Mike Wright Posted February 6, 2024 Share Posted February 6, 2024 I'm not sure if I'm missing a setting somewhere but I can't get equipment summaries to show a data visualisation on the symbol key like an instrument summary would. Is this option available? Ta VW2024 update3, windows 11 Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted February 6, 2024 Vectorworks, Inc Employee Share Posted February 6, 2024 (edited) Edited February 6, 2024 by Scott C. Parker updated image 1 Quote Link to comment
Wesley Burrows Posted April 11, 2024 Share Posted April 11, 2024 @Scott C. Parker, So with that criteria, the 2D/3D geometry and the Equipment Summary shows the correct Data Vis, however, the Data Vis does NOT work on lighting devices in a schematic view. When I shift the Data Vis criteria to make 2D/3D geometry and the lighting devices in Schematic View work the equipment summary no longer responds to data vis. Is it possible to get it ALL to work at the same time? Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted April 11, 2024 Vectorworks, Inc Employee Share Posted April 11, 2024 Hi @Wesley Burrows I've not played with this. Would you please post a test file so we can explore? Thanks, Sc ott Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted April 15, 2024 Vectorworks, Inc Employee Share Posted April 15, 2024 @Wesley Burrows I wonder if you need two data visualisations with the same colours but one for light info record and one for lighting devices in schematic. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted April 15, 2024 Vectorworks, Inc Employee Share Posted April 15, 2024 2 minutes ago, TomWhiteLight said: I wonder if you need two data visualisations with the same colours but one for light info record and one for lighting devices in schematic. This is what I was going to play with. It should work. 1 Quote Link to comment
Wesley Burrows Posted April 15, 2024 Share Posted April 15, 2024 5 hours ago, Scott C. Parker said: This is what I was going to play with. It should work. So, two visualizations work, however the problem then becomes keeping your colors synced between the two as fixtures change etc. So it works, but isn't ideal. Data Vis with Schematic Views and Equip Summary.vwx Quote Link to comment
tbexon Posted April 27, 2024 Share Posted April 27, 2024 Hi @Scott C. Parker Just to piggy back onto this thread. I'm struggling to recreate this. I have the data vis setup the same as in the above file, pointing to the Light Info Record. I can apply the Data Vis to the fixtures and to the old Instrument Summary object fine, but for some reason they are not applying to a Equipment Summary object. Any suggestions where I'm going wrong? Also for the sake of my OCD, is there an option to align all the symbols along a central line instead of left aligned? Quote Link to comment
nakedeye Posted April 28, 2024 Share Posted April 28, 2024 My route to get a coloured symbol and the same colour in the instrument summery is to just edit the colour of the 2D geometry in the resource browser. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted April 29, 2024 Vectorworks, Inc Employee Share Posted April 29, 2024 On 4/27/2024 at 6:32 PM, tbexon said: Any suggestions where I'm going wrong? Please share a file so I can play. On 4/27/2024 at 6:32 PM, tbexon said: is there an option to align all the symbols along a central line instead of left aligned? What release/build are you working in? Quote Link to comment
tbexon Posted May 1, 2024 Share Posted May 1, 2024 (edited) Hi @Scott C. Parker On 4/29/2024 at 4:13 PM, Scott C. Parker said: What release/build are you working in? 2024 Update 1 File attached! Data Vis Test.vwx Edited May 1, 2024 by tbexon Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted May 1, 2024 Vectorworks, Inc Employee Share Posted May 1, 2024 Update 4.1 is out and offers the centering you're looking for. Once you update to the latest release, please test again and let us know how things go. You may need to update and/or rebuild your summary keys. We fixed an issue with them between updates 3 & 4. Quote Link to comment
tbexon Posted May 1, 2024 Share Posted May 1, 2024 Thanks Scott! that's solved the Data Vis issue, but the symbols still aren't aligning properly. I re inserted the Equipment summary from scratch in case it was a refresh issue. (Now on 2024 Update 5) Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted May 2, 2024 Vectorworks, Inc Employee Share Posted May 2, 2024 @tbexon, Widen the Spotlight Equip Summary Key dialog and use the Alignment column. Let me know if you have issues. 2 Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted May 2, 2024 Vectorworks, Inc Employee Share Posted May 2, 2024 In this example, the strip light is aligned to the left and all others are centered. If the strip were assigned to be centered with the others, it would knock all the others far away from the left border box . 2 Quote Link to comment
Gianni Bertoli Posted December 10, 2024 Share Posted December 10, 2024 On 2/6/2024 at 3:27 PM, Scott C. Parker said: Hi i retake this post because I can make it worked. I do have this set up properly and I see in the draw the right data vis but I cant' place it in the equipment summary. Working in VWX 2025 Update1 Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted December 12, 2024 Vectorworks, Inc Employee Share Posted December 12, 2024 On 12/10/2024 at 3:38 PM, Gianni Bertoli said: but I cant' place it in the equipment summary. Working in VWX 2025 Update1 Would you please install update 2.1 and then try again. If you're still having trouble, please post a file for us to test. Thanks, Scott Quote Link to comment
