J. Miller
Content Count
233 -
Community Reputation
5 NeutralAbout J. Miller
Rank
Journeyman
Personal Information
Occupation
CAD Draftsman
Location
Abingdon, MD
Recent Profile Visitors
I have found that if I split (redraw) the object into multiple pieces like you suggested it seems to work. At least i hope it does ,the dimensions appear to be the same when unfolded and put back together? Thanks bcd Jeff
I am wondering if an object like this can be unfolded. I need to make a pattern to cut this out of vinyl. It is one of a handful of shapes i need to unfold. Been at it for a bit now with no good results Of course it had to be done yesterday. Jeff UnfoldMe.vwx
check the reply from KLinzey I am going to try that option later today BTW Thanks Kevin Jeff
I created a DMX Patch using the VW DMX Patch Menu item. It works great. I want to send this information to Lightwright 6 What fields do i link & not link to LW & VW to keep this information intact. I am overwriting info or its just being ignored, This user U Dimmer, User Address, Universe/Address, Absolute Address, DMX Address is driving me nuts. Screen shots appreciated Thanks, Jeff
It may have something to do with soft shadows. Be sure that item is UN-Checked Jegg
I need to get the Z height of a point load programmatically. It doesn't seem to respond to the normal calls. Any clues? TIA Jeff Miller
I would like to add a calculate-able (is that a word) weight to a few existing symbols i have. They are not lights, but relate to rigging hardware. How does on go about adding a weight to a symbol and assuring the it indeed does attach to the truss structure when adding the symbol. I have tried to select the symbol and "Add point loads at Selection". this adds the weight but does not attach it to the truss structure. Any clues would be helpful Jeff Miller
Truss crosses are a bit odd. and seem to appear on their own sometimes. I have copied objects and (not the truss cross) and pasted into a new drawing only to have the truss cross appear and connected to nothing. I delete the truss crosses, and sometimes they will reappear Jeff Miler
Thanks guys i will try those options Jeff
So what’s the trick to fixing that? delete redraw, restart, etc? i have this problem too Jeff
I need to hang some scenery from a braceworks rig. I know it’s dimension and weight and pick up points. How does one convert this piece so braceworks will recognize it and calculate it into the load report. Do I just use a dead load tool or is it more complicated since it will be picked up by multiple points. i don’t have the ability to determine each point load but it’s a scenic Item weighing about 300 lbs over 4 points. It’s uniform in construction. Thanks, Jeff
The tomcat 2020 blocks are made for “L” “T” & “X” I had to make the pass thu block “<>” to complete the collection. And yes one must put truss at all available sides of the corner block being used. Thanks for the responses. Maybe VW can add this topic to their help files. Jeff
Yes I see that now. Thank you for responding so quickly. Just another Braceworks newbie stumbling along. 🙂 Jeff
So how does one make a square grid of truss or an "L" shaped truss? There has got to be some way to do this. Just because I have a corner block doesn't mean i need all 4 sides. I'm new to this braceworks stuff. Can i edit a TC2020 Corner block somehow to only want to see 1, 2, 3 or 4 sides that want connections. Thanks, Jeff
Is there a trick to getting stock corner blocks to work. I am using the Tomcat TC2020 Truss library. Connecting a bunch of trusses works fine BUT As soon as I add a TC2020 corner block into the mix all I get are errors. No connections, etc, etc. I have a grid that is god awful big and uses a ton of corner blocks. Even in the simplest layout the Tomcat TC2020 corners do not work. It looks like they connect but i don't think they are. I need 20.5" x 20.5" truss and eventually 12" x 12" truss to work in grids. Any Clues? And of course I am on a deadline. Thanks Jeff Miller
