Content Count
94 -
Community Reputation
12 GoodAbout MartinBlomberg
Rank
Apprentice
Personal Information
Occupation
Production coordinator
Homepage
www.handlebar.se, www.birdleg.se
Hobbies
Leatherwork and off grid living
Location
Sweden
Recent Profile Visitors
323 profile views
EDIT: WRONG FORUM - MOVED TO "TROUBLESHOOTING". Sorry!
Hi, 1. Why is it that 2D dwgs are super slow in VW when they are quite easy to handle in any other CAD software? How can I make them work better in VW? When I try to move around an imported (or referenced, tried both) dwg it takes seconds before it moves or anything happens. And it's a blank VW-document which has no other files in it. The dwg isn't too complicated and works super smooth in softwares like AutoCAD. 2. When I have made a crop of parts of the original dwg I want to use to make my 3D drawing, the crop doesn't "stick" to the dwg. I've changed the actual crop from Screen to Layer but problem stays. Hope this make sense. I have a drawing which have both section and plan view in the same dwg, and just want to split them apart so I can "stand" the section view next to the plan view. Just like Make Doubleday does in this video. Please let me know your thoughts on this 😃 Thanks! // martin
Hi, 1. Why is it that 2D dwgs are super slow in VW when they are quite easy to handle in any other CAD software? When I try to move around an imported (or referenced) dwg it takes seconds before it moves or anything happens. And it's a blank document which no other files in it. The dwg isn't too complicated and works super smooth in softwares like AutoCAD. 2. When I have made a crop of parts of the original dwg I want to use to make my 3D drawing, the crop doesn't "stick" to the dwg. I've changed the actual crop from Screen to Layer but problem stays. Hope this make sense. I have a drawing which have both section and plan view in the same dwg, and just want to split them apart so I can "stand" the section view next to the plan view. Just like Make Doubleday does in this video. Please let me know your thoughts on this 😃 Thanks! // martin
Vectorworks User Interface Overhaul
MartinBlomberg replied to Thomas Wagensommerer's question in Wishlist - Feature and Content Requests
That sounds nice! So, what windows do you have open? Would you mind share a screenshot? Just for inspiration 😃 -
Hah, yeah, I kinda' agree. I have a history in AutoCAD and the difference is huge. Whenever I open up VW I somewhat feel a bit ashamed of the UI. -
Hi, Just a 2021 update: how is this topic moving along? I'm looking forward to the day when VW looks, and feels, like a "real" professional software. Even though it's been 4 years since original post, and I've only used VW for about a year, I feel like the UI needs a serious update. What are your thoughts today? 😃 Take care all! -
By the way, do you understand why... 1. There are so many classes and layers still left in the "Lights only" file? They remain even though I've purged several times. 2. Why the single trusses act different then the box trusses in terms of looks? Thanks!
- 11 replies
- vision
- vision2021
(and 1 more)
Tagged with:
That's good news, great! So, the current version isn't SP3? Looking forward! Thank you!
- 11 replies
- vision
- vision2021
(and 1 more)
Tagged with:
Here's a link to a Google Drive folder where both my VW files are. What I can't understand, as well, is why the lighting, LED and all rigging is larger then the actual venue. https://drive.google.com/drive/folders/1jHk6cjCGY-g7SoKmjWKwS0VO9NVcHviE?usp=sharing Thanks friend! 😃
- 11 replies
- 1
- vision
- vision2021
(and 1 more)
Tagged with:
Hm, I've tried to update the Geoimage several times but no luck. This whole feature seems quite buggy to me. Thanks for checking! 😃
Here are the two files. One with the venue and one with only the lighting devices and a LED screen. This is super weird. LIGHTS V1.mvr Partille arena Vision 2.mvr
- 11 replies
- 1
- vision
- vision2021
(and 1 more)
Tagged with:
@bbudzon Thank you so much for your reply! I'm trying to export the venue as an MVR file, but it just takes more then forever. 20min in and I'm at 5%. The file is quite large and complex, still want it? 😃 Thanks for everything! // martin
- 11 replies
- 1
- vision
- vision2021
(and 1 more)
Tagged with:
Hi all! In VW2021 I've made a model of a venue and a light plot containing trusses, hoists, lighting devices and so on. I then exported the venue (no trusses, lights, hoists) as a ESC file and imported it to Vision. So far so good (I think). Next, I exported the trusses, hoists, lighting devices and everything else used in the set design as a MVR file. Most of the things look ok, but why, oh why, does Vision import (or Vectorwork export) it like this? File with white background is from VW2021, before exporting. As you see, hoists are up side down and no truss is visible. But still the chains are at the correct position. And yes, all classes are visible during export 😃 I asked this question on FB as well but no answer so far. Thanks all! Looking forward! Martin
- 11 replies
- vision
- vision2021
(and 1 more)
Tagged with:
Thank you Dave for getting back! I've attached the file here. Even though there's a lot of chairs I really thought this wouldn't be a problem these days. I've used the lowest export quality available and used only VW standard models, a simpler chair. Thanks!
@inikolova Thanks for the help! I've removed everything but the chairs from the drawing, so nothing from the actual stage yet. Thought this wouldn't be a problem considering the tech level today. Looking forward to the new version! Thanks!
