Ethan R.
Creating an IMAG viewport?
Hi -
Before I go into "research mode" (Trial & Error!)
I want to create an IMAG viewport.
Figuring I can
- Create a Viewport from a rendtrworks camera
- Copy that viewport to a sheet layer with a screen
distort / adjust that camera viewport to match the skew of the new viewport?
Anyone have a better idea?
Thanks!
Ethan
I think Ethan wants to take a camera view of an event space and insert that camera image onto the screen objects he's placed within the event space in order to create a rendering. For example, if his rendering is a wide shot of the stage with a speaker at the podium with screens behind, he wants a close up of the speaker on the screens rendered from the same environment. Essentially a rendering nested into a rendering.
I've done this before but I rendered out the camera view as a JPG and turned it into a texture to apply to the screen - so a two step process.
(IMAG is live video at an event inserted into the live video presentation - https://en.wikipedia.org/wiki/IMAG)
Kevin
You got it Kevin.
That 2-step process is my plan - going to try the viewport over a viewport! LOL!
E
2 step process works the best... trying to do a viewport on a viewport will be very hard to make it look right
One way to do it is to render the camera view save that image as JPG or PNG. Even if you save it as PDF I think you can copy the picture and save it on your desktop.
Then create a new texture in Vectorworks import the image to that texture and assign that texture to your screen.
I hope this helps.
I take advantage of this conversation to share the learning experience on using now integrated Camera Match in 2017. It is a matter of placing a fix point and align 6 vanishing lines to a photo. Maybe small adjustment at the end. What I like about using camera match is that I can control the rendering style and not always trying to go for Photorealism. (See images)
