14 -
Reputation
3 NeutralPersonal Information
Location
United States
Recent Profile Visitors
In the process of creating a Legend and Abbreviations page for my current project and wanted to see if anyone has managed to create a report of connectors used in a file. I'm currently using a static worksheet that just has a long list of connectors whether they are used in the current project or not, but in the pursuit of using page space efficiently, I would like to be able to create a report that is just the connector name and description found in the project. Any help would be greatly appreciated!
Device Builder and workgroup Libraries
Brian Nitz replied to Brian Nitz's question in Troubleshooting
ah ok is the user folder accessible from the user libraries in the resource manager or is it found some other way? -
I've recently been working on creating a workgroup device file for the company I work for, I've managed to create the file and add things to it by dragging it into the file from the resource manager. While I can go into the workgroup library and find/use devices with no problem as the library grows it's going to take more and more time to find specific devices. Is there a way to link the device builder tool to the workgroup file so that it would scan it as well as the local user folder?
Cloud Service not syncing local folders on machines
@inikolova thank you but I seem to have figured it out. The file I was having issues with syncing was a working file, while the base was syncing just fine. I was assuming working files went off of a user's account or license but it looks like it's based on the machine in use. -
Currently, I have an issue where cloud services aren't syncing any files on my local machines. I saved a file from my work laptop yesterday but I could see it wasn't uploading it by check-in the web browser so I manually uploaded it via the web browser, today while I see it's still in the web browser it does not sync, and put it in my folder on my desktop. I have all the folders selected for sync in the settings on both machines. Any help would be appreciated.
Using the rack frame tool, Is there a way to have the frame itself front mounted but the cards in the rear of the frame?
I just figured it out, it was a class issue having the circuit connector visible, I will leave up the post in case someone else runs into the issue later.
- 1 reply
- 2
Edit: I just figured it out, it was a class issue having the circuit connector visible, I will leave up the post in case someone else runs into the issue later. Im currently running into an issue where the text from the circuit and the text from the device sockets are overlapping, has anyone experienced this before?
Looking through the forums I've seen a way to create a table of contents based off sheet layers through a Creat Sheet list function, but that seems to be missing in the connectCAD workflow. So is there a way to do this through ConnectCAD?
Rack frame grayed out making slots hard to see
Brian Nitz replied to Brian Nitz's topic in ConnectCAD
@Conrad Preen That makes sense, thank you for the help! -
Brian Nitz changed their profile photo
@Conrad Preen I see, thank you for the help!
I've created a rack frame and added equipment to the open slots but the frame is grayed out making it hard to see the slotted equipment. Any suggestions on how to fix this?
Currently, when placing a piece of equipment into a 3D rack if the equipment takes up multiple RU it will have the top of the equipment be in the RU, so as an example if I have a 2RU frame and I place it into RU 5 via the object info palette the top of the frame will be in RU 5. Is there a setting so that it would be the bottom of the frame in RU 5 instead?
Im currently building the racks for an upcoming project, I've placed a rack frame and created the card using connectCAD create equipment feature. After moving the card into the rack frame it goes out of the frame and stretches up infinitely. You can see in the object info that it knows it's in slot 1 of the rack frame, any suggestions on what went wrong or what I can do to fix it?
