Christiaan Posted December 17, 2015 Share Posted December 17, 2015 If I was going to model this I would extrude a square, then extrude a triangle by 1 mm and use the Taper Face tool to form 1/4 of the top face. Then duplicate and rotate this shape to form all the top faces. Then make a solid addition. Is there a better way to model this shape? Can it be done with a Subdivision? Quote Link to comment
bcd Posted December 17, 2015 Share Posted December 17, 2015 Try this, I prefer it as it's much more fun: In a front view Draw a section of 1/2 the diagonal and Sweep 300º, segment angle = 90º Quote Link to comment
bcd Posted December 17, 2015 Share Posted December 17, 2015 Subdivision would work too. Might be faster. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 17, 2015 Vectorworks, Inc Employee Share Posted December 17, 2015 The FASTEST way I know to create a pyramid shape that you have control over, is to start with a cube Subdivision, enable Scale mode (the second mode in the secondary modes for Edit Subdivision) and click the top face of the cube. [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=13699&filename=Screen%20Shot%202015-12-17%20at%209.28.02%20AM.png[/img] Grab the dark blue planar reshape handle on the 3D dragger and you can pull in the top corners all at once. If you just want a point, you can press tab and just enter a scale of 0. Then you can switch the secondary mode back to Translate and Rotate and when you select the top peak alter it at will to any height you like. [img:center]https://techboard.vectorworks.net/ubbthreads.php?ubb=download&Number=13700&filename=Screen%20Shot%202015-12-17%20at%209.34.41%20AM.png[/img] If you need the little rectangular base bit as well, you can select the bottom face of the subdivision with Face Extrude Mode and pull it out to the depth needed. Quote Link to comment
mike m oz Posted December 17, 2015 Share Posted December 17, 2015 My quick method: - draw a rectangle - place a 2D locus at its centre point - select both and multiple extrude - rotate so you can see the bottom face - extrude it to the required depth using the Extrude Face mode of the Push/Pull tool. If you need to modify the component heights double click on the object to get to the two separate parts. 1 1 Quote Link to comment
bcd Posted December 17, 2015 Share Posted December 17, 2015 Yes Mike. I believe we have a winner. Quote Link to comment
zoomer Posted December 17, 2015 Share Posted December 17, 2015 My dream would be a parametrical tool - for surrounding houses. Similar to the Massing Model Tool. Your Example would be kind of a one story house with a square plan and a hip roof. So that you draw 2D polygons in plan view, set story height number of stories roof type ridge height or slope Or the possibility to convert any/those flat buildings into SubD's to build the roof. Quote Link to comment
CipesDesign Posted December 17, 2015 Share Posted December 17, 2015 Ahem.... What about using a Roof?? Quote Link to comment
mike m oz Posted December 17, 2015 Share Posted December 17, 2015 There are some great solutions and they illustrate the strength of Vw - its flexibility and many ways of doing things. The weakness with my solution is that to get it to have a 2D appearance in Plan View you would either have to Autohybrid it or make a hybrid symbol of it by adding the necessary 2D. Quote Link to comment
Christiaan Posted December 17, 2015 Author Share Posted December 17, 2015 Ahem.... What about using a Roof?? Did wonder about that but it needs a flat bottom. Quote Link to comment
Marionette Maven Marissa Farrell Posted December 17, 2015 Marionette Maven Share Posted December 17, 2015 Just for fun - A Marionette object that allows inputs for A, B, & C. 1 Quote Link to comment
Christiaan Posted December 17, 2015 Author Share Posted December 17, 2015 My quick method: - draw a rectangle - place a 2D locus at its centre point - select both and multiple extrude - rotate so you can see the bottom face - extrude it to the required depth using the Extrude Face mode of the Push/Pull tool. If you need to modify the component heights double click on the object to get to the two separate parts. Hands down winner Mike. That's the first time I've used the Multiple Extrude command, thanks. Quote Link to comment
Christiaan Posted December 17, 2015 Author Share Posted December 17, 2015 The FASTEST way I know to create a pyramid shape that you have control over, is to start with a cube Subdivision ... Couple of downsides of this method: the edges of the pyramid are rounded. And had to do (admittedly a very small amount) of mental arithmetic to get height correct. Quote Link to comment
