J. Wallace Posted February 25, 2013 Share Posted February 25, 2013 Hello I created a hybrid object, a no post road side barrier. It looks great in top plan view but when I send this to surface and look at it in 3d you can see that the middle of the object has been sent to surface and thus it sinks the one end and elevates the other. I have at least a hundred of these to place along the edge of the model and hope there is a simple fix for this. Quote Link to comment
Ozzie Posted February 25, 2013 Share Posted February 25, 2013 I think you will have to rotate it in a 3D view so that the bottom of it is on a similar plane to the site model surface Others?? Quote Link to comment
CipesDesign Posted February 25, 2013 Share Posted February 25, 2013 I agree that you will need to rotate the object to match the slope of the road. However that could mean creating multiple instances of the object to fit different degrees of slope. The Send to Surface is not intended to rotate (or fit) an object to the surface, merely place it there. There may be an easier way. Depending on your specific needs (modeling for presentation or for tabulation of specific pieces needed?) you could try using an Extrude Along Path object, with a Nurbs as the path. The path will of course need to follow the road both in plan view and as it goes up/down... Quote Link to comment
J. Wallace Posted February 25, 2013 Author Share Posted February 25, 2013 Thank you Ozzie and Peter. I will give that a try. To answer your question Peter, this is for presentation purposes. Quote Link to comment
CipesDesign Posted February 25, 2013 Share Posted February 25, 2013 After further thought, although the EAP method will work, it may not look exactly correct unless you are carful to use only straight segments. Otherwise it will show curved concrete barriers... You might try using a number of EAP's (it will hopefully be less than the actual number of barriers if placed individually).The advantage to this is that you might be able to make one (or several) very long sections of the barrier. The downside is that long sections will not show breaks between the actual pieces, as there would be in real life... Quote Link to comment
bcd Posted February 26, 2013 Share Posted February 26, 2013 Try this: Draw a Nurbs curve on the surface of your dtm along the barrier line. Select both it and an instance of the barrier Symbol Edit>Duplicate along path - Fixed Distance (=symbol length + gap) (Start offset 1/2 symbol length) (Tangent) The symbol cannot be a hybrid symbol. Quote Link to comment
CipesDesign Posted February 26, 2013 Share Posted February 26, 2013 bcd, That's the best solution! I had forgotten about Duplicate Along Path. Thanks! Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Great advice bcd, thanks to everyone for your valued input. Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 I tried this out bcd and I'm having some issues. I place the 3d object, then rotate/adjust it so that it is sitting on the surface and is level (in relation to the grade), then duplicate along path and all the barriers sit just below the surface as indicated on the attachment. If I can fix the elevation issue this will work wonderfully. Quote Link to comment
Jonathan Pickup Posted February 26, 2013 Share Posted February 26, 2013 Don't forget that you can also use the place plant tool to do this. Make a plant with the 2D/3D parts that you want and run off the option to have the plant on the schedule. Then use the poly edge mode for placing. Because they objects are plants, they automatically follow the site model. I have used this method to create wind farms. Quote Link to comment
Jonathan Pickup Posted February 26, 2013 Share Posted February 26, 2013 . If I can fix the elevation issue this will work wonderfully. The elevation is based on the insertion point of the symbol, edit that to fix the elevation Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Jonathan are you suggesting to make this road barrier a plant symbol so it will place itself on the surface? Quote Link to comment
bcd Posted February 26, 2013 Share Posted February 26, 2013 I tried this out bcd and I'm having some issues. I place the 3d object, then rotate/adjust it so that it is sitting on the surface and is level (in relation to the grade), then duplicate along path and all the barriers sit just below the surface as indicated on the attachment. If I can fix the elevation issue this will work wonderfully. Hi Jamie, You don't even need to (shouldn't) rotate the symbol. Just be sure that it's created so it's sitting on the ground plane. with it's insertion point in the center of the base. Then using the Duplicate along Path it will be automatically rotated to follow the slope of the nurbs curve. In my example I used a curve with degree 1 to ensure it consisted of straight segments. Unfortunately Place Plant will not rotate the symbol for you. Quote Link to comment
Jonathan Pickup Posted February 26, 2013 Share Posted February 26, 2013 Unfortunately Place Plant will not rotate the symbol for you. Ah, i just saw that jamie has vw2012, in 2013, you can have plant that rotate Along the lIne. Jamie, yes, i was suggesting that you use the plant tool. Try stoping at the corners to get a good join. it may not be suitable for your situation, but its a good easy method when it works Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Hi bcd When I follow those instructions I get the image below. If I raise the elevation on each symbol by 30 cm its about right, but the symbol does not seem to follow the model grade.... Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Here is a side view, the brown line is the model surface. Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 I agree Jonathan it sounds like a good fix. If I make this a hybrid object and then a plant symbol I get this result. It wants to lay flat rather than on top of the model surface. Quote Link to comment
bcd Posted February 26, 2013 Share Posted February 26, 2013 Are you sure you're not using a hybrid symbol for the DAP? It looks to me that this is why it cannot rotate it to fit the Nurbs curve slope. Again - here it is but with a simplified nurbs curve. The DAP command apparently doesn't use the insertion point as I had thought. It uses the geometric center, so you will have to elevate either the symbol itself or all the barriers by 1/2 their height. Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Thanks bcd. I made sure this was a 3d object not a hybrid when I was preforming the DAP. You explanation makes sense as the geometric center seems to hit the mark. I can see this is a great way to layout the barriers but I will still have to make adjustments to each one. Thanks Quote Link to comment
bcd Posted February 26, 2013 Share Posted February 26, 2013 Hi Jamie, no you just need to be sure your symbol isn't a hybrid and sits flat, (edit the symbol from the Resource Browser not from the Design Layer) It will flow along with the slope of the Nurbs curve. Quote Link to comment
J. Wallace Posted February 26, 2013 Author Share Posted February 26, 2013 Things are getting more confusing on this end. I imported my symbol into your posted files and I got this. Insertion point seems to be middle of symbol and they follow the curve but do not turn their orientation??? 30 years ago I was an apprentice horticulturalist....I feel like that once again. Quote Link to comment
J. Wallace Posted February 27, 2013 Author Share Posted February 27, 2013 Here is the file with the added symbols bcd. Quote Link to comment
J. Wallace Posted February 27, 2013 Author Share Posted February 27, 2013 Discover something odd... When placing the symbol it sits nicely on the surface. Once we duplicate along path the symbols insert themselves based on their mid point. Can anyone tell me what I obviously don't see? Attachments show the steps Quote Link to comment
J. Wallace Posted February 27, 2013 Author Share Posted February 27, 2013 I elevated the curve by half the symbol height. Got this which is close but not ideal.These symbols look benched instead of running with the grade Quote Link to comment
bcd Posted February 27, 2013 Share Posted February 27, 2013 I think we have it: Dont forget - cmd-T to have the symbol flow // to the tangent! hth Brian Quote Link to comment
