AlanW Posted September 20, 2016 Share Posted September 20, 2016 Uploading a file say over 100,000 kb may result in a error and not be able to be viewed. As most of our small residential projects the model is always over this, will the upload size be increased to cater for full model uploads rather than a model in bits? Thanks Quote Link to comment
michaelk Posted September 21, 2016 Author Share Posted September 21, 2016 I did a test today with a 412MB file. Worked great. In 360 mode on an iPhone the walk around stays on the surface of the DTM. I tried to jump into the pool, but it wouldn't let me. mk Quote Link to comment
AlanW Posted September 21, 2016 Share Posted September 21, 2016 Thanks will give another try. Quote Link to comment
fabrica Posted September 23, 2016 Share Posted September 23, 2016 does the elevation of your layers effect web view? I am only getting the blue screening web browser with nothing in it? Quote Link to comment
AlanW Posted September 23, 2016 Share Posted September 23, 2016 (edited) I find that if you save on your favourite saved view before you export you should start on that when opened. If you get lost you touch the house button top right and it takes you back the the opening view. HTH Edited September 23, 2016 by Alan Woodwell Quote Link to comment
bcd Posted September 23, 2016 Share Posted September 23, 2016 On 9/20/2016 at 10:17 PM, michaelk said: II tried to jump into the pool, but it wouldn't let me. mk iPhone 7 I hope 1 Quote Link to comment
zoomer Posted September 23, 2016 Share Posted September 23, 2016 I tried the Example File from the Newsletter. On My iPad Air II with latest iOS 10. For me the Flythrough Mode did not work so well. Turning works fine but pinching to zoom/walk did not work most of the time at all. So it was not a real first person experience for me so far, More like turning a panoramic image Will the creation of Cameras in VW allow to set some defined starting points for Viewers ? (Or Saved Views ?) Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 23, 2016 Vectorworks, Inc Employee Share Posted September 23, 2016 The start point SHOULD be the view you export the webview from, however I think it works most reliably if you are in Perspective projection and save that as a view right before exporting. Quote Link to comment
zoomer Posted September 23, 2016 Share Posted September 23, 2016 (edited) Ok, so currently not. Like for 3D PDF's. Just for information, in 3D PDF from VW, do I need to use Cameras or Saved Views or can use both ? Edit : VW help is currently down for me but I found it in 3D PDF Export Dialog > "Export Saved Views" Edited September 23, 2016 by zoomer Quote Link to comment
michaelk Posted September 25, 2016 Author Share Posted September 25, 2016 On September 23, 2016 at 9:58 AM, bcd said: iPhone 7 I hope No. 6S. But I hadn't put any water in the pool yet :-) Quote Link to comment
