53 -
Calendar
Everything posted by tbexon
Is it possible for VS to get the structural units of a .vwx file?
tbexon replied to Sam Jones's topic in Vectorscript
Resurrecting this topic, as I this has just answered my own question, though I think i've spotted a potential error Developer Preference Wiki page. Structural Mass units the Preference selector is listed as 9821, however from what I can tell it should actually be 6821. 9821 returns 0 every time, whereas 6821 returns the expected results. Not sure who to poke about this? -
Thanks Vlado, your suggested method worked great! Cheers Tom
Hi Konstantin Sorry I should have Explained my issue a bit better, when I get a checkbox using the GetRField Command, I then have to compare it to the localized string for True. I do this using the below function: def check_locallised_bool(objectHandle,objectName,Field): localized_True_Bool = vs.EvalStr(vs.Handle(0), "1=1") # Gets Localised True Bool boolraw = vs.GetRField(objectHandle, objectName, Field) # Gets the Raw Bool result if boolraw == localized_True_Bool: # If raw string value is equal to localized version of True localbool = True else: # If raw string value is NOT equal to localized version of True localbool = False return localbool At the moment because in 2021, and according to the Developer page EvalStr returns a string so I am doing a string comparison, to compare the Result of the GetRField to the what I have established to being the String value for True in whatever Language the particular VW user is using. In 2022 EvalStr has started returning a Boolean rather than a string, meaning that a String comparison will always return False regardless. My question is whether this is an intended change or a bug? E.g Do I now need to change the logic to instead compare a Boolean result? Cheers Tom
Hello All Some potential 2022 funkyness. I use the EvalStr function to get the localized string for "True" to then use this to compare to the results from Checkboxes using GetRField. (For more information on the method/reasoning see the below thread where @JBenghiatvery kindly showed me this method in the first place) Since migrating my plug ins to VW2022 I have noticed that EvalStr is now returning a boolean not a string, and thus causing all my comparisons to fail. localized_True_Bool = vs.EvalStr(vs.Handle(0), "1=1") # Gets Localised True Bool vs.AlrtDialog(str(type(localized_True_Bool))) I have tried the above test script in both 2021 and 2022. in 2021 it returns the Expected results of the String "True", however in 2022 it returns a Boolean of True. My questions are: A) Can anyone else replicate this and get the same results? B) Is this working as intended, or a bug? I can't see anything on the Function Reference suggesting that this has been changed in 2022, however maybe @Vlado or @K.Lalkovskimight be able to shed some light? Thanks in advance!
BuildResourceListN: Accessing drawings of earlier VW Versions
tbexon replied to tbexon's topic in Python Scripting
Fair enough! -
migrating plugins to a new version of VW
tbexon replied to Jayme McColgan's topic in Python Scripting
Thanks! That makes sense! -
Hello All I'm pretty sure I know the answer to this already... BUT is there anyway BuildResourceListN (or any of the similar BuildResource command) can access a VW drawing of an earlier version? (e.g Active Drawing is in 2022, and target drawing is 2021) Everytime I try this it just fails to import anything. Which I suppose makes sense, but I was hoping for the sake of cross version plug-in compatibility there may be a solution (other than the obvious convert the target drawing to the required version)? Thanks in Advance!
Following on from this, a question about the actual plug in files themselves (VSM,VSO etc). Should these be backwards compatible with previous VW versions? Or do I need to distribute them in the oldest version I want to support and then when the user first runs the command it will automatically update it to the latest version? -
Thanks Josh, When you say the Data Folder do you mean /Plug-ins/Data or /Plug-ins/Common/Data? Given that vs.GetFolderPath() has an attribute for Common/Data but not /Data I should probably use the Common folder?
