  • 61
Streamdeck integration.
Matster
On 12/4/2023 at 11:54 PM, Ben3B said:
Hello I'm on windows, VWX 24, I'm looking for the tea pot SVG
I can't find them, any idea ?
Thanks!!!
There are a ton of usable images of the Utah Teapot online. Does it have to be SVG on the Windows platform?  I’ve used JPG and PNG almost exclusively on mine. (Mac OS)
Edited by scottmoore
Yes waiting to get the "real" one, i use a tea cup I ve found on the net ...
But I m a little bit "straight" and would use the same icone as in VWX ;)
On 9/13/2023 at 6:26 PM, Mark Aceto said:
I'm way more interested in 2023 and earlier 😅
However, I can finally share this (really wish I had better / smaller icons for Projection and Shaded / Wireframe toggles):
@Mark AcetoIf you take the image into the Key Creator Web Dialog, I believe you can scale up/down the individual image on a layer.
On 12/21/2023 at 2:12 PM, The Hamma said:
FYI I was able to create a Stream Deck command to run any command of your choice from the Stream Deck.
I did this by creating a five step multi action using the "F" (Quick Search window) function in Vectorworks.
1. Press the "F" Key
2. Delay 100 Milliseconds
3. Type the name of the command (This example is "scale bar")
4. Delay 250 Milliseconds
5. Press the "Return" key.
Very clever!
Anybody with some fresh stream deck profiles willing to share?
4 hours ago, Wood said:
Very clever!
I am working on building a complete profile for my highly customized Architect workspace. The problem is that my space uses many custom keyboard and stream deck doesn’t make it easy to change a command from a hot key command to a multi action.  It would be better if there was a way to invoke a command in a quicker way than using the  "F" (Quick Search window) function then I would program every function using said quicker way.
Sweet
Reading between the lines, it seems like this accomplishes 2 power moves:
  1. Bypasses the need to create / replace a unique keyboard shortcut in VW or OS for each command
  2. Platform-agnostic across Windows / Mac (see #1 above) so the same SD / profile can be used with multiple computers / workspaces
Am I missing anything?
Yes I think this should be Platform- agnostic but it is slower than the method that I just posted that uses the two plugin scripts which should also be Platform-Agnostic but I have not tested it on a Mac.
16 hours ago, The Hamma said:
Here is my Stream Deck Profile for the Standard Architect Workspace.  I requires that you add the two attached plugins to your workspace and set their shortcuts as shown
This version uses the names of the Commands, Tools or tool indexes rather than shortcuts except for the shortcuts for:
Which it uses to call the plugins and awaits the name of the tool which is sent from Stream Deck
Menu command call (note if there is not a chunk number you must add 00 to the end of every command, if there is a chunk number enter 01 for 1 and 10 for 10)
Tool Name Call
Tool Index call
Edited by The Hamma
  • Love 1
@scottmoore I actually used yours as a starting point for mine, and created a few more commands and I made the keys in Affinity. It is a fun process once you get the hang of it.
Some keys I made by changing the command shortcut in my Workspace, but for a majority of them, I used the power search workflow. I tweaked some of the timings to where they all still work very well.
Once you get a pattern going, it is easy to set up. My setup has 3 "pages". A main functions and two sub folders, one for Spotlight and one for ConnectCAD.
Try it out everyone, and let me know what you think.
My next project is setting up my iPad as a 64 key Stream Deck for an MA3 PC.
VWX2024(MCA).streamDeckProfile.zip
  • Like 4
I installed this profile on my Window machine and none of the commands work but all of the instructions are correct.  It appears the hotkey functions are not interchangable between Windows and Mac.  If I replace the "F" hot key with a "F" it processes half of the command.  I have to replace the "Return" hot key with a "Return" and it processes the entire command.  Not sure why they are different.
Odd....
Ya, I would guess the SD would not interpret the difference between the Windows and Command(Mac) key, but that is easy enough to change for a user in their Workspace.
That hiccup with that Multi Action is weird.
Hey all. Im trying to find more of the tool icons. I have found most of what I need but I am missing a bunch still.
Is there somewhere to easily find all of the 24 icons? Ive tried searching for the vectorworks.vwr but have only found the individual files. Unfortunately not all of the icons im looking for have been found.
On a mac if that helps.
@N.Meyer I created an icon for every tool in the architect workspace that I could not find. I combined them with every icon that I did find in the attached zip file.  Note that I did not name most of my icons but they are in the root folder.  The others may be hard to find. Sometimes you just don't know the name of the icon but it may be hidden in the folders somewhere.  Often times I had to do a visual search.
After looking through this, if you can’t find something specific let us know.
Icons.zip
Edited by The Hamma
