station
45 -
Reputation
5 NeutralPersonal Information
Location
Canada
Recent Profile Visitors
VW 2022 SP3 Site Model Issues Persist
station replied to inilegnam's question in Wishlist - Feature and Content Requests
i'm getting lags changing door label text size and memory drain as a result. Running windows 11 on a 16 core i9 w/ 64gb ram w/ a wx 7100 amd radeon card - this should not be happening that I have to kill and restart the program to keep working.... -
I might have mentioned this before but increasing issue with callouts 'disintegrating' into lines and groups - frustrating that an automated feature of creating callout instances turns into more work..... the callouts randomly appear all over the drawing and refuse to go home or sometimes reappear but bring all their friends along. Makes for a stupid drawing.
thanks Benson. I've had good luck with align surface in general but no this is simply the geodetic reference for top or bottom. I have a .15m hardscape and I want a modifier (stake or grade) to reference the top and some hardscapes reference to the bottom (seems random). I'll send a screenshot when I am back in that project
Hi- modifying hardscapes and settings are for modifier at top and it seems to randomly work at top or not. Frustrating in that the workaround is to go back and set modifiers to adjust to the component thickness... Especially fustrating when it aligns to the top of one edge and then to the bottom of the next. Is this a known issue or is there something I am missing thanks john
Hi - when adding a callout reference to a sheet the outline appears but the callout does not, when editing the annotation the grip handles show for the callout but again no callout - as a work around I switched the callout styled (or position) and it appears randomly on the drawing as circle, lines and text - (instance references are correct). This is happening across numerous drawings (randomly). VW2022
probably more of a wish list item but is there a way to increase the decimal accuracy of the slope tool. Frustrating to show a ramp on plan at eg. 7.72% 'Fall' (also wish that term could be edited) and then on section at 7.7%
is there a trick to placing a texture on the underside of a roof face - texture tool does not work nor is the object giving face options in the OIP thanks
Roof Drains Modifications constantly crash vectorworks 2022 sp 2.1
station replied to Samuel Derenboim's question in Troubleshooting
the above is a very patronizing disclaimer?? - I've had the same issue continually and have had to restart 4 times so far modifying 4 slab drains running an AMD radeon pro WX 7100 'assigned' to vw - do I need to update a 1K card every 6months to modify a slab drain?? -
I'm having the same issue across multiple files - wondering if it is a AMD compatibility issue - running radeon pro wx 7100
that is all I found as well - I wanted to change the arrow and circle - figured the circle marker should be optional at worst. Oh well thanks appreciate it
Hi - have been looking how to modify the 2d graphics for hardscape (class options don't affect arrows, etc). I am sure there is a setting that I am just missing...
have been using slab drainage tool somewhat effectively to avoid 2d drafting work in sections. BUT how to deal with visibility on plan. It seems the slab slope lines have no controls other than linework settings for the entire slab. Am I missing something? thanks john
i've had that issue as well but not recently - this is different and happens in copying in both iso or plan views. Waiting to see if it re-occurs in 2022
