DomC Posted September 17, 2015 Share Posted September 17, 2015 (edited) This Marionette network uses a custom node, which implemented the pixel-based try and error code (I think there is no other way to create voronoi, is it?) from here https://en.wikipedia.org/wiki/Rosetta_Code Instead of Pixels it uses rectangles which were extruded in random height (ground height is different in every voronoi cell). And different full spectrum random colours (which would look much better with adapted colour design). Carefull playing around with values. Do not enter to high or to low values. Creating 843'135'013 extrudes, could take a while :-) VoronoiTest.vwx Edited January 19, 2017 by MarissaF Update Links Quote Link to comment
Mark Flamer Posted September 17, 2015 Share Posted September 17, 2015 The great thing about Marionette is that it allows us to use any of the existing Python libraries.....and there are alot of them. Scipy and Numpy for example, are huge libraries with lots of good stuff and can be installed using these instructions. The idea is that for VW and Marionette to have access to them they need to be installed in the "Python33\Lib\site-packages" folder of the VW application. Also attached is an example of using these libraries (a couple of functions from them wrapped in a node) to generate a random Voronoi pattern as a plugin object. I'm hoping to provide a stand alone installer for some of these libraries in the near future, it's a little tricky curently. Let me know if you have problems. VoronoiObj.vwx 1 Quote Link to comment
rDesign Posted September 17, 2015 Share Posted September 17, 2015 Very cool. Thanks Mark and DomC. Quote Link to comment
rDesign Posted September 22, 2015 Share Posted September 22, 2015 I'm hoping to provide a stand alone installer for some of these libraries in the near future, it's a little tricky currently. Let me know if you have problems. Mark: I'm having some difficulties with the Python install instructions you provided for Mac OS X. I am no 'Terminal' wizard, and unfortunately the instructions have not been dumbed down enough for my very limited UNIX skill set. If I follow the instructions on Install Python, NumPy, SciPy, and matplotlib on Mac OS X then it installs the incorrect version of Python (2.7), but if I follow your instructions, I can't get 'pip' to install properly. Should the .bash_profile contain both of these lines? export PATH=/usr/local/bin:/usr/local/share/python:$PATH export PATH=/Library/Frameworks/Python.framework/Versions/3.3/bin:$PATH The first line is from the penandpants.com instructions, the second is from your instructions. Thanks in advance. Quote Link to comment
Mark Flamer Posted September 24, 2015 Share Posted September 24, 2015 You dont need to install Python, it's already in the VW package. I know another user who sucessfully got this setup on the mac yesterday. I just sent him an email asking if he can give a tips here. We'll get it...as a community. Quote Link to comment
rDesign Posted September 24, 2015 Share Posted September 24, 2015 Mark - thanks for the reply. That would be great - I was just attempting to follow the steps in the .txt file you posted regarding installing Scipy and Numpy on Mac OS X. Perhaps I misread your post and thought you would need to install these two Python modules if you wanted to work with the Voronoi Marionette example. It may have been unnecessary research, but I found what seems to be a good resource on initial setup for Python on Mac OS X: Hackercodex.com :: Configuring Mac OS X on Yosemite & Mavericks Quote Link to comment
Mark Flamer Posted September 24, 2015 Share Posted September 24, 2015 You are correct in that you need to install Numpy and Scipy in order to run my example that uses these libraries. You do not need to install Python, that is alraedy on your machine. Quote Link to comment
rDesign Posted September 24, 2015 Share Posted September 24, 2015 Great - thanks for the clarification Mark. It was installing pip3.3 where I ran into difficulty with the VW package-installed Python version. Does the Python version have to be 3.3.2 for Vectorworks? I noticed on the Python 3.3.2 release page that a newer security-fix release 3.3.6 is available. (They recommended using 3.3.6). Quote Link to comment
FunkyBass Posted September 24, 2015 Share Posted September 24, 2015 (edited) Hi Tim To install Numpy and Scipy on a Mac, use the description you got with these files. Make sure to install them where you can find them later because you'll need to move them to another folder. Once they are installed just go to your Vectorworks.app and right-click it to enter the contents of the app ('show package contents'). Browse to Contents:Frameworks:Python.framework:Versions:3.3:lib:python3.3:site-packages and drop the folders "numpy", "numpy-1.9.3.dist-info", "scipy" and "scipy-0.16.0.dist-info" in there. Now restart your Vectorworks and enjoy. Have fun. Edited September 24, 2015 by FunkyBass Quote Link to comment
rDesign Posted September 25, 2015 Share Posted September 25, 2015 @FunkyBass - thanks for the instructions, I'll give it a shot. So can I assume that if there are any other Python packages that we want to install and use in Marionette, one would follow similar steps by manually copying them into the Vectorworks.app package? Thanks again for your help! Quote Link to comment
