Gadzooks
    574
Everything posted by Gadzooks
  1. Thanks Christiaan - I appreciate that. (Blimey - better come up with something half decent ) Sorry @nikihoopsI may have left you hanging a little there, as I assumed from your OP that you wanted to prepare a 3D client presentation. You're quite right, the solution I suggested is far better in 3D. And, as you've found, 2D is irritating - to say the least - with the way VW wants to 'cap' everything. Your screen shot highlights not only the caps attributed to the window (obviously not normally seen in 'normal window/wall situations), but also the extra lines from the wall recess operation (which you can't really do much about in terms of adjustment of the solid used to punch the recess). As you've already discussed, the quick work-around is a liberal dose of polygons to mask the offending lines. If you choose to do that, you might as well make something 'useful' and create a floor covering for the room. Attach an image to it and leave it as a 2D only object (which will remain in place in your 3D visuals) . I've added carpet.. The fact that I see you've chosen to present the wall in a neutral white helps an alternative solution, as we can easily get rid of the cap lines another way. The wall I've used comprises just the one component..create yours as you wish... Set the component's attributes when you create it.. Just create the component as you wish the wall to be - white fill and reasonably heavy black left&right pens are chosen here to match yours. BTW - The thickness at 371 is just random (from an earlier wall) - set your own. Once the component has 'outstanding' features, you can turn off the wall from showing... Change the wall to basically 'nothing' and set the caps to use use those wall settings.. Obviously. there are a few ways of doing this (using white for the pen?) but I think as shown is a safe option to kick-off with. Note: You could also 'play' with classes and set the attributes by a class created just for this purpose. Returning to the wall, nothing now shows through for the caps. I've taken the 'carpet' away to prove!! And, of course, your 3D is unaltered... There are a few 'options' in this process and others might have better alternatives. Have a play and tweak it the way you want it! Hope this helps as a start.
  2. Thought I would test this out and as I thought it does give what you want in the VP. It doesn't really take much time to follow this process. If you want you can still place the symbol but choose to check the box 'do not insert symbol' (another misleading instruction) this will at least create the correct hole size for you. You'll still have to deal with the 'clunky' offset options if you need to move the hole slightly, but you do gain the option to cut the hole with your choice of vert/splayed/square edges which is a nice touch. Still needs fixing though (unless I've missed something). I think you should submit to Bugs.
  3. Taproot - Thanks, your file was what it needed. Mind you - Thats a few hours I'll never get back. I tried all sorts components/textures/classes you name it I think Ive got through the lot. Bottom line - I think its a bug. If I create a roof your skylight sits in and displays in the VP. There's certainly nothing wrong with the skylight so its the roof. It seems using a roof face is the issue. To test I also created a 4 part (default) roof and then adjusted the sides to leave it mono pitched as your roof face - and this works fine. I obviously also tried a roof face from scratch and that had the same fault. As an extra - I exported your file as v2017 and opened it with 2017 - No issue so this appears to be something introduced in 2018. Interestingly (possibly for the VW boffins) if you then open the v2017 file in 2018 its happy with 'roofs' coming full circle, but can't resolve your roof face at all and makes a mess of it - resizing and moving. For the moment I think you'll have to stop using roof faces (with bound symbols) and try to get by with roofs or maybe a work around is just to punch the hole first and then place a skylight 'by hand'. I didn't try that, but I would imagine it will work as the skylight won't be a roof face element anymore. Hope this helps. Others might find a different cause.
  4. Thanks Jim. @ChristiaanIf there was some sort of pattern I'd be up for chasing it down, but I think I'm tapped out. Will you submit your OP as a bug.
  5. It is though. Granted, Christiaan's OP was that the window retained orientation but the ID tag wouldn't 'play ball', but when you place the window back (as discovered by @Christiaanfrom my example) it flips the opening. This isn't what is expected (?) I think I'd like a response from VW based upon the second of the above if its all the same to you. --------- Edit Sorry - I've made it sound like you are not agreeing. I think you are, but I believe there a little more meat to the query, based upon some time with this particular 'bug'.
  6. Well I did wonder if the 'sloppy' way of inserting the window produced issues - so went to top/plan, but no difference. Haha - Dont think I can use a CAD program where outcomes are confusing and it make a difference the way you hold your face!! (royalty free btw) Lets hope someone's on the case and can provide answers
  7. I see!! Don't know what made you place it back (probably from years of using VW and can't quite believe the outcome doesn't have a spurious side) - but excellent find. Whereas your window doesn't change (except to what you require) if placed back - whats going on? For the license fee, I can do challenging (and am happy to learn more every day), but I'd rather not do confusing - especially when the boffins will have moved away from fixing window creation and be on to some new 'headline' feature (that I possibly didn't even know I wanted). Lol. The window tool is ***********. (don't bother counting the *. It doesn't spell the word I could have used) Something needs to be done with this. @JimW. Even if the answer is "you're not using it correctly" it would be good to find out where we are with this and what the boffins are going to do.
