234 -
Posts posted by milezee
@Boh thanks, I have no idea how to use a Marionette, is it difficult ?
16 minutes ago, Wes Gardner said:
play around with Marionette
I wouldn't know where to start with Marionette definitions, 🤣, yes have played around a bit, definitely no quick solutions, suppose after you've done a few the workflow will quicken up a bit, cheers for chipping in 👍
1 hour ago, Kevin Allen said:
I've done this type of thing on a smaller scale, but painstakingly manually.
@Kevin Allen yeh have been playing around, was hoping there was a nice efficient workflow that someone might know 🤔
did find this browsing around, not for carpet or woven tiles, more ceramic/hard flooring tiles, interesting plugin
https://www.mosa.com/en/services/online-tools/pattern-generator
@rDesign cheers, I'll take a look 👍
@Josh Loy Josh, I like the way you manage customer expectations 🤣, I look forward to the fix 👍
- 1
12 minutes ago, Josh Loy said:
Just so you know OpenGL generally uses 32bit floats while the model is stored in 64bit floats requiring us to work with different spaces.
@Josh Loy hi Josh, I haven't got a clue what 32bit floats & 64bits floats are 🤣, but I believe you 😊 and hopefully you guys can find some kind of fix in the next SP release 👍
@Geoff McBeath hi Geoff, thanks for chipping in, how do you explain if I create a cube, of a reasonable size, 300 x 400 x 500mm , then zoom in and the tearing still happens ? Yet if you switch to an orthogonal perspective the problem goes away ? Either way hopefully the software engineers can fix 👍
- 2
@PeterYip I think i may have just solved the tilt & spin issue, in the configure window I just had the default Vectorworks set, I added VW 2020 from applications, and it now seems to work, still not as slick as in Rhino, but it works, cheers for the assistance 👍
- 1
@digitalcarbon this is how i want my Space Mouse to work, can't even get my 3D Connexion Space Mouse to work fully in VW
@PeterYip no spin here, anything at the bottom of the list in green just doesn't work
@PeterYip thanks for chipping in, think my settings are pretty much the same, i just can't get the tilt or spin to work, kind of defeats the object of having a space mouse, works beautiful in Rhino, its a dream to use, but in Vectorworks it sucks yet they have it as supported software 🙄🤔
Trying to set up my 3D Connexion wireless space mouse on my MBP using VW2020. The pan tools are fine, right, left, up down, zoom in/out are working ok. Its the spin & tilt when in a 3d perspective view that just don't work at all ?? Any ideas 🤔
I have the same device set up to work fantastic in Rhino 3d
Screenshot attached, its the Green icons which are just not working, tia
4 minutes ago, zoomer said:
Sorry,
it works well as it should in Orthogonal OpenGL.
The drawing issues are only in OpenGL (narrow?) Perspective Mode for me !
@zoomer that's it, that's the problem, I always use 3d perspectives in 'normal', if I switch to 'orthagonal' the tearing doesn't happen when I zoom in. @JuanP is that a display bug ?
- 1
@EAlexander yeh still same issue 🤔, @JuanP I'm getting a similar issue when I use a chair from the stock VW library within the software, its not as bad, but still clips the 3d geometry if I zoom right in
@JuanP yes same happens in 2019, Juan the object is a stool/chair in SketchUp format, imported into VW (files attached)
Simple numbered Data Tags
Add the BOQ record to your objects or symbols, add your names, sizes finishes, place BOQ Table on your drawing, add Data Tags with or without leader, simple but effective way to create a BOM/BOQ with everything named, quantities etc, and easily identified on your drawing, hth someone 👍
- 4
@Tanner Shelton i would recommend having a play with Twinmotion, it's still free to download but that will change sometime in 2020 I guess, you will be surprised at what you can achieve, lengthy discussion can be found here-
There are also some good Twinmotion tutorials on YouTube, here & here
@Andrew Davies how is the new 16" MBP performing with modelling and rendering ?
Planning/Mapping Carpet Tiled Floors
in General Discussion
Posted
@Boh had a play, really interesting, there's some clever people out there 😃
came across an issue, or maybe its me, not sure, I changed the colour/fill of one of the symbol patterns, it seems to only part work 🤔, any ideas ? (screenshot attached)
