barnes2000 Posted February 14, 2008 Share Posted February 14, 2008 Is there a way to autoreduce the number of vertexes on a polygon rather than deleting one at a time? Quote Link to comment
Christiaan Posted February 14, 2008 Share Posted February 14, 2008 I'm pretty sure I saw somewhere that you could drag a marquee around vertices in v2008 to remove them, although I can't seem to do it myself. Quote Link to comment
Benson Shaw Posted February 14, 2008 Share Posted February 14, 2008 If you are trying to approximate the shape with fewer verticies, this Purge Poly VectorBits plugin might help for 10 EU: http://www.vectorbits.com/VectorBits/donationware/Entradas/2008/1/8_Purge_Polygons.html In VW12, dbl click to edit a poly, and option-drag (might be ctrl-drag in Windows) a group of vertices. The selected points can be moved as a a group, but I can't make them delete as a group even though edit poly tool is in delete mode. Anyone have that technique? Seems like the Smooth Poly command should help with this, but it only changes the point definitions. Maybe VW2008 has the desired functionality. I gotta get mine out of the box and install it. I am waiting to finish a couple projects before switching aps. -B Quote Link to comment
ionw Posted February 14, 2008 Share Posted February 14, 2008 Hi Christiaan, you are correct in your memory. in 2008 if you are using the 2d reshape tool and marque around a series of vertices on a polygon or polyline then hit the delete key all enclosed vertices will be deleted. HTH, ion Quote Link to comment
barnes2000 Posted February 14, 2008 Author Share Posted February 14, 2008 Thanks guys. I see what you're talking about with the marque and deleting of vertexes. I'm looking for a simpler way of removing unnecessary vertexes from a polygon while still maintaining it's shape. Using the marque and deleting does get rid of the vertexes, but it starts to change the shape of the polygon too drastically. I didn't mention that these were 3D polygons that I converted to 2D polygons, and by doing so, created hundreds of new vertexes. Quote Link to comment
mike m oz Posted February 15, 2008 Share Posted February 15, 2008 VectorBits Donationware: Purge Polygons: http://vectorbits.com/VectorBits/home_original.html Quote Link to comment
islandmon Posted February 15, 2008 Share Posted February 15, 2008 Lowering your Preference>2d/3d resolution prior to the conversion from 3d>2d or 2d>3d will reduce segments based on the Low,Medium,High,Very High ... options. Quote Link to comment
mark@custom Posted March 21, 2008 Share Posted March 21, 2008 (edited) All right, someone's gonna have to draw me a picture.... So I select the offending polygon [with its many many vertices] and the 2d reshape tool is 'on' and its cursor is the cross hairs that would go in the center of a circle - right?; now how do I draw the marque? I click and drag over the section but nothing happens. VW2008 on a PC Yes, I am that dense... Thanks! And, yes, I have reset my 2D resolution to "low" for importing this 2d art dxf file.... [These clients and their silly logos....sheesh] Edited March 21, 2008 by mark@custom Quote Link to comment
mark@custom Posted March 21, 2008 Share Posted March 21, 2008 Nevermind, I think I have it now. Well, I'm not looking to delete "all" of the vertexes in the marque, just every other one. I've had this issue from time to time over the years. There used to be a simplify poly plugin that one could download from the support area. Anything like that for 2008? Thanks, m. Quote Link to comment
