digitalcarbon Posted December 28, 2012 Share Posted December 28, 2012 i hope i am doing something wrong if not then this is crippling http://youtu.be/eGn4O1OOoJo Quote Link to comment
0 michaelk Posted December 29, 2012 Share Posted December 29, 2012 I think what you want to do is very possible. Can you post a small example? mk Quote Link to comment
0 digitalcarbon Posted December 29, 2012 Author Share Posted December 29, 2012 (edited) i cleaned the file up but it is still 3+mb so here is where you can get it thanks http://dl.dropbox.com/u/40223273/worksheet%20sum.vwx corrected link above sorry Edited December 29, 2012 by digitalmechanics Quote Link to comment
0 digitalcarbon Posted December 29, 2012 Author Share Posted December 29, 2012 mk, was just at your web site. someone at vw needs you to streamline the worksheet program. your worksheet formatting tool is really good. Q. since spread sheets are not a new item why not have the data export to any existing spread sheet then vw does not need to spend time developing spread sheets but can work on export and import live spread sheets? Quote Link to comment
0 Benson Shaw Posted December 29, 2012 Share Posted December 29, 2012 Related complaint: Why are we dragging "tiles" to sum and order columns? Is this necessary somehow to the developers? Cute, but extremely unlike any other function in vwx worksheets or anything else in the software. OK, eyedropper tool is somewhat similar. I often think about submitting the tiles as a bug. -B Quote Link to comment
0 michaelk Posted December 29, 2012 Share Posted December 29, 2012 I don't think that link is the one you wanted. It links to instructions for using drop box. I used to have the worksheet formatting scripts on my website so my user group could be guinea pigs. I've since expanded them and posted them here: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=165997#Post165997 I've got another batch almost ready to go.... mk Quote Link to comment
0 digitalcarbon Posted December 29, 2012 Author Share Posted December 29, 2012 sorry here is the correct link http://dl.dropbox.com/u/40223273/worksheet%20sum.vwx Quote Link to comment
0 bcd Posted December 30, 2012 Share Posted December 30, 2012 one solution: This assumes offcuts can be joined. Quote Link to comment
0 Bryan G. Posted December 30, 2012 Share Posted December 30, 2012 If you place the Sum in the "Location" Column it will give the correct sum. This is quite strange though. Quote Link to comment
0 mike m oz Posted December 31, 2012 Share Posted December 31, 2012 DM I think the problem stems from each pipe instance having a unique record from the Function record. Summing the fixed length filters the report to using the Fixed Length record which gives you a result by each unique length used. In the attached file I managed to get the correct result by adding a Total length column which is calculated from the fixed length by the count. Then by dividing that figure by 20' you get the answer you need. There may be other solutions and hopefully after the New Year one of the 'Worksheet Gurus' will respond with a better solution. In the meantime though what I have done will get you the correct result. Quote Link to comment
0 michaelk Posted December 31, 2012 Share Posted December 31, 2012 It works if you sort by length instead of Function. The sum command summarizes all the like values in adjacent cells in a database column. So you first have to sort to get them to line up the correct way that bunches all the like values together. That's why the function column values go away when sorting by Function and summarizing by length - there are multiple Function values for each of the the summarized length values. If it were to give the values you want with those commands it would have to ignore the sort - which would be very annoying in many circumstances. i.e., The worksheet would have to pick an order of summarized cells different than the way it is sorted. If the values in a summarized column are A A A B B A A B B VW databases seem to summarize them to A B Rather than A B A B Not sure why. Perhaps the New Years Gurus will have some information. The way to get the correct counts you are looking for is to sort the database by that column to get A A A A A B B B B and then sum to get A B This will make the counts work correctly. This example might be helpful. Often you want to sort and summarize and count by two criteria. Say 3 shapes and 3 colors of each shape. You would first sort by shape and then sort by color. Then summarize first by shape and then by color. Call for a count in the database header and you will get a count of each shape in each color. Example attached. mk Quote Link to comment
digitalcarbon
10 answers to this question
