I get an error message every time I quit Vectorworks Architect 2023 or 2024 in MacOS Sonoma
doug shaffer
I can't seem to find anyone else on the forum that's dealing with this issue.  Like it says in the subject line, every time I quit VWA 2023 or 2024 I get an error message saying "Vectorworks 202X quit unexpectedly."  I have not noticed that there's any file damage when re-opening the files but it concerns me.  Is this a bug in VW or Sonoma?
I have all the latest updates for VW and Sonoma and I'm using a 2019 MacBook Pro.
I can copy / paste the "Problem Details and System Configuration" if that would be helpful.
Thanks for any help you can offer -
Doug
15 answers to this question
Since you are on a 2019 machine, I am assuming that VW was already installed when you upgraded the OS.
Have you tried running the VW Updater app in the application folder? Start by choosing the Advanced Option menu on the right and choose Repair and see if that fixes the problem.  If it doesn't, then I would suggest Uninstalling VW and reinstalling. No reason that should work, but there are often mysterious reasons computers don't do what we expect.
HTH
Hi,
I noticed the same for me.
After my accidental update to Sonoma (I only wanted to download it, but
Sonoma installed it itself= my fault), I have problems by quitting
Vectorworks, even with the new Sonoma update 14.1.
Yesterday I installed VW 2024, (release day in Germany)
and I also got crashes by quitting VW.
So VW 2024 got installed after the migration to Sonoma.
Vectorworks is the one and only software with crashes like this
after my update to Sonoma!
Things I tried:
- permission reset via Terminal
- Repair with Vectorworks Updater
- rebuild of the user-folder
Things that I think could still lead to problems for me (completely subjective)
- my User in macOS (maybe I try to a new user)
- my custom Workspace setting
Best would be to by a new Mac! 🤣
Greetings from Germany
Tobi
HTH
Thanks Pat -
I tried the VW Updater "Repair" function to no avail and uninstalling and reinstalling didn't fix the problem either.  As long as it's not corrupting my files or hurting anything else on my computer I'm not too worried about it.  Just a little concerned.
Doug
You start with one of the Default Workspaces that ship with VW and add/move commands and tools and add/edit the assigned shortcuts to match your desired configuration.
To make it slightly easier to remember what you have, you can go to Tools:Workspaces:Workspaces... , select your custom workspace and then click the Export button and you will get a Text version that lists the commands in each menu, the tools in each palette, and the shortcuts that are associated with them.
  • Like 3
Well, I deleted all of my non-default workspaces and added tools and quick keys as I desire to the default "Architect" workspace but that didn't fix the problem.  Any other thoughts?  Otherwise, I'll wait until VW Update 2 to see if that changes anything.
Thanks -
Doug
26 minutes ago, doug shaffer said:
It still crashes.
FYI, I received a message from Juan P. and sent him my serial number and crash report.  I'll let you know what he says.
Thanks
Also, FYI, I tried opening Vectorworks without opening a file but I still get the "Vectorworks 202X quit unexpectedly." message when quitting the application.
