M5d
    471
Reputation
129 Spectacular
1 Follower
Personal Information
  • Location
    Australia
Recent Profile Visitors
  1. https://www.maxon.net/en/archviz @Dave Donley are you able to share more on how this software / plugin will be bundled now? If you can . . . Maxon used to provide 'Visualize', a limited version of Cinema 4d aimed at architectural / product renderings. Will this new plugin window be a standalone product like 'Visualize', or will it be an add-on that's part of Cinema 4d?
  2. https://architosh.com/2025/05/maxon-aims-to-bring-hollywood-level-rendering-to-aec/ There's a second article with more detail on this from Architosh today . . .
  3. Thanks for the tip. Helvetica Neue and its sub-variants passed. I use this font pretty much everywhere. I was able to find what the replacement character is with Font Book, ڐ is an Arabic character or Unicode: U+690.
  4. Thanks Pat. I’m on update 7, so hopefully 8 is a fix. I’m not sure how this can be captured, the Worksheets work as expected whether they are basic or very complex. The issue is a random occurrence that’s not specific to any particular Worksheet or any particular Row, it happens in both Database and Spreadsheet Rows. When it happens, it can be just one Cell on one Worksheet, or a smattering of Cells across multiple Worksheets. The only consistent feature is that the affected Cells are Cells that only contained text. That can be the Title Cell of the Worksheet, which is typically a Spreadsheet Row or the screenshot Cells above, which were Database Rows dedicated to specific criteria (members types), where the affected / first Cells simply had text in them for the type of member (not drawn from a record). The resulting corrupted or rewritten text typically (I think), is the second character of the original text followed by the j-like character with 4 dots. I skipped over 2023 and moved to 2024 a few months ago. So this project / file (1.4Gb) was started in 2022 and moved to 2024, maybe that’s the cause . . . If it continues in update 8 or in new files, I’ll repost with further details.
  5. Hi Pat, So far no Cells with formulas or that report data have been affected, just Cells with text only in them. For instance, in the Floor Framing screenshot above, the cell beside the B#s just has the text Bearer(s) in it, the same beside the PL#s, which should read Plate(s), the Joist(s) Row has a formula. Everything is intact when a worksheet is imported. At some point (I just haven't caught when or what might trigger it) text Cells across different Worksheets randomly (but repeatedly) get replaced / corrupted. The worksheets are old (well established across many versions), 2024 is the first version to cause this.
  6. I'd love a fix for a minor bug that's happening in worksheets (Vectorworks 2024), which replaces text in a cell with the symbols shown in the examples below. No bug report yet, because when it occurs hasn't been obvious, but it happens frequently. Retyping or reimporting the worksheet is a temporary fix when publishing, but constant checking is required.
  7. When you stare into the Abyss . . . . . . engrossing, if not slightly addictive tool!
  8. Indeed, we must be cautious . . .
  9. Hi @Tyler French this survey email appears to be an ongoing campaign? Using the unsubscribe button at the base of the email takes you to the page in the post above. None of the options available clearly refer to your emails, which category do they fall under?
  10. How do we unsubscribe from this particular type of email?
  11. https://architosh.com/2024/04/autodesk-and-nemetschek-group-partner-on-interoperability/ This seems like a monumental shift / leap forward. @KPrice Apologies if this has already been posted elsewhere, I couldn't see it in announcements. I would be very interested to hear from Nemetschek Vectorwork's on this agreement, and what kind of developments might be looked at over time?
  12. Probably not the answer you're after, but WinDoor has the feature I think you are looking for . . .
  13. I haven't made the leap to VW2024 yet, so I cannot speak for the latest edition, but this is a known limitation of the software. There's a (cumbersome) workaround for the problem and a wishlist item from 2018 in the posts below.
  14. From Create Data Tag Styles:
  15. That is good news. So Redshift RT, I'm guessing, will go even further than an IPR, i.e. similar to working in Shaded mode . . .
