- 4
Followers
0
Integrate 'Extend Nurbs' into the Push/Pull tool + more
Asked by
Kaare Baekgaard
Asked by
Kaare Baekgaard
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
I use the extend nurbs command quite often, but it is a somewhat clumsy element in a workflow.
I wish the I could just point on an edge of a nurbs surface with the push/pull toll - and push/pull it (or at least pull it). The 'move face' mode would correspond to the 'smooth extension' mode of the extend nurbs command and the 'extrude face' mode would correspond to the 'linear extension' mode.
Also I wish I could use the loft tool between existing edges of objects – without first having to extract the curves.
Finally I wish there was two additional modes on the connect/combine tool, where the edges of the two selected nurbs surfaces would extend to the place where the surface planes cross each other. – One mode would be for straight extensions and the other mode for smooth extensions.
I hope these wishes are understandable
