972 -
Everything posted by zeno
hello I would like to see an improvement in them can I set the camera option directly in the OIP. When I need to adjust the light in a rendered viewport, actually I need to go inside every time in the "camera" dialog inside the viewport etcetera... this must be helpful if I need to move the camera but for only the exposure, blur and other effects could be very quick to set it into an OIP in my opinion Thanks
Class description in organization dialog
zeno posted a question in Wishlist - Feature and Content Requests
How about add the description in Organization dialog? so you can have an entire look of the drawing's structure -
Hi everyone, I tried to create a panorama view with a render style with camera and exposure effects. It's not working. Even if i run the command when I'm into the active camera.
good Work Alan! I will learn your videos!
How do you use stories for multiple model? I prefer to generate some saved views after creating the different viewport phases, to manage the file with stories (and not increase the file size)
Yes, is it the same option!
A solid element can do a structural element by OIP A Pointcloud isn't a solid element. I suggest you create a section viewport and create some polygons in the annotation dialog of the viewport. Is very quick and good-looking
By the way, using the ambient light the entire scene becomes more "flat" even with low increase level "like 5-10%). At the moment is necessary to use it when you are in front of windows, but if your background is back to you could be better turn the ambient light to off to have better results in my opinion. There is a WIP render, but I think that the right render is the better one. In this case, if you need to elaborate different viewport on the same scene, could be necessary creating multiple render style with multiple background excetera.. it could be complicated a little bit.
All building elements like wall slab etc are "structural", or everything you want to convert to "structural" by OIP (like an auto hybrid or some similar) . All parts will be cut under the same class section style. If you checked the option "make structural and no structural parts" you can choose 2 different section mode (like section and projected items), both of this element can have attributes by classes. So if you cut a window or a door the glass could not have the same lines like the "structure" of the windows, or simply you need to separate to representations. In this case you need to check the "use structural and no structural" options.
Thanks, zoomer. It was made for a webinar. Here is a very important issue to have the capacity of management the different project phases (like the "variable thickness wall".. but it is a long history I think..)
Move by point tool to ignore copy number in move mode
zeno replied to Art V's question in Wishlist - Feature and Content Requests
Hello Art V i add a specific command you can find on the UI settings. In italian language it's "SPOSTA E DUPLICA", maybe "move and copy" i think.. (i send you an image). It works very quick, but you can only move an object or duplicate it (more click you do, more copy you have, like the terribly "autocad style" ;-) ) I put it in the standard palette. in some case could be useful. Z -
Existing tree symbol vwx 2018: issues with selecting symbolsymbol
zeno replied to quandong's question in Troubleshooting
Hello Quandong, i don't understand what you need precisely. Can you explain it better (with images if you have)? Z -
I had the same problem. I resolved it without creating multiple models you need only create a lot of class, new slab-wall-window style etc. with specific classes after that you can organize your viewport: you need play with class exeption so you can set different colors as you need. You must assign ALL components by class. Different classes by old, new and comparised step. This is necessary because vw show different colors by component-wall in section when the specific elements is projected. Only if all components attribute are settings by class allows you to manage the colors. I will send you some picture to better understand
In a first moment, if i turned off the charis classes the light disapperared. After that, i turned off only the reflctivity (not glow, reflectivity) on the chair's elements. I have the same results: no light. I had the same problem in EVERY part with a metal texture in the scene.
I'm just tring some different settings. I had a very big problem. Every metal shaders worked like a light, even at 5 % brightness. look at picture attached: both have the SAME settings, exept for metal texture settings of sittings (you can see something similar a light on the kitchen: it is a metal part) how is possible to manage it? it works well?
Some splotchiness are going away buth some are remaining maybe a 3D geometry problem for the windows?
Thank you Jim, i will repost it with the updatedet settings How about using non total white color?
Hello everyone... I just restarted to set some renderings on the scene. Actually, i use a very high background (up to 5000% brightness) and a render style without a camera. I find the internal light good but I need to replace some texture etcetera. No more light on the scene. But some spot are here... and I need to understand how can I remove it to continue my work. Does it depend only on the texture of the window part? Thanks a lot Z
On the Italian Version (we use the “architect window/door tool), if you need to create a door style you can do it inside the tool’s dialog. Begin from a simple window or door and than search where you can save it like a symbol or something similar. So you will add your style on your file resources. attention: i used often this styles. I noted that if you make several chang settings on the style, every time you will wait a liitle bit for effective changings on the scene. I readed that it’s a single core process : if you see that the file is “freezed” that’s because the changing is in progress. For example sometimes i needed to wait 3 minute for 5 windows-changing progress, all comes from a single windows style. Exept the time, this is a very great instrument. Remember that you can lock/unlock what you need.
How many cores / threads does VW take advantage of?
zeno replied to Mickey's question in Troubleshooting
Someone has the updated link of these link, please? -
I'm so sorry. Could you direct me on one of the latest?
