MartinBlomberg Posted August 16, 2023 Share Posted August 16, 2023 Hi, I must have forgotten something important because I can't fillet these polylines' edges. Am I stupid or am I missing something? File for download below. Thanks! Untitled 1.vwx Quote Link to comment
0 Benson Shaw Posted August 16, 2023 Share Posted August 16, 2023 The fillet tool has a VERY small value (13) in this file. It is filleting, but not discernible except at huge zoom where the graphics are, um, confusing. And, one of the internal polylines is not closed. That open corner does not fillet, until closed. HTH -B 2 Quote Link to comment
0 Tom W. Posted August 17, 2023 Share Posted August 17, 2023 I never knew you could do this! Edit a Polyline's 'history'. Although it only seems to let you do so much before locking you out... Good to know though - thank you! 2 Quote Link to comment
0 MartinBlomberg Posted August 17, 2023 Author Share Posted August 17, 2023 Thanks! It still doesn't work on my end. I've set the object to "Closed" and connected all lines. I've also changed the fillet radius to several different sizes (I even tried that before without any success). I must be missing something really obvious here... Quote Link to comment
0 DBruhnke Posted August 17, 2023 Share Posted August 17, 2023 1 hour ago, MartinBlomberg said: I must be missing something really obvious here... When double clicking on the shape with the fillet tool, the radius can't be larger than half the distance of the smallest side. And for some reason, this shape shows in OIP as closed, but there is still one side that appears to not be closed. HTH 1 Quote Link to comment
0 MartinBlomberg Posted August 17, 2023 Author Share Posted August 17, 2023 @DBruhnke That made sense! Now it works! Thanks!! 1 Quote Link to comment
0 DBruhnke Posted August 17, 2023 Share Posted August 17, 2023 @MartinBlomberg Glad there was a solution. Have had this issue in the past where one corner is actually made up of 2 points so close together that it appears as a single handle. Have had to clip the poly into pieces to troubleshoot the offending side. Keep clipping to smaller and smaller pieces until the culprit is found. 2 Quote Link to comment
0 Kevin McAllister Posted August 17, 2023 Share Posted August 17, 2023 12 hours ago, Tom W. said: I never knew you could do this! Edit a Polyline's 'history'. Although it only seems to let you do so much before locking you out... Good to know though - thank you! Yes, Command [ on a Mac. I use it all the time. Something everyone should know how to do! Kevin Quote Link to comment
0 Tom W. Posted August 17, 2023 Share Posted August 17, 2023 Well I know Cmd-[ is the shortcut to edit all sorts of things, just never knew Polylines was one of them! 1 Quote Link to comment
0 Benson Shaw Posted August 17, 2023 Share Posted August 17, 2023 6 hours ago, DBruhnke said: this shape shows in OIP as closed, but there is still one side that appears to not be closed. The container/perimeter object OIP can show Closed even when the internal polys are not closed. Apply that Cmd[ shortcut to access/edit the internals. -B 2 Quote Link to comment
MartinBlomberg
Hi,
Thanks!
Untitled 1.vwx
9 answers to this question