DomC Posted September 29, 2015 Author Share Posted September 29, 2015 Hi Tim I think this shoud be possible. But maybe not every function can be used simply inside the Vectorworks "container". Particularly functions which wants to open a dialog window, print something in the terminal Window and other user interaction. The instruction from Mark and FunkyBass for Numpy-Installation works fine here. I Installed it in a separate folder. And then copy/pasted it in the Vectorworks Application Content. I would not overplay with actions like this ... Quote Link to comment
rDesign Posted September 29, 2015 Share Posted September 29, 2015 I would not overplay with actions like this ... @DomC: I agree completely. Copying and pasting folders inside of application packages makes me very nervous. @Vectorworks: This does not seem like the safest system for users to install additional Python packages. Would it be possbile for Vectorworks to have a symbolic link inside the Vectorworks application package which soft linked to the user's Python installation folder which is outside of Vectorworks? Quote Link to comment
Mark Flamer Posted September 30, 2015 Share Posted September 30, 2015 We actually added a path exactly for this reason on the mac. It should be available in SP2. It is just outside the package at "../Libraries/PythonExternals". Python modules will be available to VW and Marionette from this location. Also, In response to DomC above...I have seen Marionette launch dialogs and plot data from SciPy. It is possible. Take a look at the enormous functionality of these libraries. http://docs.scipy.org/doc/scipy/reference/ All sorts of good stuff there. VW + Marionette + Signal Processing? ;-) Quote Link to comment
rDesign Posted September 30, 2015 Share Posted September 30, 2015 Mark - Thanks for adding the external path to Python, that seems like a much safer, long-term solution. Quote Link to comment
rDesign Posted September 30, 2015 Share Posted September 30, 2015 Take a look at the enormous functionality of these libraries. http://docs.scipy.org/doc/scipy/reference/ All sorts of good stuff there. VW + Marionette + Signal Processing? ;-) Mark - would it be possible with added Python libraries to create a Marionette node that functions similarly to Grasshopper's 'Image Sampler' node? Something that could create 2D surface patterns by sampling a reference image: designcoding :: Facade Study – Bitmap Pattern designcoding :: Image Sampler Revisited Thanks. Quote Link to comment
Mark Flamer Posted September 30, 2015 Share Posted September 30, 2015 I believe so. Scipy has an image processing library. Once we can work with the individual components of the image (colors, pixels, etc) alot should be possible. We could draw and extrude a grid of circles whose radius was determined by the average brightness of the pixels, for example. Quote Link to comment
rDesign Posted October 2, 2015 Share Posted October 2, 2015 Mark - thanks for your reply. Are you saying that just installing scipy will allow us to work with individual components of an image, or is there some core functionality that needs to be added to Vectorworks for this to work (like UV mapping)? Thanks. Quote Link to comment
twk Posted September 7, 2016 Share Posted September 7, 2016 (edited) Hi @DomCand @Mark Flamer, wanting to implement a voronoi pattern in vectorworks, the file that was attached to this thread from the old forum has disappeared. Any chance of re-uploading please. (adding @MarissaFand @Alan Woodwellif maybe either of you had downloaded it and have a copy?) @JimWis this common with all previous attachments at the old forum? Will they be migrated forward at sometime? Thanks Edited September 7, 2016 by twk Quote Link to comment
AlanW Posted September 7, 2016 Share Posted September 7, 2016 Hi , is this the one VoronoiObj (1).vwx 1 Quote Link to comment
twk Posted September 7, 2016 Share Posted September 7, 2016 @Alan Woodwell- you sir are a legend! Cheers mate! 1 Quote Link to comment
AlanW Posted September 7, 2016 Share Posted September 7, 2016 There was this one also. VoronoiTest.vwx 1 Quote Link to comment
rDesign Posted September 7, 2016 Share Posted September 7, 2016 (edited) 3 hours ago, twk said: @JimWis this common with all previous attachments at the old forum? Will they be migrated forward at sometime? See this thread: Edited September 7, 2016 by rDesign 1 Quote Link to comment
twk Posted September 7, 2016 Share Posted September 7, 2016 Thanks @rDesign, first time i've seen the KnownIssues thread.. thats great! Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted September 7, 2016 Vectorworks, Inc Employee Share Posted September 7, 2016 It's brand new! Also I had the permissions on it set improperly the day we rolled the new forums out. This is where I will be moving all confirmed bugs in the software, content, website and forum after they have been "officially" confirmed by me or another employee. The idea is that an bugs overall path would be: Troubleshooting Forum > Issues Discussed > Issue Confirmed > Issue Moved to Known Issues > Updates on Issue as they come > Confirmation of fix in a given version or at a given date. 1 Quote Link to comment