So I was doing some bug hunting within one of my plug ins, and I seem to be getting some unexpected results from the vs.FindFileInPluginFolder() function. I'm using the function to retrieve the filepath for a file within my plug ins folder, which works absolutely fine. Where I'm running into problems is when I'm trying to handle a situation where said file does NOT exist... Below is the test code i'm using: import vs ok,path = vs.FindFileInPluginFolder('FileName.ini') if ok: # If File Exists vs.AlrtDialog("ok") else: # If File Does NOT Exist vs.AlrtDialog("no") The problem I seem to be running into is that the ok Boolean keeps returning True even when the file is definitely not present within the Plug Ins folder. First I thought it was still just cached in VW memory somewhere, so tried the old restarting VW trick. Same result. Eventually I noticed that I had another File called "FileName.vso" in the plug ins folder. a bit of experimentation later yielded these results: When FileName.ini is NOT present within Plug Ins Folder, but FileName.vso IS present: FindFileInPluginFolder('FileName.ini') Returns True FindFileInPluginFolder('RandomName.ini') Returns False FindFileInPluginFolder('FileName.randomfileextension') Returns True So from this it would suggest to me that FindFilePluginFolder command ignores file extensions and just looks for the File Name. Is this working as intended? The Function reference does say it searches for File Name, but then the example further down has an extension attached to it, and I believe it's fairly common practice within most filename/path related programming functions to take the extension into account? If this is working as intended does anyone have a nice workaround for dealing with same file names but different extensions. I was thinking I could probably do something with vs.GetFolderPath(-2) and some os.path commands... I realize the simplest solution is just to make sure every file has a unique name, which is probably what i'll end up doing, but thought i'd see if anyone has any helpful insights before I go digging through all my code for every reference to this particular file...
I thought as much, are you aware of any handy guide or helpful threads that may point me in the right direction? (I can't say i've delved too far into the SDK yet)
Thanks Yasen, that makes sense. Quick follow up question, is there a way (via Vectorscript) to add parameters to the Lighting Device Parameter worksheet?
Thanks Pat!
I have not seen the notes, do you have a link to them? I had a search on developer.vectorworks.com for them but it doesn't seem to return any results? I think what i've discovered is that using Circles as my testing object, was a poor choice, from what I can gather FindObjAtPt_Create will only return a circle object if the radius intersects with perimeter of said object. Luckily with both PIOs and Rectangles (which are the two main object types i'm interested in right now) the function does return any part of the object that is within the radius.
Thanks Josh I've been having a play with FindObjAtPt_Create, and I'm struggling to understand how the radius parameters works. I've drawn a circle with a radius of 20000mm, and placed a number of objects within it and outside (see below image), however the results I'm getting are not as expected. If I set the functions radius to 20000 it still picks up objects slightly out of that radius, for instance the object with the red circle around it gets picked up even though the distance from centre (which is the location i'm selecting each time for the starting co ordinates) is 22608. Strangely even though it's picking up objects further away than the overall Circle, it's not picking the containing circle itself... Also from what I can tell I need to set the radius large enough to encompass the entire object for it to be included in the list. I've adapted the code from the example on the wiki as below: import vs def PickPointCallback(pt): startContainer = vs.Handle(); list = vs.FindObjAtPt_Create(startContainer, 1, 0, pt[0], pt[1], 20000) cnt = vs.FindObjAtPt_GetCount(list) vs.AlrtDialog("Initial Co ords: "+str(pt[0])+ ' '+str(pt[1])) for i in range(cnt): hObj = vs.FindObjAtPt_GetObj( list, i ) x2,y2 = vs.HCenter(hObj) d = vs.Distance(pt[0], pt[1], x2, y2) vs.AlrtDialog( 'Index: ' + str(i) + ' Obj Type: ' + str(vs.GetTypeN(hObj)) + ' Dist: '+str(d) ) vs.FindObjAtPt_Delete( list ) vs.GetPt( PickPointCallback )
Hi All Apologies if this has been covered somewhere else, though I'm struggling to find any similar topics, could just be i'm not using the right terminology. I'm trying to recreate the functionality similar to that of Spotlight Hanging Positions and their ability to automatically assign Positions to Fixtures that overlap with the HP. e.g: I want to have a "base" PIO and when I insert a different PIO (Say PIO 2) into the drawing, PIO 2 calculates if it overlaps with any "Base" PIO's and if so queries said "Base" object and retrieves some information from it. The bit I'm struggling with is how to go about working out what objects overlap with said PIO 2. I suppose I could get PIO 2's bounding box co ords and then somehow query if there are any other objects within those same Coordinates. But I though I'd ask if anyone has any better ideas before I go down this route? Thanks In advance!
