531 -
Calendar
Everything posted by TomWhiteLight
MVR export always sets fixture beam and field angle to 25deg
TomWhiteLight replied to Richard1's topic in Entertainment
What are you exporting to? A console? You don't need to swap any fixtures out, simply right click a lighting device and choose 'select devices by instrument type' from the contextual menu, Then assign the GDTF file from the OIP. I can do this in less than 5 clicks. -
You just need to assign the correct fixture mode prior to export, you can do this with 3 clicks. Can you post the file? -
Attaching swivel clamps to lighting pipes
TomWhiteLight replied to Sam Thomas's topic in Entertainment
You can use insert connection (as symbol) or you can attach the truss record to the clips. -
Try this file. Insert Connection as symbol.vwx Insert Connection as symbol.vwx -
Architect is really just a different toolset. Spotlight has the same wall, door, slab and window tools. To get high quality renders you should be considering the following... Textures - You can create your own textures and edit the defaults Render Styles - You can create your own render styles and are not just limited to out of the box renders. Lighting - You can use Spotlight lighting devices, light objects, IES lights, HDRI backgrounds, light emitting textures. Camera - You can create viewports with the renderworks camera tool that can include, bloom, exposure and depth of field effects. All of this will only look good with a good render style rendered out on a sheet layer with a high enough DPI setting. Your image looks like it might be rendered on the design layer in a shaded render style. To improve the shaded render mode you can select shaded options from the render dropdown.
Question about visualizing object info
TomWhiteLight replied to Tina le Roux's topic in Entertainment
"How do I see the object info (eg: colour and dimmer number) on the lighting symbols i have drawn on my plan? " I think if they are displaying this information in the OIP then the lighting device plugin has been used to insert the symbol. You will need to create a label legend and then assign it to the lighting devices. 39mins into this video... https://university.vectorworks.net/mod/scorm/player.php?a=47¤torg=articulate_rise&scoid=94 -
Vision 'No Ambient light"
TomWhiteLight replied to Carl Burnett's topic in Vision and Previsualization
Hi Carl If you select the root folder from the scene graph you should be able to adjust the ambient light. I think the Ambient light settings will be however Vision was left. The ambient light is not exported. -
Cable following several consecutive cable paths - VW crashing
TomWhiteLight replied to Jake124's topic in Entertainment
Interesting that I cant get a crash on my mac, if you contact tech support tell them this might be windows specific. -
(Edit) Just seen, Jesse's message, A repair might fix the cable path tool. -
Hi Jake, I have downloaded the file and created many cables as per your instruction and I cannot replicate the crash. 1. What graphics card do you have? There may be a number of things causing the issue, you mentioned an old file and whilst you have new objects it might be worth updating the plugins in the file, tools - utilities - update plugin objects. Also are you running 2022 SP3? We fixed a bunch of stuff with cable tools in this service pack. When you installed 2022 did you instal into a new folder or did you overwrite/merge? It might be worth repairing your user folder which is an advanced option inside the Vectorworks Updater program/application which you will find inside your program files in the Vectorworks folder. If this doesn't resolve it please contact tech support. -
How to remove a truss pick-up symbol from a hoist?
TomWhiteLight replied to Mark Aceto's topic in Braceworks
Have you tried replacing with a completely new hoist? I am having the same issue, once you select a symbol I can't find a way to go back without re-inserting the hoist. -
Hi phil you could always obtain a subscription license for 30 days? The straight truss tool in Spotlight will probably work well for you. Or your truss object can probably just be simplified. Edit the symbol (3D) and run an add solids command to simplify geometry, you could also set curved geometry to med or low in the render style. the Spotlight workspace would be useful if you wanted to connect other pieces of truss and add lights etc.
standards vs template files, what is the difference?
TomWhiteLight replied to grant_PD's topic in General Discussion
You can pull in the VW-Auto generated classes by creating a new class in organisation and choosing the relevant file from the list. Interestingly you can save your own file in this list for pulling in your own classes as and when you need them. -
@hollister design Studio Just FYI your vectorworks settings are backed up in your user folder. I switch between machines so having a shared user folder means that even when opening a new install I have all of my prefs/settings everything as I like them. I think saved settings is also a good enhancement request. best wishes Tom W
Hi Charlie, can you post or DM the file please? thanks.
I Agree Russ, I will add this to the feature request.
You could make them a hanging position? As far as I am aware only connecting truss items can have the same truss system name. The other thing to bear in mind is you can always ungroup a hanging position and then make it again if you find that workflow restrictive.
Why have you got the sockets in the rack 3d layout? The sockets/devices should be on a separate layer? If you want to show 3d racks on top of devices and schematics combined somehow then i would use 2 separate viewports one on top of the other.
I spotted this in a training session the other day. It has been reported as a bug. For now copy and then rejoin, apologies for the extra step required, a fix is being worked on.
hmmmmm the only way I have been able to do this is to attach a relevant record to the symbol and then insert it with an appropriate plug in tool. Then I can 'Tag' it with the Equipment Item Tool. Not very elegant but it does work. Further conversations to be had internally about this. Many thanks. Tom W
Yes, The equipment item itself can have 'Use symbol' checked and then a symbol can be selected from the resource manager. Did that answer your question?
"I wonder also if it is possible to remove the panel text (CTP_xxx) in Rack 3D Layout like it is in Rack Elevation?" This won't show up in a section viewport provided Planar objects is unchecked in the viewport settings on the object info palate.
Spoke with ETC, The PC version is ready but they have had some issues with Mac OS (Not Vectorworks). They are working on this at the moment and will post both platform versions once ready.
Lighting Accessory Alignment and Changing Device type 2022
TomWhiteLight replied to Patrick Schulze's topic in Entertainment
You shouldn't need the workaround too much longer and symbols are unaffected. This is being worked on currently. In terms of more than one accessory this still works (Eg Scroller top-hat) The accessory tool knows that you are effectively mounting an accessory on an accessory. I will keep you updated.
