Rassa12345 Posted November 6, 2015 Share Posted November 6, 2015 (edited) I have an object, a rectangle, that has shared characteristics from other elements but I only want it to exist if certain parameters are met. I linked the rectangle to the other elements that it is sharing its characteristics with and then linked the rectangle to an "if" node at the "true" link. My issue is that even if the "if" node test is false the rectangle still appears. I assume it is because the rectangle shares its characteristics with other elements and that circumvents the "if" node. Is there a way to have the "if" node control the existence of this type of rectangle? The bottom "Wrapper" is the item I referring to. As you can see it is linked to other elements of the script as well as the "if" node. Edited November 6, 2015 by Rassa12345 Quote Link to comment
AlanW Posted November 6, 2015 Share Posted November 6, 2015 Hi, Also have a question on IF. I have a test if A>=B then true, Draw circle, else (False) draw square. Can you show the connections please. If I run it I get both. Sorry for such a Noob Question but hey got to start somewhere. Quote Link to comment
Vectorworks, Inc Employee sbarrett Posted November 6, 2015 Vectorworks, Inc Employee Share Posted November 6, 2015 The If node is a little tricky in this way - it does not negate the true or false input, it only filters the information. For this: "I have a test if A>=B then true, Draw circle, else (False) draw square." For it to work, it would have to draw the square or circle AFTER the if node. If you send a circle into the false input and a square into the true input, it still draws them because they are part of the definition prior to the If node. The way you could do this is if you connected the delete node to the output of the if, that way it would delete whichever object you choose. The best way to use the If node is if you have two values that you want to choose from, not two objects. that was you could send one of two radii to a circle depending on the test - the other value still exists in the definition, but it is just not used to create anything. I hope that explains it! Quote Link to comment
bcd Posted November 6, 2015 Share Posted November 6, 2015 Yes, that's as far as I got. But then recognizing that a circle with r=0 or square with b or h = 0 is not drawn then then using a pair of if statements works: Quote Link to comment
Rassa12345 Posted November 6, 2015 Author Share Posted November 6, 2015 The If node is a little tricky in this way - it does not negate the true or false input, it only filters the information. For this: "I have a test if A>=B then true, Draw circle, else (False) draw square." For it to work, it would have to draw the square or circle AFTER the if node. If you send a circle into the false input and a square into the true input, it still draws them because they are part of the definition prior to the If node. The way you could do this is if you connected the delete node to the output of the if, that way it would delete whichever object you choose. The best way to use the If node is if you have two values that you want to choose from, not two objects. that was you could send one of two radii to a circle depending on the test - the other value still exists in the definition, but it is just not used to create anything. I hope that explains it! That does explain it. Thanks for clarifying. I will try the delete option and see if that works. I look forward to seeing Marionette become more robust! Quote Link to comment
AlanW Posted November 6, 2015 Share Posted November 6, 2015 (edited) Sbarrett, Thanks you have explained it simple that is easily understood. What I have so far it a script that creates a Kitchen cabinet and to set the cabinet width to have a say range from min 600mm to max 1500mm. Max width of doors to be 750mm, so if the cabinet unit width is <=600mm draw 1 door and if > 600mm then draw 2 doors. bcd, Love the Bool at the beginning. This is all about knowing what each of the nodes do so you can use them efficiently. For a non programmer this is like starting to learn a new language. Also it took me a while to figure out that your end result was an object and not a wrapper node. Once I figured out that you had to convert the wrapper node to an object the change was instant with the check box. Thanks again Edited November 6, 2015 by Alan Woodwell Quote Link to comment
bcd Posted November 6, 2015 Share Posted November 6, 2015 (edited) Thanks Edited November 6, 2015 by bcd Quote Link to comment
AlanW Posted November 6, 2015 Share Posted November 6, 2015 (edited) Nice Strike, Mine is probably more like. Edited November 6, 2015 by Alan Woodwell Quote Link to comment
bcd Posted November 7, 2015 Share Posted November 7, 2015 nicely tempered: modesty & courage Quote Link to comment
Nik Posted January 9, 2016 Share Posted January 9, 2016 The delete option works great as long as you have an object on both the true and false inputs. If you have an object only on one of the input nodes you will get error messages. The marionette will work but you'll get a popup error message when it runs. Quote Link to comment
Patrick Winkler Posted January 11, 2016 Share Posted January 11, 2016 Hello Nik, Sorry if I missed something. Why should someone put values of a different type into the if-Node? I hope it helps when you connect the delete-Node direct with the object node like in the attached example. Quote Link to comment
J. Miller Posted January 14, 2016 Share Posted January 14, 2016 Hello, Most of this is making sense, but my question is a little different. I'm using a bool node and "IF" node to allow the user to add an additional object or not. How does on go about drawing an object or NOT. I guess I am looking for an IF THEN statement?? Jeff Quote Link to comment
Nik Posted January 14, 2016 Share Posted January 14, 2016 My issue isn't so much changing an object as it is, adding an object if conditions warrant. Quote Link to comment
AlanW Posted January 14, 2016 Share Posted January 14, 2016 (edited) This is what the IF node does. If one condition is true do X, if false do Y and your test is if the criteria you set for change is met. So if you want to add an object, if condition is true you place it on that side of the node. HTH Edited January 14, 2016 by Alan Woodwell Quote Link to comment
