lolo66 Posted September 9, 2016 Share Posted September 9, 2016 Hi all, Is there a way to draw extended elevations on VW 2016? Thanks, Lois Quote Link to comment
zoomer Posted September 9, 2016 Share Posted September 9, 2016 (edited) Section Viewport > Properties > Advanced Properties > Extend ? Edited September 9, 2016 by zoomer Quote Link to comment
lolo66 Posted September 9, 2016 Author Share Posted September 9, 2016 Thank you for your reply. I've had a look but I don't think that's what i'm looking for. (If you mean Advance Section Properties- Extent) I want to create extended elevations as the builders here in the UK prefer to work with extended elevations over true elevations (I don't know if it's like that in the US!) So every recess is flattened out on the page. I've googled it and I can't seem to find any information about it so i'm thinking that perhaps it's not possible? Quote Link to comment
zoomer Posted September 9, 2016 Share Posted September 9, 2016 (edited) Tried to google. Something like we call "Wandabwicklung" ? (An extended elevation is an elevation of the several wall surfaces of a room arranged so as to read as a long continuous strip. Extended elevations are useful in preparing working drawings for decorators.) I thought this is possible in VW (by use of Spaces ?) but I never tried that. Have to look into it. Edited September 9, 2016 by zoomer Quote Link to comment
lolo66 Posted September 9, 2016 Author Share Posted September 9, 2016 Ah I see-, it makes sense- wand=wall and abwicklung=unrolling- so yes that's exactly what I want to do. What do you mean by use of spaces? I'm not knowledgable of that technique. Thank you! Quote Link to comment
lolo66 Posted September 9, 2016 Author Share Posted September 9, 2016 I've had a look on the German VW's forum and it doesn't seem possible sadly Quote Link to comment
zoomer Posted September 9, 2016 Share Posted September 9, 2016 (edited) I'm not sure, maybe that was a extra option in the german edition of VW from Computerworks. (Or even something I saw somewhere in Archicad) At a first quick look I found no such option in VW, neither in View Menu nor by Space Tool or Objects. Edited September 9, 2016 by zoomer Quote Link to comment
Tom Klaber Posted September 9, 2016 Share Posted September 9, 2016 (edited) Are you generating the elevations from a model? If so - then it is just a matter of arranging the viewports on the page. We still do our interior elevations in 2D. I have heard that there is better interior elevation workflow in the works. I am not sure it will be in 17. Are there other software that can do this? It seems complicated - having to have a rotating camera that detects wall breaks. Edited September 9, 2016 by Tom Klaber Quote Link to comment
rDesign Posted September 9, 2016 Share Posted September 9, 2016 (edited) You would have to do this manually by creating individual section viewports for each short section of wall and then manually lining up all of the Section VPs in order. (It would be nice if the Space tool could be used to automatically create interior elevations, but it doesn't. I think it's been wishlisted before). Edited September 9, 2016 by rDesign Quote Link to comment
zoomer Posted September 9, 2016 Share Posted September 9, 2016 (edited) OK, I see it was Archicad. I always thought that VW could do that Elevation Viewports won't work. As already said, it have to be Section Viewports for each wall and manual aligning Section VP's on a Sheet Layer. And I second the Feature Wish. Edited September 9, 2016 by zoomer Quote Link to comment
lolo66 Posted September 9, 2016 Author Share Posted September 9, 2016 Hi Tom, Yes I am creating my section viewports from a 3D model. Perhaps it is easier to draw the interior elevations in 2D then, if the builders are wishing for complete extended elevations- I shall have to consider that. I believe I read on the German forum that Rhino is able to do this but I don't use Rhino software so can't say for sure. Hi rDesign- it seems a very longwinded way to do a viewport for every tiny section of wall but I suppose at least it can be done this way. I have built up a long wall of true elevations using this method. Thank you for your replies- at least I know now! Quote Link to comment
Tom Klaber Posted September 9, 2016 Share Posted September 9, 2016 11 minutes ago, lolo66 said: Hi Tom, Yes I am creating my section viewports from a 3D model. Perhaps it is easier to draw the interior elevations in 2D then, if the builders are wishing for complete extended elevations- I shall have to consider that. I believe I read on the German forum that Rhino is able to do this but I don't use Rhino software so can't say for sure. Hi rDesign- it seems a very longwinded way to do a viewport for every tiny section of wall but I suppose at least it can be done this way. I have built up a long wall of true elevations using this method. Thank you for your replies- at least I know now! I would not recommend you moving backwards. If you should be able to leverage the model you built. But yeah - drawing section viewport for every wall is what has held us back - from BIM. Again - It has been hinted that the issue will be addressed - it is just a question if it is next week - in which case it could help you - or next year. Quote Link to comment
