Andrew Davies Posted April 24, 2009 Share Posted April 24, 2009 Could the process of cropping a viewport be simplified ? At the moment, the viewport crop object is only visible if the relevant class is visible, both document wide and within the viewport. Don't see why this is the case. Why does the crop object need a class assigning at all - the viewport itself has a class anyway. Quote Link to comment
0 Ray Libby Posted April 24, 2009 Share Posted April 24, 2009 A good wish. In the meantime, always assign your viewport crop object the none class. Quote Link to comment
0 brudgers Posted April 25, 2009 Share Posted April 25, 2009 I give mine a zero thickness to keep them from displaying in the viewport. When I want to select it, I just use a window. Quote Link to comment
0 Ray Libby Posted April 25, 2009 Share Posted April 25, 2009 This is about class visibility, being able to select. If the crop object is in a class that is not visible, you are unable to select or modify by any means. Quote Link to comment
0 brudgers Posted April 25, 2009 Share Posted April 25, 2009 Right, but if you don't want it to be visible, you can control it "by object" rather than "by class." Because there is only one crop object per viewport, "by class" doesn't make a lot of sense (to me). If it's in a class that always visible, then all you have to do is select it with a window...and in the case of a veiwport crop, figuring out where to draw the window is really really easy. Quote Link to comment
0 Jonathan Pickup Posted April 25, 2009 Share Posted April 25, 2009 I wish the crop object was always assigned to the None class, with a tick box on the Object Info palette to hide or show the crop Quote Link to comment
0 brudgers Posted April 25, 2009 Share Posted April 25, 2009 (edited) I wish the crop object was always assigned to the None class, with a tick box on the Object Info palette to hide or show the crop You would still be in the position of having to select it. The logical place to control the display of the crop would be the OIP for the VP. Then you could turn it on and off from the sheet or design layer. And for what its worth, I'm completely against hardcoding anything into a class, let alone hardcoding something else to a class. But as I see it, the OP's issue is more one of workflow than Vectorworks features. Edited April 25, 2009 by brudgers Quote Link to comment
0 Ray Libby Posted April 25, 2009 Share Posted April 25, 2009 I agree, crop objects should automatically be assigned the none class. Quote Link to comment
0 brudgers Posted April 25, 2009 Share Posted April 25, 2009 Why? How would that make the program more flexible? Quote Link to comment
0 Ray Libby Posted April 25, 2009 Share Posted April 25, 2009 There's nothing to be gained in classing a viewport crop object. Being able to assign classes to a crop object only leads to problems. Quote Link to comment
0 islandmon Posted April 26, 2009 Share Posted April 26, 2009 Sometimes I use the Crop as a Frame and sometimes it is just invisible lines.. why not ? As far as I'm concerned the Crop is perfect the way it is ... if it ain't broke ... Quote Link to comment
0 Dieter @ DWorks Posted April 26, 2009 Share Posted April 26, 2009 I agree, crop objects should automatically be assigned the none class. Absolutely not! I have viewports that hasn't turned on the none class, because I only want to show the walls above. My solution is: Just make a seperate class for viewport crops and annotations. And if you make two classes for it, you can show/hide annotations and crops seperately. But please don't use any predefined classes! I really hate them. We should always be able to choose them. Quote Link to comment
0 VincentCuclair Posted April 26, 2009 Share Posted April 26, 2009 Why not just have a check box in the OIP with Show/Hide Viewport Crop Object and while were at it, it would be good if we could just change the Viewport Crop size/shape with its handles and then when you're happy, have another check box in the OIP with Lock Viewport Crop......this would save a lot of (double) clicking and opening dialog windows. Quote Link to comment
0 Ray Libby Posted April 26, 2009 Share Posted April 26, 2009 islandmon, how do classes help with this? Quote Link to comment
0 Jonathan Pickup Posted April 26, 2009 Share Posted April 26, 2009 Sometimes I use the Crop as a Frame and sometimes it is just invisible lines.. why not ? As far as I'm concerned the Crop is perfect the way it is ... if it ain't broke ... It works well for me too, but many people accidently assign the crop to a class, then turn that class off. then they can't find the crop object. Of course, if they assigned the crop object to the correct class, they wouldn't have this problem. Quote Link to comment
0 brudgers Posted April 27, 2009 Share Posted April 27, 2009 It works well for me too, but many people accidently assign the crop to a class, then turn that class off. then they can't find the crop object. Of course, if they assigned the crop object to the correct class, they wouldn't have this problem. Well poorly trained users always have problems. Making the crop default to the none class won't fix that. Quote Link to comment
0 DBLand Posted May 21, 2009 Share Posted May 21, 2009 1. You can turn off annotations separately to crop outline if you assign all annotations to a class from within the edit annotations window. Then select the VP (which must be on a different class) and turn off your annotation class on the VP OIP. Quote Link to comment
0 grant_PD Posted May 21, 2009 Share Posted May 21, 2009 hmmmm... seems a discussion curiously close to my wishlist post as well. I don't think anyone is claiming to be poorly trained, or claiming that they can't assign a class to a crop object. I doubt that it's possible for any object to exist without a class (hence...the NONE class). I think what people are really talking about is the inconsistency of the program structure. NNA has developed a dimension class that can be set to always default to a particular class. They have shown that they can do it, that they can make it controllable. I imagine their original logic was something like: when is a dimension not a dimension? Never. So this particular object should always default to it's particular class. Now, following that logic, when is a crop object not a crop object? When is a viewport not a viewport? Quote Link to comment
0 AndiACD Posted May 22, 2009 Share Posted May 22, 2009 Grant, i love your train of thought. Perhaps you could start a training course for a specific group of people(who shall remain unnamed for now) . . . . Quote Link to comment
0 Pat Stanford Posted May 22, 2009 Share Posted May 22, 2009 The dimension class is vestigial from the Minicad days. Then all dimensions HAD to be in the dimension class. That limitation was removed around VW8 (?). You now have the option of forcing dimensions to use Dimension or any other class of your choosing. If you really want the option to put your viewports in a class it should only be about a three line (alright, probably 30) PIO. Pseudo code below: DoMenuTextByName(CreateViewport); SetClass(LNewObject,'ViewportClass'); Then just edit your workspace to hide the regular Viewport command and add your version. Quote Link to comment
0 Miguel Barrera Posted May 22, 2009 Share Posted May 22, 2009 Brudgers, Rather than using a window to select the zero thickness crop object, it may be easier to just select all (Ctrl+A) since there can only be one object. Quote Link to comment
Andrew Davies
20 answers to this question
