AlanW Posted July 6, 2015 Share Posted July 6, 2015 Hi, Anyone have any videos or information regarding how to use the "Tools/Layer and Class Mapping" process in Vectorworks other than in the VW help section? Thanks Quote Link to comment
Pat Stanford Posted July 7, 2015 Share Posted July 7, 2015 This command allows you to restructure a drawing, by "automatically" changing the names and number of layers and classes in the drawing. What are you hoping it will do? Much easier question to answer than a full blown explanation that might not actually solve your problem. General intent of the command is to be able to merge multiple classes into a lesser number of classes. For instance, an imported DWG with hundreds of classes (0, 1, E2, etc) could be "mapped" down to a much easier to handle number, possibly with a prefix showing where they are coming from. Since once you have the mapping set up you can "save" that mapping, the next time you need to import from that source the classes/layers can be reduced much more easily. Quote Link to comment
AlanW Posted July 7, 2015 Author Share Posted July 7, 2015 Thanks Pat, I guess I am wanting to fully understand the command and what it does then think about the opportunities for using it. I only discovered it today (so much to learn) so as with my philosophy of learning the program to its fullest so that I can be in a position to use it when necessary or the opportunity arises, I was after any any possible tutorials. Thanks Quote Link to comment
zoomer Posted July 7, 2015 Share Posted July 7, 2015 I wish for a layer/class name "search + replace" feature, like the german version of VW has. Quote Link to comment
Jonathan Pickup Posted July 8, 2015 Share Posted July 8, 2015 I have written a manual on layer and class mapping, it's on my web site: http://learn.archoncad.com/2008/06/8543/8543/ Quote Link to comment
AlanW Posted July 8, 2015 Author Share Posted July 8, 2015 Thanks for the response. Lucky I am a subscriber to Mr Jonathon Pickup Quote Link to comment
Mickey Posted July 21, 2015 Share Posted July 21, 2015 Hi, Anyone have any videos or information regarding how to use the "Tools/Layer and Class Mapping" process in Vectorworks other than in the VW help section? OMG I've been dreaming of a tool like this, but I don't seem to have it. I looked it up in VW 2015 Help and read all about it. I'm drooling waiting to use this as I have many files with convoluted ACAD classes, but I don't have this tool. See attached screen grab. I tried changing workspaces. I tried editing my workspace to see if the tool is in a menu but I don't see it anywhere. I have Fundamentals, Spotlight, and Renderworks. Where is this tool? Quote Link to comment
rDesign Posted July 22, 2015 Share Posted July 22, 2015 (edited) I believe you need to have either Designer, Architect or Landmark for the Tools -> Class and Layer Mapping... function. EDIT: See attached Commands_Tools2015 PDF taken from the Help File. It shows that the Class and Layer Mapping tool is only in Designer, Architect or Landmark. EDIT: Removed my reference to LayerMap worksheet function as that is not what is being discussed. Edited July 22, 2015 by rDesign Quote Link to comment
Mickey Posted July 22, 2015 Share Posted July 22, 2015 I believe you need to have either Architect or Landmark for the LayerMap Worksheet function. WHAT? WTF!!!! Why would you bury such a fundamental part of the program in a module? Can anyone from VW Tech comment on this? Quote Link to comment