Christiaan Posted December 17, 2015 Author Share Posted December 17, 2015 Just for fun - A Marionette object that allows inputs for A, B, & C. Actually, sorry Mike, you're now a distant second! This is brilliant. Not just for fun at all. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 17, 2015 Vectorworks, Inc Employee Share Posted December 17, 2015 She's good. Quote Link to comment
Marionette Maven Marissa Farrell Posted December 17, 2015 Marionette Maven Share Posted December 17, 2015 She's good. Laughing at my desk now. But thaaaaanks Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 17, 2015 Vectorworks, Inc Employee Share Posted December 17, 2015 The FASTEST way I know to create a pyramid shape that you have control over, is to start with a cube Subdivision ... Couple of downsides of this method: the edges of the pyramid are rounded. And had to do (admittedly a very small amount) of mental arithmetic to get height correct. Side note just for anyone checking all the methods out: Marissa's method is obviously better than mine, but the roundness can be solved by the Crease mode being used on each of the angled edges, sorry i forgot about that. In any case, that still increases the number of steps to completion and makes it no longer fast, along with the difficulty in setting accurate heights you mentioned. Quote Link to comment
bcd Posted December 17, 2015 Share Posted December 17, 2015 Just for fun - A Marionette object that allows inputs for A, B, & C. Actually, sorry Mike, you're now a distant second! This is brilliant. Not just for fun at all. except that Marissa used Mike's method in her Maironette! - so they're both first? Quote Link to comment
zoomer Posted December 17, 2015 Share Posted December 17, 2015 Ahem.... What about using a Roof?? Because I want to keep the geometry as simple and reduced as possible. Quote Link to comment
CipesDesign Posted December 17, 2015 Share Posted December 17, 2015 Well, if you Create Roof, then Ungroup, then Convert to 3d Polys and delete the unneeded ploys, you are left with 4 3d polys. Is that not simple enough?? Quote Link to comment
Christiaan Posted December 17, 2015 Author Share Posted December 17, 2015 Well, if you Create Roof, then Ungroup, then Convert to 3d Polys and delete the unneeded ploys, you are left with 4 3d polys. Is that not simple enough?? The Roof Tool was actually the first thing I went to but it imposes quite a cognitive load in the form of having to translate the settings to the simple shape, decide whether all the settings apply or not and, worst of all, you have to do some maths to work out the angle of the top faces. At least with the Roof Face tool you can use rise over run, but even then you're left with a little maths and even more tidy up. The Multiple Extrudes command is pretty much designed with this shape in mind. Very elegant, and topped off perfectly with the Marionette script. Quote Link to comment
CipesDesign Posted December 17, 2015 Share Posted December 17, 2015 More than a few ways to skin some cats ;-) Quote Link to comment
zoomer Posted December 17, 2015 Share Posted December 17, 2015 Yes, you can do that in different ways. Because I do that for every new project, Extruding the existing Buildings around from the site plan, just to have a nice Skyline for Visualization, I would prefer a more comfortable Way/Tool, like an overhaul of the Massing Model Tool, but simple Solid geometry only. I think the way is creating own Tools by Marionette. Could be quite complicated including all my feature list though Quote Link to comment
mike m oz Posted December 20, 2015 Share Posted December 20, 2015 (edited) Christiaan, multiple extrudes are useful for modelling wall cappings with sloping tops (see attached Vw 2016 file and image). You still need to model the bottom part and and then Add Solid them into one object. Also to give them a fill in 2D Plan View you need to either make them into an Autohybrid object or convert them into a hybrid symbol. If you need to have curves then this method is not suitable. That is best done with Extrude Along Path. If you need the ends to slope you have to use either the Split tool or Solid subtraction. Edited December 20, 2015 by mike m oz Quote Link to comment
zoomer Posted December 20, 2015 Share Posted December 20, 2015 ^ Very helpful. Exactly what I need Quote Link to comment
