Tim Harland
Content Count
82 -
Community Reputation
9 NeutralAbout Tim Harland
Rank
Apprentice
Personal Information
Occupation
Architect
Homepage
www.hoskinsarchitects.com
Location
Afghanistan
Recent Profile Visitors
Referenced Titleblock Styles losing data
Tim Harland replied to Tim Harland's question in Troubleshooting
Hi @Nikolay Zhelyazkov , I have sent you an example test file. It is a bit difficult to replicate as there doesn't seem to be a clear pattern to when it occurs. Kind Regards, Tim -
Hi, we have an issue with a number of our sheet files where at irregular intervals our title blocks lose all of their data (apart form sheet number and sheet name) and revert back to the default values. We have a titleblock style saved in our project library, with the associated record format, and this style is then referenced in to our various sheet drawings. Periodically all the information resets itself, which is an absolute nightmare as we usually just notice it as we are preparing to issue a set of drawings with it associated other stresses 😉 We had the same issue on VW 2019, have recently updated to VW 2021 but are getting the same behaviour. Has anyone else seen similar issues?
Text linked to Record in Symbol Colour Overrides (SLVPs)
Service Select has provided a solution to this issue: if you change your navigation graphics option, it should fix the issue. Tools > Options > Vectorworks Preferences > Display > change Navigation Graphics to Good Performance and Compatibility. For Info the text exported to pdf with the correct colours, ie it was just a display issue. -
Tim Harland posted a question in Troubleshooting
It seems like in VW 2021 class colour overrides are not actioning on text inside symbols that is linked to a record? Is anyone else seeing this? -
Multiple selected space area display sum??
Tim Harland replied to Kazemester's question in Troubleshooting
I have just seen in this thread that this should be coming back in SP3 -
We use this all the time too - it still works for polygons there doesn't seem to be any reason for it to have gone away? -
Viewport Class & layer Override 'Styles'
Tim Harland replied to Tim Harland's question in Wishlist - Feature and Content Requests
That is great to hear! -
@Boh that could work but our class colours etc are defined by the client (for dwg export) and we often have multiple sets of viewport within the same file that have different attributes required. It is not just overrides it is also class visibilities that I’d like to control in one place. The biggest issue is that the workflow to adjust the override properties across multiple sheets is tricky - every time you adjust a property or switch a class on or off you need to get the correct eye dropper settings and run through the whole set - this is not very intuitive or efficient especially when there is a big team working on the project with different skill levels. -
Tim Harland posted a question in Wishlist - Feature and Content Requests
We would love to have a way to manage class and layer overrides in viewports, at least within files - we have some project with over 100 plan sheets alls with the same class override - any tweaks to the override settings requires a very careful use of the eyedropper tool and is difficult to manage. If these styles were able to be transferred across drawings (with the same class set) that would be even better. -
Hi Juan, what ist meant by this feature?: "Data Mapping for Custom Records This task adds data mapping functionality to Vectorworks records." Thanks, tim
I have been querying about this sort of ability to 'lock' fields in a record so that they can be centrally controlled form a project library for years - as Pat says it is currently not possible. There are many use cases where we want to have some data fields fixed per symbol instance and some adjustable (and that the data can all be listed in the same worksheet database). I imagine it would be implemented similarily to the way styles (Space or Window styles etc) allow you to have certain aspects locked ot the style and others adjustable per instance. I have had limited success by embedding an additonal 'data' symbol with the record attached to it inside my symbols - that allows the updated information to be 'pushed' to referenced files, but limits how you can access the information in worksheets.
Data Tag scaling
Tim Harland replied to Samuel Derenboim's question in Wishlist - Feature and Content Requests
Hi Kostadin, Sorry I have tested it a bit more extensively. They behave like page based symbols on design layers but they don't behave like page based symbols in Sheet Layer Viewports - ie they change sizes with different scale viewports. Ideally they would stay the same size in different scaled Sheet Layer Viewports like Page Based Symbols do? That tends to be our real world use of them, ie we want a door label that is on a particular design layer to be the same page size on a 1:00 as on a 1:50 drawing. Regards, Tim -
Data Tag scaling
It would also be good to be able to set Data Tags with Page Based rather than World Based sizes like symbols. -
Fixed Data Fields in Record Formats
Hi Pat, How do you make records invisible? That could work although still has the issue that the data cant be updated in a central library. I have used the data attached to an object inside the smbol as a worksaround before, it works well for scheduling, it is just that the new data tag tool, (which is great and had so many uses BTW) then can't access this data as far as I can tell? I have tested out ifc too - when you change ifc data for a symbol in the resource manager it updates all instances of the symbol in the file where the symbol is located, unfortunately it doesn't push that across to symbols in referenced files as far as I can tell. -
Hi Boh Hi Pat, Thanks yes I understand how worksheets and custom selections work, but not all our staff do and it is too dangerous when people can edit individual instances of a symbol, and ideally we can push changes from a library to multiple files without having to open them indiviually and changing each instance there. It is not only me, after I posted the wishlist I found this old post with the same request: The end of that post has a work around that I am going to explore using IFC data instead of Records. Thanks for your feedback!
