CJA
    5
Reputation
1 Neutral
Personal Information
  • Location
    Australia
  1. So Pat, If I learn the worksheet functions I'll be able to use them in the data tag tool ( as long as I use the right prefix & suffix) and I'm taking it other tools as well where there is input for dynamic text.
  2. Yes! Thank you that's worked. Thanks for the Tip Tom W. I will now read up on what that field does. Thanks again.
  3. Slight Issue... Tag appears to work... However... It has appeared to Turn off the WinDoor tools capability to toggle the 'opaque' option. It thinks for a second and then switches the option off again straight away. Is this because it thinks the code is telling it to be opaque instead of just reading the value?
  4. Thanks Guys, I'll be honest coming from ArchiCAD were everything is spoon fed to you this is some complex language to get around. But I can definitely see massive potential in this level of flexibility.
  5. Hi Everyone, Former ArchiCAD user new to the Vectorworks Environment. Trying to create a data tag that when the obscured glazing is ticked in the OIP instead of returning a 'true' or 'false' in the tag it returns either 'OBS' or ' '. Is this a simple add on string to the Tag Field Definition or is this a case of a something simple needing a very complicated workaround.
