inikolova
Vectorworks, Inc Employee
    696
Everything posted by inikolova
  1. @Kevin Allen, You have two accounts - one is VSS and one is not. It sounds like you are using the wrong one. You should use kallen3.
  2. @grant_PD Check the About page in the Vectorworks Cloud Services desktop app, it should be on version 13.4.2742. If not, you should see a button to update. This restarts the app. After this, restart Vectorworks and the AI visualizer should work property.
  3. I submitted an entry in our project tracking tool for consideration. We would appreciate if you share a test file that describes the behavior that you are describing. We can work on addressing it once we have a good understanding of what you are seeing. Yes, we are aware of this problem. We will be working on preserving the sorting type that is set in Vectorworks at the time of export. To improve the usefulness of the viewer as a presentation tool, we are planning to introduce Saved views. Class visibility which was just recently released was an important building block for us to be able to support saved views. Thanks to everyone who contributed to this thread! We appreciate the feedback and it is taken into consideration as we are developing our plans for future product improvements. Best regards, Iskra Nikolova
  4. Hi @Brian Nitz, Please send me a direct message on the forum, or email me at inikolova@vectorworks.net, so we can investigate your problem further. We need to know your username, so we can look at your log files and see if we can identify any errors that may be causing this. Any chance that you are trying to sync a file that is currently opened in Vectorworks? What are you seeing on the Vectorworks Cloud Services desktop app's Status dialog (Sync activity pane)? Best regards, Iskra Nikolova
  5. Hi @George_Holder, The behavior that you are describing is seen when the Vectorworks Cloud Services desktop app is not running. Selecting Vectorworks Cloud should trigger the start of the app but you need to wait for it to finish starting and then select it again. Please let me know if you continue to have trouble. Best regards, Iskra Nikolova
  6. Hi @Junga, I can help you with this. Please send me a direct message with your username, so I can check your jobs and be able to investigate the exact reason why they are failing. A possible reason why you get this failure message would be if you are not using a legal Vectorworks version. The Cloud doesn't work with pirated files. Best regards, Iskra Nikolova
  7. @BartHays, Thanks for reporting! It should be fixed now. Best regards, Iskra Nikolova
  8. @rudybeuc@gmail.com, This issue has been reported number of times and we tried various fixes with no success apparently. 😏 We have a device share option for files that are available locally on the device, so you can Air drop them or share with other methods available on your device. I am sorry you ran into this issue. I will let our engineers know. You can find the device share option on the three dots menu of the file.
  9. Hmm, weird that it works with other webinars, but not this one. Let us know if you manage to find a fix. I informed the Vectorworks University team about your issue as well.
  10. @zoomer, A colleague tells me that they are seeing some security and privacy issues not just with Vectorworks University, but with other areas as well, after upgrading to Sonoma. If you are using Private browsing in Safari, this error appears. There is no known solution to this issue as of now.
  11. Hi @rudybeuc@gmail.com, Yes, to create a point cloud with Nomad, you need a device with a LiDAR sensor. Photogrammetry works with any pictures, even those taken with a drone. Nomad has a built-in app for taking the photos as well. If the photos are taken with iOS Nomad, additional metadata is captured that aids the reconstruction process and helps creating a model in the correct scale and orientation. Here is a nice course about Photogrammetry and Point clouds from Vectorworks University: https://university.vectorworks.net/course/view.php?id=2703 Please let me know if I can help with anything else. Best regards, Iskra Nikolova
  12. Hi @Kaare Baekgaard, In the Cloud Services Desktop app settings, there is an option to select items to sync. This allows you to keep all your files online only and select only items that you are currently working with to sync to your local hard drive. I am glad you were able to recover your files. I hope this helps! Best regards, Iskra Nikolova
  13. Hi @Kaare Baekgaard, Files disappearing for no reason is scary, so I asked our engineers to look at your usage logs to see if they found something wrong. According to the logs, a lot of files and folders were deleted from the web portal today around 12:25 UTC. The deletion requests were made simultaneously and all the deleted items were from the root folder. It looks like you (or someone who may have come into your account possession) selected many (or maybe all) the files/folders in the root folder, and deleted them. Do you recall doing anything on cloud.vectorworks.net? Best regards, Iskra Nikolova
  14. Thanks for the update, Christiaan! I am not able to reproduce an issue with the "Run on startup" setting in the app. Not sure if the Lingon app that you have might have something to do with that? If the System startup setting is doing the trick, that should be good enough. Best regards, Iskra
  15. @Mike D., A new version of the viewer is now available for download in the Customer portal (https://customers.vectorworks.net/downloads). It should no longer crash on launch.