  8. I thought this might be classes but you say they are turned on (in the VP?) Can you confirm - this is a new 2018 file, or is it something created in 17 and now opened in 18? - Just so we have the complete background to this. I can't replicate this. Can you upload the file? (or a test)
  9. @nikihoopsAgree - could be a lot better. But work arounds and your knowledge of VW in that respect will help a lot. Its what the forum is great for. I think if you were drawing this as new build I would use @Christiaan's way as you would end up with more accurate materials shown on plan. HTH
  10. Errr - far right? (no worries - more coffee? lol.) You'd have thought the option to splay was was made for this. Nah - well thought through by the boffins, but flawed by a (lack of) simple addition command set to state where the splays should be. These settings give you this.. Just an extra tick in the box for left and right only would be good. And I can't be bothered to raise the issue of 'finishing' the wall surfaces. - Oh I did (silly me) You could 'fiddle' this (yes VWX needs fiddles/workarounds all the time.) Build an appropriate shape to create a wall recess on the inside of the window. Shape on plan and then extrude - in your case floor level to window head. Highlight wall and 'shape' and Choose AEC > Create Wall Recess.... I've then had to 'dress' the wall finish in. Works, but not as good as VWX boffins could (should) make it. Hope this helps.
  11. Yes and no - most of this seems to be the complicated way you have constructed the elements. As far as the 'complexity' is concerned, clicking on the 'box' reveals its a solid subtraction (to form the 'letter box') and then clicking on that reveals the 'box' is an extrusion of 4 separate lines. And - I see @Jeremy Bestjust snuck in before me with a better way. I was trying to upload an image built similarly but it seems part of the forum is brocken as far as images are concerned. @BGI tried your file in 2017, but you've posted 2018. Neverless, if it works in 2017, perhaps you should notify a 'bug' ? ---------------- Edit - sorry, missed you out @Benson Shaw- equally reasonable way to fix the prob. I resolved to using 3d polygons. ----------------- Edit again!! - How are you guys uploading images atm? Wont work for me.
  12. I think it would help if you posted the file - or a simple file that contains a wall with the sample 'window' elements. It seems from the image posted that the underside of the ptac is lower than the element to the right of it. Is this drawn correctly? Brickwork opening (base) is to remain level? I also note the height of the 'window' is not a brick dim. Does this need to be addressed? I assume the ptac also protrudes forward of the other three 'flat' elements, or is the casing not needed (to be shown accurately) in this exercise? Or the body of the ptac is internal? Would be helpful to have some detail to be borne in mind to develope a solution.
  13. Something Brocken??? I dragged and dropped (on another thread) and it worked! - Thanks. But (theres always a but) now it won't allow further screenshots to be placed - even by uploading to the 'container' first. I get.. Which, incidentally, I have dragged into place here as well. (still works - yeh) Now I'll try to add to this .......Nah doesn't like that. For information - the image above is only 36kb and the one I next tried and failed with is 192kb so its not a size issue. @JimWare you still playing with this and you know about the issue?
  14. Spot on - I generally reduce to 600 which seems reasonable on the forum page. And dragging into into place would be a nice touch.
  15. No worries - Def go with what you want. Your work-around certainly seems to work. From your screen shots, another issue seems to be the poor legibility of the fractions. I don't use them (UK) but I'm a little surprised at the poor resolution of fractions. I assume some fonts are better than others.
  16. Bruce - why don't you use the text offset setting. They don't have to be exactly on the line do they? You can drag the dimension box to wherever you'd like (off the line), but entering a value in Text Off will keep your dims consistant. EDIT.. Sorry - should have added - Then you don't need a fill to the dimension
  17. @Christiaan - Agreed, window insertion has 'suck it and see' outcomes half the time. Looking at the file you posted, is there something adding to the 'confusion' VW gets itself into. Your design has the opener on the right hand side of the window in wall elevation. If you look at the window settings VW has your window opening to the left in its front preview pane. If we assume this is how the window was 'created' (and you've flipped the window in this instance) then do a test... Clearly looks like this is a bug if VW can't handle a flipped window style and represent it accurately with ID attached. Could you perhaps try this and just make sure its not me thinking I've stumbled over something, but that turns out I just need another coffee
  18. (maybe?) I think you have to install incrementally. Starting with the 2017 and then the SP's in turn. Someone will correct me if I'm talking.........
  19. Nice little vid @Andy Broomell Sometimes much easier to show than tell.
  20. Hi - Have you set the page to be seen? There are options to show in the page setup. You maybe have show boundary unchecked? Edit.. @JimWsnuck-in before me!
  21. Good advice Benson. Good and clean control over classes can make or break a project and the way its presented. It's worth time spent on a class 'regime' as it is on setting out layers and VP's.
  22. Ha ha. Now I've heard it all. And we (Architect/Designer) moan about it. We should be grateful.
  23. Well I'm not in the market for a lift atm. But I think you need to be quite 'explorative' when you google stuff. If at first you don't get quite what you want it pays to slightly change the search order/question. I've absolutely no idea what you're after in terms of quality/price etc but 3d single man lift gives this.. https://3dwarehouse.sketchup.com/model/u28faf057-bef5-4ce6-a7bd-c5be7b416090/Manlift Would do me - maybe not for you? Change the colour to yellow and stick your client's logo on it Done! Scissor lift gives. https://3dwarehouse.sketchup.com/model/26d1c26917219e40c3513b64581c4322/lift There's loads out there - varying quality etc. "Yer pays yer money (or get it for free) and yer gets yer choice" so there's plenty more I'm sure are better modelled but huge files. Good suggestion - This is always a really good start for 'sublime' or 'ridiculous'. Just spend bit of time looking for either something that is exactly what you want, or something that has potential and you don't mind 'playing' with it to get you where you need to be. Hope thats a start for you.
