All other dimension modes allow modification after creation though text and drag end point without needing to be associated.
Ordinate Mode leaves you No options but delete and recreate.
Unassociated Ordinate Mode dimensions don't update if moved, have no relationship to Zero after creation.
Associated Ordinate Mode dimensions only adjust when the object is altered directly.
tool lets me lets me connect and join lines, arcs, polys, but wont complete to form a closed object.
I have to decompose, do last connection and then select all correctly to compose a closed object.
I want this tool to complete a last connection and close single objects also.
moving the curser to change from Shape tab to Data tab in the Object Info Pallet is arduous.
can we have quick key to toggle through or have 2 object info pallets so I can have both Shape and Data visible .