  16. Thanks, @Tim Harland, I'll talk to the team to see if that would be possible. Best, Iskra Nikolova
  17. This is a known crash on the Mac with the 2024 Viewer that was recently resolved. The fix is in the process of being built and released any day now.
  18. Hi @Christiaan, The Vectorworks Cloud Services can be set up to run on startup either from the app settings or from the OS settings. It should not just stop working if you did not manually quit it. I am asking an engineer to review the log files of your app to make sure there is no issue that causes the app to die silently. If such an issue is found, it will be fixed soon. Best regards, Iskra Nikolova
  19. Hi @Tim Harland, Vectorworks Cloud Services supports rendering with referenced files, as long as they can be found. One requirement is that the master and the referenced files must be in the file version of the latest version of Vectorworks - currently 2024. The other requirement is that the Vectorworks file and the referenced files must be uploaded to the same storage - either Vectorworks Cloud Services or an integrated cloud storage such as Dropbox, Google Drive, or One Drive. If you have your Vectorworks file stored in another location (such as a local folder on your computer), you can still do Cloud Publish, and the file is uploaded for processing in the background. I guess your wish is for the Publish command to be able to look for all referenced files and upload them along the main file, is that correct?
  20. Hi @NBarnes, The Vectorworks desktop viewer can open project sharing files as read-only. This would be the best method for viewing the actual Vectorworks files. The people who need this kind of access can be added to the Shared Cloud folder and this folder can be synced to their desktop computer, so they can always have access to the latest version. Both of the above-mentioned only require registration for a free Vectorworks account. Note: There is a known problem with 2024 Vectorworks viewer crashing on Mac, and there should be a fixed version soon. Please let me know if I can help with anything else. Best regards, Iskra Nikolova
  21. @StefanoT Unfortunately, I just heard back from our engineers that this won't be a quick bug fix. I am sorry. We would have to find a way to allow Nomad to open 3D models attached to presentations, or whole presentations in general.
  22. Hi @jbtroost, We are currently working on a VR app for Quest devices. It will have similar features as the Nomad 3D/AR viewer, as it will be using the same file format. Planned release is around mid March 2024. I hope this helps 🙂 Best regards, Iskra Nikolova
  23. Hi @zeno, Yes, we want to support 2D geometry as well, however the specifics of the implementation are not yet clear, so I cannot promise anything at this point. We are currently working on a cloud drawing viewer that is specifically for geometry avalable on sheet layers. It is planned to support viewing BIM data upon object selection as well. Even though a separate team is working on this new viewer, it may affect how things work out for the planar geometry in the 3D viewer. Again, it is too early to be able to say how anything will be for sure, but we are definitely working in this direction. Best regards, Iskra Nikolova
  24. @zeno, Switching between 2D/3D views seamlessly or displaying both, in a BIMx fashion is on our list of improvements. We are currently working on supporting class visibility in the 3D viewer, which is the foundation for being able to support saved views. Saved views may be able to give you what you are looking for. Best regards, Iskra Nikolova
  25. Hi @StefanoT, Thank you for your post! That is correct, the vgx model viewer is not working well on mobile browsers due to technical limitations, so we implemented this page to forward users to viewing the models in Nomad. I think we have missed this case (forwarding to Nomad within a presentation slide). I opened a bug to our team to see if this can be fixed. Unfortunately, Nomad is not able to view whole presentations at this time, but this is on our list for future considerations. You are correct. This is not possible at this time, but I hope the first bullet is a bug that can be fixed. I added this to our list of future improvements. I added this to our list of future improvements as well.