J. Miller Posted January 14, 2016 Share Posted January 14, 2016 ok thanks, Alan, but what do i place for false. It wants to see something, or errors pop up. I don't want to draw anything for false Jeff Quote Link to comment
Nik Posted January 14, 2016 Share Posted January 14, 2016 I would expect that the marionette network in the attached file "Drawsboth" would draw a circle and not a square, when the boolean is true, but it draws both. In order to draw one and not the other I can do one of the following: 1. Create "If" nodes that evaluates to a "0" if my Bool is true and feed that into radius/height. 2. Invert the logic of the boolean and add a delete node to the output Quote Link to comment
AlanW Posted January 14, 2016 Share Posted January 14, 2016 (edited) Hi, You just need to place a delete at the end to delete the other object. Not sure if one of the nodes should be changed so this step is no longer needed. I think the "If" Node should have the delete issue resolved within it and not outside. Maybe someone can look at this and rewrite it. (outside my league) HTH Edited January 15, 2016 by Alan Woodwell Quote Link to comment
Pat Stanford Posted January 15, 2016 Share Posted January 15, 2016 Alan/Nik, Very nice, but I don't think that is what Jeff is looking for. Both of your will alternate between drawing a circle and a square while he is looking to always draw a circle and when Bool is true ALSO drawing the square. I could not figure out a way to do this using the standard nodes, so I hacked together the If and Delete nodes to create a Boolean Delete. I had to do this in Python. But it only took about 4 added lines of code to the Delete node. The Boolean Delete removed the object passed to it when the control signal (test) is true. Quote Link to comment
Vectorworks, Inc Employee sbarrett Posted January 15, 2016 Vectorworks, Inc Employee Share Posted January 15, 2016 Here is another way of making the If node work in the way you want it to without making any alterations to the code. It involves a few extra steps but it only draws the shape you choose and it gives you the output of the single drawn shape. I love using the data nodes - there is so much you can do if you use them together. There is also a definition that draws both object when true and one when false - if you run it as true it gives an error, but only because nothing is going to the delete node. Quote Link to comment
J. Miller Posted January 18, 2016 Share Posted January 18, 2016 hey Pat you are close What i am looking for is: If bool is true draw the square if bool is fals dont draw anything Jeff Quote Link to comment
Vectorworks, Inc Employee sbarrett Posted January 18, 2016 Vectorworks, Inc Employee Share Posted January 18, 2016 Another way to make the If Node work a little better is to tweak the code a little. All you have to do is double click on the node, and change the Marionette.PortIn() values for the true and false inputs from 0 to None. This should make you network work the way you want it to. @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): this = Marionette.Node( 'If' ) this.SetDescription( 'If test is true, pass the value from true otherwise pass the value from false' ) true = Marionette.PortIn( None ) true.SetDescription( "An item" ) false = Marionette.PortIn( None ) false.SetDescription( "An item" ) 1 Quote Link to comment
J. Miller Posted January 19, 2016 Share Posted January 19, 2016 worked great Sarah Thanks again! Jeff Quote Link to comment
Patrick Winkler Posted May 2, 2016 Share Posted May 2, 2016 (edited) Another way to make the If Node work a little better is to tweak the code a little. All you have to do is double click on the node, and change the Marionette.PortIn() values for the true and false inputs from 0 to None. This should make you network work the way you want it to. @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): this = Marionette.Node( 'If' ) this.SetDescription( 'If test is true, pass the value from true otherwise pass the value from false' ) true = Marionette.PortIn( None ) true.SetDescription( "An item" ) false = Marionette.PortIn( None ) false.SetDescription( "An item" ) Unfortunately this solution will also cause an error message to show up (Script Debug Mode is activated in programm settings.) I modified the delete node to prevent it from running with None or zero value: @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): this = Marionette.Node( 'Delete' ) this.SetDescription('Deletes an object.\nNote: Objects to be deleted are saved in a list and are deleted at the end of the network execution. So, there is no risk of referencing an object that no longer exists') obj = Marionette.PortIn( vs.Handle( 0 ) ) obj.SetDescription('The object to delete') def RunNode(self): obj = self.Params.obj.value if (obj): vs.Marionette_DisposeObj (obj) Edited May 2, 2016 by Patrick Winkler Quote Link to comment
Oachl Kini Posted November 16, 2016 Share Posted November 16, 2016 Just ran into the kind of the same Problem as Jeff: I'm new to Marionette and I tried to recreate the stick figure from the python examples in the developers wiki with Marionette. (http://developer.vectorworks.net/index.php/Python_Sample_Point_Object_(complex)) For this example the hair should only be drawn if the User checks a checkbox, so a boolean. But with the if-statement I get an error from my Line Node if the box is unchecked. So I tried a filter with a delete object at the false-items box. But now I get an error from the Delete object Node if the box is checked, because now it gets no input. Now I'm not really comfortable fiddling around with the if Node. So, while modifying the delete node to work without input (or None-input or 0-input) might be an option, I wanted to ask if there is another solution for this in the new version (working with VW2017). On 15.1.2016 at 6:41 PM, sbarrett said: Here is another way of making the If node work in the way you want it to without making any alterations to the code. It involves a few extra steps but it only draws the shape you choose and it gives you the output of the single drawn shape. I love using the data nodes - there is so much you can do if you use them together. There is also a definition that draws both object when true and one when false - if you run it as true it gives an error, but only because nothing is going to the delete node. Also, as I can't see any attachment to this post, there might already be a solution, but I'd like to know it. :-) Quote Link to comment
