Neil Barman
Vectorworks, Inc Employee
    748
Posts posted by Neil Barman
  1. That's interesting about there not being a call to get the Levels of a Storey. Hmm.
    Realistically, knowing the way templates will be set up and the way users may work "on the fly", it is conceivable that Levels will created both ways; Some Levels will be added from a template and others will be added manually as needed as planning a project.
    I very much appreciate you digging into this, Pat.
  2. 14 minutes ago, Pat Stanford said:
    Ah, scope creep. 😉
    LOL... Busted!
    Yes, the end goal would be to view/print said Report so that a small-and-very-smart team could look at all the Storeys, and their associated heights, and building height limits and such, and plan the project (height-wise) well, before even drawing and objects.
  3. Thanks @Pat Stanford!
    The storey info I am hoping to extract is mainly what is shown in the Stories tab (and related dialogs) of the Organization Window. I'm thinking that this order should work:
    Highest Storey name & elevation plus prefix/suffix, then that storey's List of all Levels (the ones I have actually used, not the full list) in order from high to low plus the name of Design Layers associated with a Level.
    then
    Second highest Storey name (with all the info as above)
    then
    Third highest Storey
    and so on, until...
    Lowest Storey
    Something like this...
  4. I am wondering if someone here might have a way to report the Storeys within a file (as well as each Storey’s contained Layers, Levels, their heights, etc) when the file ONLY has Stories set up so far? That is, there is no geometry drawn in the file yet, hence I'm not able to report the Storey, layer, level of a any of objects themselves.
    Thanks!
  5. Once you get the palettes docked where you would like them please do make sure you then go to the Window menu > Palettes > Save Palette Positions.
    (and @Jeffrey J. Hummel, you are listed as a "Greenhorn" because you just joined the Community Forum and have only posted a couple of times as of now. Such membership "level" are fairly typical on public forums and simply indicate how long or how much a member has been involved/active. As you post more, your level will change. If you would like to indicate more about your history with Vectorworks, your Vectorworks version, your computer spec's, etc I would suggest that you enter this info into your forum signature. You can find this area to edit under your name at the top right > Account Settings > Signature.)
    • Like 1
  6. On 11/26/2019 at 7:59 AM, MHBrown said:
    Thanks, that worked. However, I don't ever remember having to have that extra step in earlier versions of Vectorworks (or MiniCAD, for that matter, going back to 1995).
    Since that color pencil box is a Mac OS-based color picker, it sounds to me like Catalina is the reason for having to press the OK button to confirm the color.
    It may be a sign of things to come on the Mac side of things... it might not be a bad idea to review other Catalina changes to the OS.
  7. @Jalkana It sounds like you may be asking for something like “Viewport Styles”, according to the current way Vectorworks allows the user to set common options for objects. You would still need to set up the Overrides once somewhere – no software can read your mind, yet – but then you could then save the Viewport Style as a resource to be used at another time. Also, you may also need to tell each viewport to adopt a certain Viewport Style, but you can describe how you would like this to happen with the fewest clicks possible, or from a “central location” like the Organization dialog box. Whatever the case, I would recommend that you post this request in the Wish List section of the Forum. Include a description of what you would like to achieve, how you would like to achieve it, and how such a feature would be beneficial to your workflow and possibly for the workflows of others.
    (And not to diminish your request at all, but if you did actually run into the time-crunched scenario you describe above, you might need to have a serious talk with your structural consultant and especially your client about your Working Relationships. You would certainly need to say no to one of them – Most likely the client. Last minute information, requests and emergencies on their part do not need to equate to making you panic or work in a compromised way.)
    • Like 2
  8. On 6/5/2019 at 1:31 AM, stephaneuk said:
    This seems to have happened to my flies.. running VW19 SP3
    From fast renderworks to final quality....
    @stephaneuk It looks like what you’re seeing may be different from the issue that was being discussed in much of the rest of this thread. If you are still experiencing the issue, I would recommend contacting your Vectorworks distributor’s technical support for assistance.
    Also, since you only mention Fast and Final Quality Renderworks, I would encourage you to try out Custom Renderworks Styles instead. You will likely find that you can create better looking renderings in shorter times by taking control of the render settings yourself.
  9. 1 hour ago, Francois Levy said:
    I set mine to about 0.6 seconds; seems to be long enough to avoid everything lighting up like a pinball machine, but not too long to wait if you want the highlighting.
