quandong
    6
Reputation
0 Neutral
Personal Information
  • Occupation
    Registered Landscape Architect
  • Location
    Australian Capital Territory Australia
  1. Thanks Pat, file is in 2018 format. I think the there have been some changes to the way 'existing trees' symbols work with the introduction of 'import tree survey file' in 2018 (a fantastic development).
  2. Thanks Zeno Apologies for the delayed response, I've been away from my office. Please see attached PDF. existing tree symbol query.pdf
  3. Existing tree symbol The existing tree symbol in VWX 2018 does not seem to be working properly. When I go to select a 2D symbol, none of my own symbols come up, only the default ones display. Action is 'retain'. This was not an issue in vwx 2017. Can you give me advice on how to solve this please.
  4. I'm having the same problem. Help would be appreciated - thanks
  5. I have been collaborating on a project where the graphic designer is using InDesign (CYMK environment). Some of my diagrams were placed in InDesign. Despite using the same PMS number our colours did not match. The result was a fair bit of 'tooing an frowing' with the Printer. All this costs. I'm looking to avoid this problem in future. I'd like to clarify: 1 Are Vectorworks PDFs in RGB? (there doesn't seem to be any way to choose either CYMK or RGB when exporting to PDF) 2. Which Pantone lists does Vectorworks use? The Printer tells me that Pantone changed their lists a few years ago. For example, we wanted to use Pantone 5757C. Pantone 5757C in InDesign CS5 is C=27%, Y= 0%, M=95%, K=55% In Vectorworks equivalent values for Pantone 5757C are given as 0.024,0.00,0.278,0.561. The Printer tells me these convert to percentages viz: C=2.4%, Y=0%, M=27.8%, K=56.1%. Definitely not the same colour even allowing for different paper! I use a PC. Am I doing something wrong? Is there a way to work around this please? If the PDFs from Vectorworks are RGB wouldn't this have implications for printing generally and being able to show the client reasonably accurate colours?
