, click on the fill style button, click on hatches, click on the hatch dropdown list and wait for several seconds while that list populates - it takes so long at first I clicked several times because it didn't seem to be working. Finally get a hatch and apply it - the whole operation taking around 10-12 seconds where it used to take less than 2. PS: You have to test this immediately after startup, because once you have used the attributes palette this way the list has been loaded and persists, reducing the delay
As of v2016, all the resources, crap or not, were loaded on my machine with an SSD in 15 seconds to complete the whole startup cycle. As of v2017, with the new look and handling of resources, time has ballooned for startup and lots of other operations - such as, just assigning a hatch to an object. It is really not acceptable that we pay for poorer performance with supposedly improved software. Can someone from NNA explain why this has happened, and if there is some benefit we should be getting from all these slowdowns?