So I I go about this a slightly different way. I'm not saying it's the correct way, or that there aren't better ways, but it atleast works for me! To get a Lighting Device parameter I simply do a GetRField() command on the objects 'Lighting Device' Parametric Record (which as far as i'm aware is attached to all Spotlight Lighting Devices) I did a test comparing both methods, and got the same results as you with LDevice_GetParamStr not returning Inst Type, however querying the record via GetRField did return the correct results. I also confirmed that LDevice_GetParamStr does work on some fields (such as Position). (Apologies it's written in Python Script rather than Vectorscript, but the results should be the same!) import vs field = 'Inst Type' handle = vs.FSActLayer() param = vs.LDevice_GetParamStr(handle, 0, -1, field) vs.AlrtDialog("Param: {}".format(param)) val = vs.GetRField(handle, 'Lighting Device', field) vs.AlrtDialog("Rec Val: {}".format(str(val))) It is strange that LDevice_GetParamStr doesn't return certain field (and some fairly critical fields one could argue) could this be a potential bug? @JBenghiat or @K.Lalkovski Have you come across this at all?
Ok cool so i can use vs.EvalStr(vs.Handle(0), 1=1) to get the localized string for True and then just compare that to the results from the records?
So I have an event enabled PIO with a couple of Boolean parameters. Up until now I've been using the below to get the parameter's current state by converting the string to bool, as GetRField returns strings, which I thought was fine. show_weight_bool = strtobool(vs.GetRField(objectHand, objectName, "Show Weight")) HOWEVER An unexpected bug has come up, from someone who tried this plug in on a non english version of Vectorworks (it was German in this particular instance). The error thrown from the strtobool function, was: ValueError: invalid truth value 'wahr' From what I can gather, the GetRField seems to be returning the localized value for the checkbox (in this instance 'wahr' which I'm given to understand from a quick google means True), rather than, as I was hoping just a pythonic True, but in string form. Firstly is this working as intended? I presume so as it would make sense that if you were extracting the string you would want said string to be in the localized language rather than always in english... SO does anyone have any clever ways around this? I've been hunting through the Function Reference but nothing obvious has jumped out at me, I was hoping it might be as simple as there was a vs.GetRBool or something similar that returns a BOOLEAN value, but so far I can't find it (I'm certainly not saying it's not there, just that I have not been able to locate it!) I'm hoping there's a super obvious answer that I'm just missing here!
val = vs.GetLBHeaderTextWidth('Some Text', False) vs.Message(val) I just tried this on win10 in VW 2021 SP2 (574483) 64 bit and it crashed my VW straight away.
2021 Import Errors for External Python Packages
I'm running Windows @domC Following you're suggested process, I got the same results. Strangely when I look at the environment paths within the VW Python environment, using sys.path(), "Python Externals" is in there. I'm still having issues with my specific package (pyOpenSSL) DLL load failed while importing _openssl: The specified module could not be found. If I try running with a clean 3.8 interpreter outside of VW it runs fine, same as within 2020. -
There is a work around. Rather than writing the script within the Plug in script itself write it in a YourScriptName.py file located in the same directory as the .vsm file within you're plug in folder. Then, within the Plug In Script, you just need to import the other script: import YourScriptName The .py File is still easily read so the next step, when you're ready to encrypt and distribute said plugin, is to swap the .py for the compiled python file( .pyc), which is located within the "__pycache__" folder of whatever directory the .py file is stored in. (for more info on .pyc files check out this) As long as you put the .pyc in the exact same location as where the .py was, it should function exactly the same. This still isn't perfect. Compiled files can still be de compiled but this requires a much higher level of knowledge than simply opening in a text editor! For more general info on encrypting python plug ins check out this thread
So I just moved all my plugins across to VW 2021, and I'm now getting Import Errors for Plug ins that use the External Package PyOpenSSL. The error i'm getting is: DLL load failed while importing _openssl: The specified module could not be found. I've tried both deleting and reinstalling PyOpenSSL via VerifyOrGetLib, aswell as simply copying the working "Python Externals" from 2020 Plug in folder, neither seems to solve the issue. Pip does seem to be successfully installing PyOpenSSL, with the most up to date versions of it's dependents. I'm aware that with 2021 the Python distribution has been upgraded to 3.8, so I'm wondering if something to do with that could be causing this? Checking the docs here it is compatible with 3.5+ I don't believe it's an issue with the package itself as if I install it, and run from my local copy of Python 3.8 via IDLE it imports fine. Any thoughts would be greatly appreciated! This is rather where my knowledge reaches it's limit!
