Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
dontevenjoke
What is the most effective way to produce photomontages?
Hi,
I am trying to show a client how a home addition will appear using a photo of his existing home and montage-ing a 3d VW image.
What is the easiest and/or most effective way to do this?
Thanks,
Photograph the existing site and then measure the distance and your elevation from your camera tripod to say, the main story floor, and then apply the same amounts +/- when placing the Camera tool into your Top View drawing. Render and export the image into Photoshop, add it to the site photograph on its own layer and see what you did wrong in setting up the model, then try again, etc. until you get it reasonably close. You can do a little warping of the adjoining buildings in PS to get them to align better with your model.
One has to be impressed, when reading the input parameters of Matt Panzer's Camera Match, as to the several settings which remove guesswork in comparison to VW's own Camera tool, which has lots of power but leaves you with little to go on when compositing with a site photograph. Thus, given the low cost of the plugin, and the high cost of your time, it may be an idea to pick up Camera Match and save yourself the hassle of winding up with an image which you don't feel really good about.
DWorks - your bosses attitude is unfortunate. You will spend more money in the time you take tweaking the view to get it right than the plug-in would cost.
The fudging with the perspective and point of view that happens between the 1st and 2nd sentence above is what Camera Match gets done rather quickly, although still with some fudging required.
If you really can't get Camera Match, at least view the movie tutorial on his website. It's a great explanation of the use of Renderworks backgrounds and image-filled polygons to composite a rendering into a photo without resorting to Photoshop or the like.
The work method shown allows a viewport to be set up so that a re-rendered composite can be "automatic", without going through the export image fiddling process repeatedly. That nugget alone is nearly worth the cost of the plug-in, and in this case it's free!
I can't buy the plug-in on my job. My boss won't lett me. So I need some info on how this can be done withouth the plugin.
What I would do is time how long you are taking to achieve this task, including forum time.
When you have completed the task tell your boss, that you can achieve the same result in 5 minutes with Matt's plug in.
Job done.
You have to do the view adjustments inside the Viewport. If you prefer to do it via the camera object then be aware that camera objects aren't linked to Viewports, so each time you adjust the camera location you will have to generate a new viewport.