zoomer Posted September 9, 2016 Share Posted September 9, 2016 That workaround way the Section Lines should be constraint to the Wall ends, for changes, anyway. Quote Link to comment
zoomer Posted September 14, 2016 Share Posted September 14, 2016 (edited) On 9. September 2016 at 4:23 PM, lolo66 said: Hi all, Is there a way to draw extended elevations on VW 2016? Thanks, Lois No !!!! But looks like VW 2017 heard you. It is there ! Creation will be automatic. Just that you may need to move those VP's together for an endles feel. Edited September 14, 2016 by zoomer Quote Link to comment
rDesign Posted September 14, 2016 Share Posted September 14, 2016 But - each Interior Elevation marker can only create up to 4 interior elevations, so you would need multiple Interior Elevation markers to create an extended Interior elevation like you're asking. Quote Link to comment
zoomer Posted September 14, 2016 Share Posted September 14, 2016 Interesting thought. What will happen with an, say, L-shaped Room ? One Viewport will take parallel 2 Walls that will be behind each other in depth ? And you would need to cut that VP in half to include the touching perpendicular wall ? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 The idea is that you would place as many elevation markers as needed, removing any extras individually. You are able to control which ones remain (even just keeping one if you like) without breaking from the marker. If people really like this UI element and what it can do, Engineering has mentioned they are considering allowing a custom number of directions and control over where each one is pointing. Alternatively, another option is allowing the marker to "automagically" determine how many wall views it can grab from its present location and creating as many viewports as it deems possible, but that wasn't included in Phase 1 for this tool. 1 Quote Link to comment
Kevin McAllister Posted September 14, 2016 Share Posted September 14, 2016 16 minutes ago, JimW said: If people really like this UI element and what it can do, Engineering has mentioned they are considering allowing a custom number of directions and control over where each one is pointing. Alternatively, another option is allowing the marker to "automagically" determine how many wall views it can grab from its present location and creating as many viewports as it deems possible, but that wasn't included in Phase 1 for this tool. I would really love to see this expanded to its full potential...... for example, drawing elevations for a theatre box set (three walls, open to the audience, side walls usually angle out), or within a solid addition instead of walls, or elevations that all point towards a point for detailing a freestanding object from 4 directions. Kevin Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 14, 2016 Vectorworks, Inc Employee Share Posted September 14, 2016 22 minutes ago, Kevin McAllister said: I would really love to see this expanded to its full potential...... for example, drawing elevations for a theatre box set (three walls, open to the audience, side walls usually angle out), or within a solid addition instead of walls, or elevations that all point towards a point for detailing a freestanding object from 4 directions. Kevin Agreed, work with it for awhile and see what bits you like, what bits you don't and what areas need tweaking. We will get everything together and get the feedback in as soon as possible for the Phase 2 changes. Quote Link to comment
rDesign Posted September 14, 2016 Share Posted September 14, 2016 21 minutes ago, Kevin McAllister said: I would really love to see this expanded to its full potential...... for example, drawing elevations for a theatre box set (three walls, open to the audience, side walls usually angle out), or within a solid addition instead of walls, or elevations that all point towards a point for detailing a freestanding object from 4 directions. Kevin ^^^^ I agree 100%. The new interior elevation tool is a great first step, but as Kevin described there are many situations where walls are not at right angles to each other. Quote Link to comment
zoomer Posted September 14, 2016 Share Posted September 14, 2016 +1 The creation of VP's by examining Walls sounds fine Quote Link to comment
