Atchison Posted July 4, 2016 Share Posted July 4, 2016 I have one file where the object info. palette doesn't show data for objects and won't allow me to input data. All other files are working ok. Is there a setting I've missed? Quote Link to comment
Jim Smith Posted July 4, 2016 Share Posted July 4, 2016 Is this an older file opened in 2016 or a native 2016 file? Quote Link to comment
michaelk Posted July 5, 2016 Share Posted July 5, 2016 I've also seen this in 2016. Closing the palette and reopening it fixed it. hth mk Quote Link to comment
Atchison Posted July 5, 2016 Author Share Posted July 5, 2016 The file was created from a VW 2015 file. I've tried closing the palette and reopening but still not working. Quote Link to comment
Jonathan Pickup Posted July 5, 2016 Share Posted July 5, 2016 Have you tried restarting Vectorworks? Quote Link to comment
Atchison Posted July 5, 2016 Author Share Posted July 5, 2016 Yes - several times. Quote Link to comment
Jonathan Pickup Posted July 5, 2016 Share Posted July 5, 2016 And what if you restart your computer? Quote Link to comment
Atchison Posted July 5, 2016 Author Share Posted July 5, 2016 Still doesn't work after restart. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 5, 2016 Vectorworks, Inc Employee Share Posted July 5, 2016 If that is the case and it only seems to be affecting the one file, get that file in to support and they can take a closer look, it may be a type of corruption that could be repaired: http://www.vectorworks.net/international/ Quote Link to comment
Atchison Posted July 13, 2016 Author Share Posted July 13, 2016 Problem was solved by Julian at Ozcad. 'Try going to the Tools Menu/Origin command and choose Set User Origin to Internal Origin option, to see if that makes a difference'. The user origin of my drawing was set a long way from the internal origin. Quote Link to comment
ajs Posted July 31, 2016 Share Posted July 31, 2016 (edited) using 2016 SP4 Designer on Mac OS 10.11.6/MBP core i7 2.8/16Gb/Radeon R9 M370X 2048 None of these solutions have worked for me in files imported from 2015 or created in 2016, and I need to be naming a bunch of flown goods for a large event. Which renders 2016 semi-useless for creating production drawings. 1.) Is there a fix for this, or do I roll back to, say, 2015 where it does work? 2.) Does anyone know if this feature existed prior to 2016 SP4 (this thread's appearance falling after SP4's release date)? -andrew saboe www.saboedraws.com Edited July 31, 2016 by ajs Quote Link to comment
Kevin McAllister Posted July 31, 2016 Share Posted July 31, 2016 Andrew, Your situation sounds a bit like you had a custom tool installed that got removed. For example, if you used to use the Softgoods 2 plugin but uninstalled it, object you previously made would appear without any options in the OIP. Kevin Quote Link to comment
ajs Posted July 31, 2016 Share Posted July 31, 2016 hello, Mr. McAllister; I know what you mean, and I don't believe that's the case, for 2 reasons. First, didn't have a custom tool installed to remove, and second, it affects pretty much anything. A line, a rectangle, a PIO, nothing I've tried so far allows me to assign a name under the Data pane of the OIP. Or more precisely, while I can name anything whatever I like, it goes away immediately upon deselection of the object. If the field was blank before, it reverts to blank. If the field had text before (because the object was drawn in 2015 originally), it reverts to that text. For example, if I draw a rectangle in 2016 SP4 and name it 'rectangle'in the OIP's Data Pane, the field will be empty the next time I select that object. Or, if I duplicate the soft goods object named #1 Border that was part of the drawing imported from 2015, and try to rename it #2 Border, that's not happening. To keep things from being dull, neither of these behaviors have been 100% consistent, either. Though the first example's trying its best. My workaround right now is to draw and name things in 2015 (where it works just fine), then import the 2015 drawing into 2016, and then paste the objects into my 2016 active file and realign everything by hand. Between that, and lighting devices that disappear in viewports, it makes me all nostalgic for my drafting machine. I appreciate your taking a swing at this on a weekend, though-thank you kindly! -andrew saboe www.saboedraws.com Quote Link to comment
Kevin McAllister Posted August 1, 2016 Share Posted August 1, 2016 Andrew, Thanks for the clarification. Out of curiosity did it start after you updated to MacOS 10.11.6? I am running VW2016 SP4 but haven't yet run the software update from 10.11.5. It sounds like a bug. I'm assuming you've restarted your machine and tried resetting your preferences? Kevin Quote Link to comment
ajs Posted August 2, 2016 Share Posted August 2, 2016 hello, Mr. McAllister; I couldn't really say if this behavior began before the OS update. This is the first time in a while I've needed to name objects-I use it to help keep my hanging plot organized/tell which heavy black line is the cyc and which is the krinkle screen, for example. It's been a bit since I've drawn something that used an actual proscenium stage, and the second or third time I've used this file, importing the previous file, throwing out last years' stuff and adding in new. So strictly speaking, yes, the behavior was first observed after the OS update, but I have no idea if it was there all along, and I just hadn't needed that function so far. Yeah-looks, smells, tastes, walks, and quacks like a bug. I've performed the usual rituals of exorcism to no avail. Things that were created from scratch in vwx2016 seem to be behaving more as expected today, though. -andrew saboe www.saboedraws.com Quote Link to comment
LJN Posted September 27, 2017 Share Posted September 27, 2017 I have the same problem.. Obviously a common problem / known bug. Restarting the computer or Vectorworks didn't solve for me. It is file specific. Could be importing a png file that did it. The only solution was to copy the drawing layer by layer into a new file. Quote Link to comment
station Posted September 1, 2023 Share Posted September 1, 2023 FYI same issue in 2023 - was pasting a png file. Deleted that and it was fine Quote Link to comment
