432 -
Calendar
Everything posted by Ethan R.
https://blog.vectorworks.net/2017/05/designs-made-walking-simtread-2-5-software I found a blog-post for SimTread - can't find much else?
In VW 2019 there was a plug-in to work with CROWD:IT https://www.accu-rate.de/en/en-crowdit-x-vectorworks/ What happened to that? Is there any other Crowd Simulation tool? We are looking for pinch points in our design and want to play with fire code compliance, etc. Thank you
Bumping this for a muslin material. I'm looking to make a scrim and it would be quite useful 🙂
was this a bamboo symbol by chance?
Rebuild Vectorworks from the Ground up
Ethan R. replied to abshapi's question in Wishlist - Feature and Content Requests
Oh yes we have! Forget new features - fix the ones that are tere. -
I'm so happy to see this tool grow and grow !
Was not trying to do that. By setting bracing to 0 and face to 0, I was still getting the outside frame 🙂
+ set framing width/depth to 0 Thanks !
Hi - Is there way to have jacks span multiple flats? ie. if I'm making 12' high wall with 4x8's ? Thank you 🙂 edit - add image
I haven't been able to work it with spaces, but have it going with Data Viz
Tutorials for Spaces + Worksheets + DataViz ?
Ethan R. replied to Ethan R.'s topic in General Discussion
Working it with Data Viz ... could be longhand? Working i -
Hello all, I have a project that requires me to show how space use changes over time. I'm new to space planning and having a bit of a bear of this. example: Space 1 Month 1: Build-Out Month 2: Retail Use 1 Month 2: Retail Use 2 Month 7: Buildout Month 8: Exhibition Month 14: Tear-Down Month 15: Vacant Space 2 Month 1: Build-Out Month 2: Multi-Purpose Event Space Month 6: Buildout Month 8: Exhbitoin etc .. This could also be reorganized by time Month 1 Space 1: Build-Out Space 2: Build Out Month 2 Space 1: Retail 1 Space 2: Multi-Purpose Event Space As a final product I would like a series of color coded plans showing Usage per Time Period It would great to be able to generate a worksheet from the same data to allow easier manipulation. Thank you Ethan
@Pat Stanford Thank you Reading this; I'm thinking that it is probably faster to simply bash this out on 15 Sheet Layers! 🤣 I'll give it a go and see how we do! For reporting - maybe copy past into excel?
Thanks Pat I have a unit with about 9 "Spaces" or "Areas" I think what you say is correct Over the course of time, the spaces will change use example: Space 1 Month 1: Build-Out Month 2: Retail Use 1 Month 2: Retail Use 2 Month 7: Buildout Month 8: Exhibition Month 14: Tear-Down Month 15: Vacant Space 2 Month 1: Build-Out Month 2: Multi-Purpose Event Space Month 6: Buildout Month 8: Exhbitoin etc .. This could also be reorganized by time Month 1 Space 1: Build-Out Space 2: Build Out Month 2 Space 1: Retail 1 Space 2: Multi-Purpose Event Space As a final product I would like a series of color coded plans showing Usage per Time Period It would great to be able to generate a report from the same data
I need to define space use over time. ie. month 1 -> usage scenario A month 3 -> usage Scenario B is spaces the right tool for this? Can someone help me with a good tutorial? Thank you Ethan
I've had a Gigabyte Aero for the since Nov 2017 - and it is still doing rather well. A log of guts for a good price. I've heard the new OLED versions are pretty slick! (though I think they are only 15") https://www.gigabyte.com/Laptop#AERO-series
Imported OBJ does not find associated textures
Ethan R. replied to Charlie Winter's topic in General Discussion
The sketch-up model imported perfectly! -
I find this intermittent as well. Nothing solid to report here 😞 -
@Brendan Gray@Charlie Winter - Very cool ! Thank you.
we have all noted this for years. The new model of 'annual release' to justify subscription packages is the culprit. This - i belive - is a practise started by apple wit the iPhones and has come to dominate the industry. Gone are the days when software could refine itself over years. The push for new features now outways basic functionality; and we are all dealing with bloated software. Anyone wonder why Acrobat is over 1GB of code? -
Apologies if this has been asked and answered ... When checking layers in/out we are asked to make notes - which is great! Is there a way to see a running list of those check in/out notes? - Perhaps even linked to a design space object on each layer that shows notes relevant to that layer? That way one could track changes between updates (as long as there is good note taking). On that _note_ is there a way to simply show changes since your last sync? Thank you! E
