Solid Subtractoin Having Odd Effect on Extrusion
Not sure why that is happening.  I have seen similar when manipulating objects with lots of vertices.  That floral extrude looks to have loads of points, or maybe some overlapping geometry that might mess up in the subtraction.
Perhaps a different approach would work - edit the extrude rather than solid subtraction.
I recommend paste in place a copy of the extrude into a new blank vwx file and test it in the new file:
Dbl Click the extrude to edit its source object (the 2d polygon).
Draw or paste the 2d rectangle onto the 2d poly at location where the box was.
Select both the rectangle and the polygon.
Clip surface & Delete the unwanted rectangular portion.
Exit the extrude.
If that does not work as expected, post the test file to this forum thread so others can test.  Good luck!!
-B
Do you know about editing the clipping part of a clipped polyline like your lattice? If you select the lattice and use Ctrl [ it will allow you to just edit the clipping part. You might try clipping the rectangle there. You'll get a good sense of what's going on with the lattice (eg. how its composed) by doing this as well.
Kevin
@Josh - The lattice conspires to make that clip 2d or subtract solids 3d go bad.  Bottom row:
1.  "voids" are part of the perimeter, rather than holes in a continuous perimeter shape.
2.  There are several stacked points.
One fix is to remove and rebuild the bottom row.
In Top/Plan, my repaired lattice looks OK.  In flyover image, the color fill goes wonky, so there could be other problems.  But extruded version keeps color fill OK.
Modified file has B appended to file name so you can tell them apart.
HTH
-B
Solid_Subtration_and_Clip_Surface_Issue-B.vwx
Edited by Benson Shaw
still thinking about it
Not sure why the screen goes bad but the process is as attached.. If you want to do it as polygons and not extrudes unhitch the extrude from the network then add surface then clip surface and you get the bottom result as a flat surface.
Edited by Alan Woodwell
Benson's observations are correct. It looks like the bottom piece of the lattice was created without the little circles where the points meet. I think those little circles would have prevented the geometry issues. When you use Modify>Edit Polyline (Ctrl or Command [ ) you can see where the geometry is different. VW is getting confused by the overlapping points at the ends of the petals.
Kevin
The highlighted areas in the image are the clipping objects of the polyline.....
58bd8bc634a51_ScreenShot2017-03-06at8_17_55AM.png.5683e0d39fd5879e0dca90560694788b.png