So from my understanding the when you install the ZIP file it copies all the contents of the Zip FIle into the Users Plug in folder, so could you not package the Rource file within the .Zip then use vs.GetFolderPath() to get the users plug in folder, aswell as Library Folder and use shutil.move to move them from plugins folder to required folder. import shutil import os import vs def manualPackageInstall(foldername): shutil.move(os.path.join(vs.GetFolderPath(-2) , foldername ), # Path to Folder to move in plugin Folder os.path.join(vs.GetFolderPath(-13) , foldername)) # Path to Libraries in User Folder Something like that?
I know this has been discussed in several threads before, but after extensive reading and experimenting I'm still clearly missing something. I'm trying to get the handle for a user selected object within an event enabled Plug in Tool. e.g User clicks button in OIP -> Highlight mode is turned on and user clicks on desired object -> Handle is returned and code continues onwards. I've created the event enabled object, and added the button to the OIP fine, and used TrackObjectN() to allow highlighting of only relevant objects. The issue I'm running into is actually getting the handle of the object. I understand that TrackObjectN is only highlighting, and not a selection mode, but from my reading of the wiki for TrackObjectN: def vs.TrackObjectN(traverseType, callback): return (outObj, p) It should return the handle and Co Ords whenever the user mouses over or clicks an object that relates to the criteria. e.g if the last action is a click on the desired object it should return that handle, or atleast it's co ordinates from which I could then use PickObject to get the handle. In reality when I try: outObj , p = vs.TrackObjectN(0, trackObjCallback) It throws a TypeError 'NoneType' object is not iterable. Given that when I try: vs.TrackObjectN(0,trackObjCallback) It functions as expected, but without returning any handle or co ordinates i'm guessing either i'm using this wrong or it doesn't actually return such information. I'm wondering if I need to try using vstGetEventInfo to look for a mouse button click and then capture the mouse's current Co Ordinates, however after searching "MiniCadHookIntf.h" I couldn't obviously see any obvious constant for a mouse click. TL/DR I'm trying to capture a handle for a user selected object, within a event enabled object and have clearly missed a step somewhere! Any help or nudges in the right direction would be greatly appreciated! Relevant parts of current code pasted below: import vs def makeOIP(): link_pos_button_id = 1234 # User Button Id theEvent, theEventData = vs.vsoGetEventInfo() # Gets Object Event info if theEvent == tb.Constants.kObjOnInitXProperties: # If the event is the initialisation of the object ok = vs.SetObjPropVS(tb.Constants.kObjXPropPreference, True) # Allows for creation of custom OIP?????? ok = vs.SetObjPropVS(tb.Constants.kObjXPropHasUIOverride, True) # Custom OIP Overrides standard UI vs.vsoInsertAllParams() # Inserts all Parameters into OIP displayString = "Link to HP" # text for button result = vs.vsoAppendWidget(tb.Constants.kWidgetButton,link_pos_button_id,displayString,doesNothing()) # Add Button to OIP if theEvent == tb.Constants.kObjOnObjectUIButtonHit: # If the event is a button being pressed if theEventData == link_pos_button_id: link_to_hp() # Function to run to allow user to select object. if theEvent == tb.Constants.kResetEventID: # If Object is reset # Code to run on object reset def doesNothing(): pass def trackObjCallback(h,x,y): HPHandle = vs.PickObject((x,y)) if vs.GetTypeN(h) == 86: return True def link_to_hp(): vs.TrackObjectN(0, trackObjCallback) outAction, outMessage1, outMessage2 = vs.vstGetEventInfo() #vs.Message(str(outObj)) makeOIP()