    Thanks for the suggestion, François. I was just looking for the "sweet spot" and, though I love pinball in machine form, I don't want to see it all day on-screen... a 0.6s delay is great!
  10. Welcome to the Forum, @malonso!
    It sounds like what you are are wanting to do is what Classes can do. Using Classes, you can set the graphic attributes (pen colour, file colour, etc) for objects so that you can visually differentiate them while working with your project on a Design Layer. When it’s time to create the drawings, you would then create Viewports of what you wanted to show on the drawings. Viewports can be set to override the Class settings you previously assigned, so walls, for example, that appeared with colour when you were designing, can be set to appear black and white (or any colour really) for print/PDF.
    Since you are new to Vectorworks, I highly recommend checking out the Getting Started Guides here. The first four guides (Basics, 2D, 3D and BIM-Architectural) should be especially useful for getting you acquainted with many key core abilities of Vectorworks.
    I hope this information helps.
  11. You are most welcome! I’m happy to help.
    I made that little movie using Snagit, a great screen capture tool from Techsmith. It allows you to record just a specific region of your screen, which is very handy for focusing attention. Snagit is a superb tool for taking & saving screenshots and annotating them, but it also works well for shooting short videos. For longer videos that involve more post-production, annotations effects and audio tracks, I use Screenflow from Telestream, which is also amazing.
  12. 9 hours ago, DJMDevon said:
    Thanks for the list of shortcuts, I'll have a look through and look for any possible conflicts. We have a customised set that we've all been using in the practice for the past 10 years, initially setup by our Vectorworks supplier, hence it would be useful to be able to export / print a full set of the shortcuts setup in the customised workspace.
    5
    To export a .txt file of your customized workspace:
    1. Go to Tools > Workspaces > Workspaces... (which opens the Workspace dialog box)
    2. Select the Workspace from which you would like to generate the list of menu commands and tools.
    3. Press the "Export" button in the right sidebar.
    4. Determine the destination of the .txt file and save it.
    I hope this is what you are looking for.
  13. For what it’s worth @DJMDevon, I have typically opted to not migrate when installing a new version, so that I get the version as the engineers built it. I have then edited a copy of a stock workspace to create my own custom workspace. My customization, which I will admit is not as “extensive” as some custom workspaces I have seen, usually takes under 5 mins. (I used to keep a list of my modifications, for easy reimplementation, but I’ve done it enough times over the years that I don’t need to review the list anymore.) I have always had good results from this method... Almost like starting from a tried-and-true recipe, then making small modifications to it over time to create your own version.
    This manual “revisiting” of customizing my workspace also provides me the focused, considered opportunity to add or remove aspects of the workspace that I realize I should be changed from my previous iteration. Sometimes a previous modification doesn’t get repeated because it wasn’t as useful as I thought it would, or I try out a new modification that subsequently proves to even more useful than I previously anticipated.
    I have even used or suggested this approach in offices where I have worked or consulted, and people have typically appreciated the results (even in cases where they insisted that doing so would take too much time... It turns out it didn’t actually take that much time and they too found it valuable to “revisit” the process of workspace modification.)
    Your mileage may vary of course, but I thought I would share that approach in case it helps.
    As for printing a list of your already modified workspace, I seem to recall that this is possible – I’ll look into it...
    • Like 1
  14. 39 minutes ago, BradLyons said:
    Thank you for your response.  ARE YOU KIDDING ME??  Do you know why there is that limitation?  That's a horrible design flaw!
    My understanding is that the 8 light limit is part of the OpenGL standard as a whole because OpenGL is meant as a quick-to-render solid mode. If the OpenGL standard allowed one to add as many lights as they wished, then it is likely that the "quick" aspect of OpenGL would be gone (because rendering light can be complex and add rendering time.)
    • Like 2
  15. @DJMDevon I dont know exactly why you’re seeing what you’ve described, but the description you’ve provided makes me curious... When you first ran v2019, you would have been asked if you would like to migrate from a previous version, did you you reply Yes or No?
    With regards to the keyboard shortcuts, Vectorworks’ built-in Help documents (available via the Help menu) have a PDF of the keyboard shortcuts. It’s available here.
  16. There shouldn’t be any issues... I was just able to do it myself and had no trouble.
    If you are still not able to, I would recommend sending an email to tech support (CAtech@Vectorworks.net) and asking them to look into it. When you email, make sure to include the last 6 digits of your serial number so they can cross reference with your account.
