Kennedyme
59 -
Reputation
7 NeutralPersonal Information
Occupation
Exhibition Design & Detail
Location
United States
Recent Profile Visitors
2,248 profile views
I'm having the same problem, except rechecking the "solid" fill box did not change anything. Mark
I've been having the same issue. Hidden line rendering just not working, instead acts like wireframe. Been using Vwx 25 years, all the objects have solid fills. Mark
I'm using Monterey and have the M1 Max chip. I wonder if either of those are part of the problem.
Is there a way to get data visualization to recognize individual items inside a symbol? It seems to react unpredictably. Sometimes, an item with a specified class that is inside a symbol seems to be ignored by the data visualization setting. Other times, the color chosen works, but the transparency setting does not. Mark MacBook Pro M1 Max 32 g RAM VWX 2022 SP2
- 2022
- data visualization
(and 1 more)
Tagged with:
Vectorworks 2022, SP2 has been very slow and buggy for me. I have a MacBook Pro M1 Max with 32g RAM, so I am frustrated. I have been using VW since it was a young MiniCAD and have been getting very frustrated with new bells and whistles with great promise that don't seem ready for primetime. Instead of fixing existing issues, with each update, more half-baked gadgets are introduced. I'm getting pretty disillusioned with VW. Mark Kennedy Exhibit Designer
Thanks, I'll try that. Btw, the cabinets are not an issue, because they are intentionally without a fill. The trees are the issue. Some of the branches are groups inside of symbols. Mark
@Tom W. This problem happens in VPs, also. The files were created before vwx 2022 by people in my company–perhaps in 2020. However, I did not have this problem until vwx 2022 SP2. I attached some screenshots. The first is hidden line. Second has the background render as shaded and foreground as hidden line. the third is Renderworks Colors White.
Bug – Hidden line fails to render in VW2022
Kennedyme replied to Kaare Baekgaard's question in Troubleshooting
I have 2022 with SP2, and hidden line is not working consistently. It doe not have to do with the attribute settings. I have checked that, but that is not the problem. The objects are appearing solid using most other render modes, including Shaded, Dashed Hidden Line, Final Quality RW, even Artistic RW.... However, not Hidden Line or Polygons with Lines. While I am actively using the Flyover Tool the hidden line rendering looks correct, but when I am no longer 'Flying Over,' and it renders, some items are rendered correctly, while others are missing lines, so as to appear inside-out. It's definitely a glitch of some sort. (Fyi, I have been using vwx for almost 25 years) -
I checked for that first thing, but was not the issue.
Object Info Palette Not Showing Selection?
Kennedyme replied to Bijerro's question in Troubleshooting
I'm having similar bugginess in 2022 with regards to selecting objects. It's kind of random. "Select all" won't work in design layers, but will work in sheet layers. Sometimes I can't select something at all, unless I choose "force select." -
Hello, I am using the trial version of 2022 design suite, and when I render in Hidden Line, some extrusions render like a messed up wireframe (top horizontals invisible, other parts like wireframe). If I create the shape as a solid, it renders fine. Other extrusions render fine. What's up?
Marionette beginner: Trying to create parametric extruded object
Kennedyme replied to Kennedyme's topic in Marionette
https://forum.vectorworks.net/index.php?/profile/16986-marissa-farrell/ Hi Melissa, I was wondering if it is possible to do what I describe above in Marionette. Mark -
Worksheet criteria field value selection menu
Kennedyme replied to lgoodkind's question in Wishlist - Feature and Content Requests
But, when searching for Field entry, is it easier? -
At the minimum, there should be a way to search, like can be done for Classes. The functionality is so lame as to feel abusive. Mark
