Another skylight insertion question
hollister design Studio
What am I not doing correctly?
  • I imported a Velux skylight symbol.
  • Selected the roof class and layer as active.
  • Double clicked the skylight in the resource manager (in the 'selected file' mode.)
  • Hovered over the roof until it was highlighted.
  • Clicked and then clicked to set the angle.
The skylight just sits perpendicular to the roof with no cutout.
Also tried from Top/Plan but the roof will not highlight.
Video capture:
5 answers to this question
That particular symbol doesn't have 'Insert in Walls' enabled. When this is disabled it won't let you insert it into a Roof using the Symbol Insertion Tool but bizarrely you can insert it if you drag it onto the Roof from the RM. So either drag it from the RM or enable 'Insert in Walls' in the Symbol Options + then you can insert it using the Symbol Insertion Tool as you're trying to do in your movie. Crazy I know...
  • Like 4
