Window Objects Not Showing Jamb Line in Round Wall
This might be an easy one. I just can't remember the solution now in my old age. Or maybe a new problem with new hardware new OS.
How do you get the jamb lines to appear in window objects inserted in a Round wall?
7 answers to this question
Maybe a problem with the new "level of detail" setting.
Which can show Windows, Symbol geometry, .... in 3 different levels,
reduced, medium and fully detailed.
You can also link these levels to automatically switch according to layer scale.
Your Windows appearance looks like the reduced, lowest LOD.
2 hours ago, zoomer said:
Maybe a problem with the new "level of detail" setting...
Thanks for the suggestion. Maybe it's right under my nose, but I can't find the setting. I'm on version 2020. Is that a v2021 feature?
Hopefully it's not a v2020 bug in latest MacOS 11.3 and hardware M1 Mac.
The odd thing is that it's only affecting Round (radius) walls, not straight walls.
Thanks for the file.
So this looks like a bug in Vectorworks 2020 that has been corrected in Vectorworks 2021.
However, this case can be corrected in 2020 by selecting the windows and settings the "Break" to "Full Break with Caps" in the Object Info palette.
Yes! That's the trick. Thank you.
