We are getting weird errors with one folder of VW files. It is most likely a server problem, but our techs have tried everything, and since it only happens with files from this one project, I thought I would see if there was a possibility a corruption in the files could be causing this.
We will be working, and then get the following errors:
The disk drive or file is marked read-only. Please unmark it and try again.
Failed to save the file. Please ensure that the disk containing your local temp folder has sufficient free space.
There is not enough space on the disk to save the file.
Where is the local temp folder?
Is there any chance these errors are with VW and not the file server?
Tom Klaber
Thanks
Edited by Tom KlaberLink to comment
9 answers to this question
